IRO install, unkown washers. PLEASE HELP - JeepForum.com
post #1 of 6 Old 07-14-2013, 12:31 PM Thread Starter
LIMITEDwoLIMITS
2003 WJ
Hey guys, so I got my IRO adj. trac bar and adj. front upper and lower CA's. I had to take my WJ to a fab shop since they wont let me work on it on base. In my box it came with a bag of fairly thick washers. Im not sure what they are for. Im thinking the Trac bar. Please let me know. I dont have any pictures. my bad. I just wanted to let the shop know for certain what they are for.
Thanks
03 WJ 4.7 4X4 SWAPPED IRO 4" synergyballjoints,bilstein5100,Addco rearsway,JKS discos
Last edited by LIMITEDwoLIMITS; 07-14-2013 at 12:32 PM. Reason: found part of the answer
LIMITEDwoLIMITS is offline
post #2 of 6 Old 07-14-2013, 12:34 PM
skain8
skain8's Avatar
They are most likely for your lower control arms at the axle.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #3 of 6 Old 07-14-2013, 05:55 PM
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
They are for the lower control arms. Two washers going on the axle side, (one on each side of arm). One washer goes on the outside of the frame mount so the control arm is spaced towards the middle. These are necessary to properly tighten the control arms with out bending the mounts. There should be a total of 6 washers. 3 for each arm. Make SURE they get put on PROPERLY or else your mounts will be bent and that isn't a fun time.
Axle side should be = axle mount-washer-control arm-washer-axle mount
Frame side = frame mount-control arm-washer-frame mount
Also most people put the jam nut facing the frame side as well.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4 of 6 Old 07-15-2013, 12:45 PM
JimmydaGreek
2015 JK Wrangler
I'm in the middle of installing mine too and I got the washers on the axle side no prob. BUT, on the frame side my control arm fits perfect on the driver's side without a gap but it does has a slight gap for a washer on the passenger side. Should I bend out the frame mount on the driver's side to allow room for the washer?
Thanks...
2015 JK Unlimited Rubicon Loaded and Modded
JimmydaGreek is offline
post #5 of 6 Old 07-15-2013, 01:13 PM
snobrdrkid07
WJ for Life
I would use the washer on the Frame. Mine fit perfectly on each side with a washer. Why yours don't I couldn't tell you.
-Michael-
post #6 of 6 Old 07-15-2013, 01:18 PM
JimmydaGreek
2015 JK Wrangler
Yeah me neither...room on one side and not on the other, strange.
