interior lights and windows problem - JeepForum.com
post #1 of 3 Old 01-29-2014, 10:09 AM Thread Starter
mollydodger
2009 FSJ Cherokee
My daughter just called and says her interior lights won't turn off and her power windows won't work. I suspect the wiring between the door and jamb. I will have the car in a few minutes but would like suggestions on what to look for first. Thanks!!!! It is a 2004 Grand Cherokee.
mollydodger is offline
post #2 of 3 Old 01-29-2014, 10:13 AM
ChrisHager
Administrator
ChrisHager's Avatar
You're correct.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is online now
post #3 of 3 Old 01-29-2014, 03:27 PM Thread Starter
mollydodger
2009 FSJ Cherokee
interior lights and windows not working correctly
Chris, You were correct as well!!! I fond the black wire and the orange with white stripe wires broken completely in two. Replaced sections from the connector at the door all the way into the kick panel area. All is good!!! Thanks for your reply and help!!!!!!!!!!!!!!!!!!!!!
