Interior bezels trim - JeepForum.com
post #1 of 271 Old 04-15-2011, 05:05 PM Thread Starter
Thomahawk
I am going to paint My Interior bezel Trims wooden pieces because i Think its very old fashion/school. I have a dark grey Interior and thinking of painting the bezel trim dark grey metalic like "gun metal".
Anybody That has done theres That can post pics so i can see How it Looks?
Havent Made up My mind about colour yet. 
Buildthread
Thomahawk is offline
post #2 of 271 Old 04-15-2011, 06:23 PM
narnwv
narnwv's Avatar
there's brushed aluminum ones out there. There's a junk yard around me that used to have one with that trim. I'd do that over painting, painting makes it so cheap looking....like the 17 year old ricers do their vents and such.
Freedom edition:
Columbia:
You get the idea....
~Aaron
narnwv is offline
post #3 of 271 Old 04-15-2011, 07:22 PM
Nubster
You can probably sell off the wood trim to someone that appreciates it and buy the trim you like with the proceeds.
"When I Die, Bury me in my Jeep. 'Cause it's never been in a hole it couldn't get out of!"
White Jeep Club #132
Nubster is offline
post #4 of 271 Old 04-15-2011, 07:51 PM
mattmc74
2009 JK Wrangler
Agreed. Just buy a trim kit. There is a few really nice ones out there.
mattmc74 is offline
post #5 of 271 Old 04-15-2011, 09:32 PM
imaguy3
if you do plan on removing your trim pieces this would be helpful... http://wjjeeps.com/interiortrim.htm#DOOR
"The long right strip above the glovebox is attached from the back of the instrument panel with four 10mm bolts and is much more difficult to remove. Due to safety considerations in the event of an accident, it is securely bolted on from the back. This trim piece is laminated to a piece of thick metal and weighs more than a half pound. To remove it requires the disassembly and removal of the entire instrument panel, including the cluster, radio, A/C unit, glovebox, ashtray and so on. Although not as difficult as it sounds, it could take 2-3 hours to disassemble the dash and put it all back together. "
imaguy3 is offline
post #6 of 271 Old 04-16-2011, 04:22 AM Thread Starter
Thomahawk
http://www.autopartswarehouse.com/sk...gs+Best+Seller
Anybody tried this?
Buildthread
post #7 of 271 Old 04-16-2011, 04:24 AM Thread Starter
Thomahawk
Any links for buying new trim?
Buildthread
post #8 of 271 Old 04-16-2011, 07:52 AM
autojunkie
I used a satin nickel color on mine. It's looks a lot like the factory brushed without looking fake and "ricer". Just pick a color that looks clean and simple. Nothing gaudy...
The trim pieces, wood or brushed or whatever, are all thin metal wrapped over a plastic frame. The plastic frame is used for the mounting tabs.
The driver side (small) piece just uses trim clips to hold it in. Gently pop it out with a nylon pry tool.
The passenger (large) piece uses nuts to hold it in place. You have to remove the whole IP top panel to properly take it off. Don't try and cheat by pulling the aitbag cover back to reach the nuts becasue you will bend the IP top panel and it will never sit right again.
Before you paint make sure you properly prep it. You won't need to do heavy sanding, but buy some 3M scratch pads and sand it down completely with those being sure to scuff every little part you can.
Shoot them with a can of primer, let it completely dry, then lightly scuff them again with the 3M scuff pad.
Wipe them down. If you don't have a tack cloth, you can use a clean rag with a tiny bit of thinner.
After the prepping, then paint. Do a few light coats at a time witing about 30 minutes between coats. This will keep it from running on you.
I don't have pictures of mine, but it turned out very nice. Take your time and good luck
autojunkie is offline
post #9 of 271 Old 04-16-2011, 03:19 PM Thread Starter
Thomahawk
Thanks guys. I know How to Take this parts of by reading wjjeeps.com.
I also know How to prep and paint. I have bin painting a lot of Parts and Stuff for boats motorcykles and some car parts before. My friend works in a paint deliver shop and can provide me Any kind of spray paint and Any colour i Will need.
What i need to decide which colour i Will Go for is picture posted so i can see What it Looks like after mounted inside car. Any more pics? Need ideas!
Buildthread
post #10 of 271 Old 04-17-2011, 07:24 AM Thread Starter
Thomahawk
Still not sure about color, i consider Carbon film layer to put outside the trim. Easier, and maybe alot cooler.
Check out www.Carbonfiberfilm.com!
What u guys out There Think?
Buildthread
post #11 of 271 Old 04-17-2011, 12:07 PM Thread Starter
Thomahawk
I did order this **** today. Will post pics when finnished. 
Buildthread
post #12 of 271 Old 04-26-2011, 01:42 PM Thread Starter
Thomahawk
Started My Interior trim bezels project today. I use 3M Black Carbon vinyl. Turned out Really Nice i Think. Much better Than the stock wood ****! 
I Will do the rest another day, it tales some time.
Buildthread
post #13 of 271 Old 04-26-2011, 01:47 PM Thread Starter
Thomahawk
Looks like this
image-1476789953.jpg   image-2445105356.jpg   image-3047639560.jpg   image-2903010971.jpg   image-3221316625.jpg
Buildthread
post #14 of 271 Old 04-26-2011, 02:44 PM
KillaKeys17
The carbon fiber looks great! How difficult was it to wrap the edges smooth?
KillaKeys17 is offline
post #15 of 271 Old 04-26-2011, 02:54 PM
viperman96
2005 WK
Looks awesome. Think I might do this also. Did you have to heat it at all to wrap the edges?.
viperman96 is offline
