What is the ride quality difference these two springs? I guess we can throw Zone's springs into this discussion to. Does one ride stiffer then the other? Is a stiffer spring better or worse for mild offroading (no serious rock crawling)? Or is a softer spring better. Why did you go with one over the other?
ArloGuthroJeep - I see in your Arlo's Lift Kit: you choose the Tera Flex springs. Could you explain why you picked those. Also that post is pretty old (2007), do you still fell that the Tera Flex are the best?
And just to verify my ignorance, High Spring Rate equals a stiffer spring correct?
