iron rock rear sway bar links - JeepForum.com
post #1 of 10 Old 03-19-2012, 01:33 PM Thread Starter
adavis39
ok so this is staring to irritate me. everytime i max out my suspention travel, the left rear sway bar link pops off the bushing.(the bushing is still bolted to the sway bar but the link actually comes off the busging disconnecting that side of my sway bar) I got these links and bushings straight from IRO. They seem very solid but I an tired of taking it off and putting the bushing back in everytime I go offroad. Has anyone else had this issue. Any suggestions on how to fix or should I just fine some replacements?
adavis39 is offline
post #2 of 10 Old 03-19-2012, 01:35 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Can you take a pic?
~Richard
billzcat1 is offline
post #3 of 10 Old 03-19-2012, 01:39 PM Thread Starter
adavis39
yeah, i took one this weekend but havnt had time to upload it. Ill do it tonight. Its like the bushing just keeps pulling out of the loop on the end on the link. It isnt loose, its actually a huge pita to press them in.
adavis39 is offline
post #4 of 10 Old 03-19-2012, 01:47 PM
billzcat1
2003 WJ
I'm just wondering if you could pre-load the bushing by sandwiching it between two Grade 8 washers. Or if your sway bar is at a nasty angle, increasing load on the links.
~Richard
post #5 of 10 Old 03-19-2012, 01:52 PM Thread Starter
adavis39
yeah, i had considered the washer idea. Any risk of breaking the sway bar though if I essentially make it the weak link. Also, has anyone ran discos on the rear? I have been thinking about it since I defiantely like having the swar bar for on road performance but can tell a huge difference in the amout of flex with it off
adavis39 is offline
post #6 of 10 Old 03-19-2012, 02:05 PM
billzcat1
2003 WJ
Are you running a stock sway bar or Addco? As far as I know there are not any available disconnects for the rear, but the links are very easy to unbolt.
FWIW, when things break, it tends to be the mount bracket pulling out of the frame or the axle-side mount brackets breaking. Sway bars are made of spring steel, very resilient stuff. But sway bar angle has a lot to do with things breaking, it could also be affecting your flex a LOT. I have tried wheeling with/without rear sway bar and prefer it connected (stock bar). The front is discoed and handles all the flex, the rear bar keeps the body more stable.
The rear sway bar should be sitting between 0 and 15° to horizontal at your normal ride height. The steeper the angle, the more wheel travel is restricted.
~Richard
post #7 of 10 Old 03-19-2012, 03:03 PM Thread Starter
adavis39
still runnin stock bar. Ill check the angle when I get home. I never had the angle specs for the rear just he front so that helps. thanks
adavis39 is offline
post #8 of 10 Old 03-19-2012, 08:41 PM
rkperry1
Had the same problem, it was the washer. I didnt have it in the right side, it would slip right over the head of the bolt and come undone. hope this helps. might want to do one on each side
2001 Grand Cherokee 4.0 Inline. 4 inch Lift with Bilsteins, 245/75/16 BFG ATs. Westin bull bar, Halos, 12" JL Audio W7
rkperry1 is offline
post #9 of 10 Old 03-19-2012, 08:55 PM
Planetcat
2010 WK
I have the IRO links with a few sandwhiched washers. I don't fully flex out, but it keeps the clunking down and the bushings stay in the end link nice and tight. Put as many as you can in between the bracket and the bushing. They don't need to be grade 8, there's no stress on them.
2010 WK Laredo 5.7L, 2004 WJ 4.7L (totaled), 1959 CJ-5, 1996 XJ (sold), 1989 YJ Wrangler 4.2L (Sold)
Planetcat is offline
post #10 of 10 Old 03-20-2012, 07:31 AM Thread Starter
adavis39
thanks for the input guys. It gives somethin else to do this weekend. gotta throw a new exhaust on the wifes new 07 overland too. busy weekend
adavis39 is offline
Rear Sway bar links WheelinCowboy WJ Grand Cherokee Forum 22 10-06-2011 05:24 PM
Rear sway bar links vwbuge WJ Grand Cherokee Forum 4 04-30-2011 07:09 AM
Rear sway bar end links and rear sway bar body bushings nickc50310 WJ Grand Cherokee Forum 34 02-23-2011 03:07 PM
NEED HELP WITH QUESTION. Im installing my rear extended sway bar links and.. NewtonGT WJ Grand Cherokee Forum 7 02-20-2011 10:39 AM
rear sway bar end links inlinegrand6 WJ Grand Cherokee Forum 2 09-20-2010 12:49 AM
