IRO adjustable arm question - JeepForum.com
post #1 of 9 Old 03-13-2014, 05:10 AM Thread Starter
veiri86
2003 WJ
I have the IRO adjustable arms but after I adjusted them they are still loose as I can't find a proper hex key to tighten that hex bolts shown in the white circles in the photo below, if anybody had luck knowing the size I will be grateful
Sent from ME
R.I.P ratmonkey
Build thread:
01' 4.7 Limited WJ 5" lifted, Rubicon Express 4.5" coil springs with IRO critical path setup and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), JKS HD tie rod (MOOG problem solver Ends), JKS HD drag link (Moog Probel solver Ends), 4.56 Yukon ring and pinion, Moog HD SSD107 Steering Stabilizer, IRO Front drive shaft conversion, Stillen slotted rotors all around with Stillen brake pads, IRO adjustable A-Arm, 3" all the way Kolak Exhaust with High flow Magnaflow Cat. Converter and Flowmaster Super 50 Muffler, 285/70R17 AT Kumho (33") on 17" BlackWheel rims 909B, K&N Cold air intake, Four nozzles Bosch injectors, and Flashpaq 3780.
03' 4.7 H.O WJ 3" lifted, OME HD with 0.5" Coil spacers and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), Moog Problem solver TRE's, IRO Front drive shaft conversion, IRO adjustable A-Arm, High flow magnaflow mini cats, high flow magnaflow cat, Flowmaster Super 44 muffler, 265/65R17 AT Yokohama on 17" Rays rims, and Flashpaq 3780
veiri86 is offline
post #2 of 9 Old 03-13-2014, 09:30 AM
ZJPunk98
Which arms are these? I will call them for you and get the size allen key.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline
post #3 of 9 Old 03-13-2014, 09:40 AM Thread Starter
veiri86
2003 WJ
Thanks a lot. I really appreciate it.
They are the front Y arms for the 4" IRO lift kit critical path.
Thanks a lot in advance
Sent from ME
R.I.P ratmonkey
Build thread:
veiri86 is offline
post #4 of 9 Old 03-13-2014, 10:56 AM
Tollmtn
Sent from ME
If they still use the same size they did when mine were built....You need a 3/16" (.1875") allen wrench. If you can not find an inch allen wrench you might change the bolts to M. I think the size would be around M6.
Also....Veri your pictures are blurry but it looks to me like IRO has changed the design of their flex joints, they look like they contain the guts with a snap ring. If at all possible would you please take some pictures of both sides of the flex joints. And If you have one that is not assembled please take some pictures of the internal parts. Previously they used a flex joint that was bolted together.
Tollmtn is offline
post #5 of 9 Old 03-13-2014, 12:50 PM Thread Starter
veiri86
2003 WJ
Thanks a lot for your feedback, always am stuck with inch or US bolts and nuts while all the ones here are metric, for example I had to order the jam nut for my IRO adjustable track bar from the US as IRO forgot to send it and here such thread type is not available.
Concerning the photo, actually this is not an actual photo, I found it online and marked the bolts, but I will snap some real shots tomorrow for the arms and post them on here
Sent from ME
R.I.P ratmonkey
Build thread:
veiri86 is offline
post #6 of 9 Old 03-13-2014, 10:22 PM Thread Starter
veiri86
2003 WJ
Here are the bolts on the IRO arm which I can't find a matching hex key size here to tighten it
Are these arms similar to yours Tollmtn?
Sent from ME
R.I.P ratmonkey
Build thread:
veiri86 is offline
post #7 of 9 Old 03-14-2014, 11:35 AM
Tollmtn
Sent from ME
Yes that is the same clamp as on mine. The allen wrench size is 3/16 inch.
Look at the sizes below. You may be able to find M6 bolts locally, you could just replace the bolts. The only issue would be if the counter bore for the bolt head on the arm is large enough for the metric bolt head. You could buy one M6 bolt and nut and give it a try to see if that would work.
1/4" bolt = .250" diameter, Head outside diameter .375", allen wrench 3/16"
M6 bolt = .236" diameter, Head outside diameter .393", allen wrench 5mm
Tollmtn is offline
post #8 of 9 Old 03-15-2014, 11:26 AM
ZJPunk98
I forgot to call IRO the other day, got busy sorry. Just tried them to provide you with their answer but they are closed for the day.
I am sure Tollmtn is right on.
Erik
ZJPunk98 is offline
post #9 of 9 Old 03-15-2014, 12:49 PM Thread Starter
veiri86
2003 WJ
No worries bro. Really I appreciate your assistance.
Actually Tollmtn is my reference for anything related to IRO as his feedback based on actual experience not just theories.
Sent from ME
R.I.P ratmonkey
Build thread:
veiri86 is offline
