Interesting observation: elect windows - JeepForum.com
post #1 of 30 Old 08-24-2014, 10:54 PM Thread Starter
Rick14
About a year ago my '99 grand Cherokee would need the mirrors adjusted EVERY MORNING! I figured the truck was just getting old, the cables were getting worn out, etc, etc, I didn't think too much about it. But recently my Window regulator stopped working so I took off the side panel in order to inspect. After seeing the broken cable I decided to order a new regulator and figured I'd leave the door panel off until I received and installed the new part. So, after Fed-Ex lost the 1st one (long story) they send another one, meanwhile I've been without electric windows and the door panel for nearly 2 weeks now and much to my amazement the mirrors have stayed exactly in the same spot???
1. I'm glad to hear that the problem with my mirrors may not be as extensive as I originally thought but I can't for the life of me figure out what the problem could be. I know that I tried (in the past) leaving the L/R mirror selector in the R and/or middle position and that didn't seem to help. Has anyone else experienced the mysteriously moving mirror syndrome?
Rick14 is offline
post #2 of 30 Old 08-24-2014, 11:27 PM
SirSilvia
door panels off, the mirror doesn't sound like it's connected. the broken wiring probably touching itself and making the mirror move.
2002 Jeep Grand Cherokee Limited V8
SirSilvia is offline
post #3 of 30 Old 08-25-2014, 04:19 AM
86cj74.2L
86cj74.2L's Avatar
Do you have a limited with the memory buttons on the driver side door panel?
86cj74.2L is offline
post #4 of 30 Old 08-25-2014, 07:59 AM
wxmanWJ
Mine was doing this. I couldn't for the life of me figure out what the problem was. I also had a problem with my driver window needing multiple presses of the button to get it to go down or up. Then one day, all my dome lights stayed on. I did some searching and figured out it was broken wiring in the boot going from the driver door to the cabin. There is a rubber boot holding the wire harness, and power and ground wires for the driver door module (DDM) tend to wear out and break off, causing a ground or a short.
I would pull back the boot and inspect your wiring. Here's a few threads about it:
http://www.jeepforum.com/forum/f310/...ector-1306958/
http://www.jeepforum.com/forum/f13/w...s-clip-554593/
My "stocker" build thread: http://www.jeepforum.com/forum/f310/my-first-jeep-owning-adventure-1532212
wxmanWJ is offline
post #5 of 30 Old 08-25-2014, 09:33 PM Thread Starter
Rick14
I know and appreciate your views but here is the deal. They won't need adjustments all day no matter how much the car is driven, turned on and off or how many times the doors are opened and closed. When I park the car in the evening the mirrors are still good. The next morning they need to be adjusted up/and in, the same amount each morning like clockwork. That's why I thought the cable was just stretching a little every night, but that's not the case. And a short would not be so predictable, again this needs to be adjusted the same amount EACH morning???
Rick14 is offline
post #6 of 30 Old 08-25-2014, 10:19 PM
rdkendrick
2003 WJ
Are you sure you set the correct buttons? Set both buttons and see what happens. If it still does it, disable the memory function.
Sent from my iPad using Electrons
rdkendrick is offline
post #7 of 30 Old 08-25-2014, 10:27 PM Thread Starter
Rick14
Done it all a thousand times. Thought I might hear from someone who may have the same problem.
Rick14 is offline
post #8 of 30 Old 08-27-2014, 03:25 PM Thread Starter
Rick14
Anyone else having problems with their mirrors going out of adjustment each morning?
Rick14 is offline
post #9 of 30 Old 08-28-2014, 10:22 AM
SirSilvia
That's most likely the wires going through the door by the hinge with exposed copper touching each other
post #10 of 30 Old 08-29-2014, 09:26 PM Thread Starter
Rick14
I thank you for your opinion but it seems strange to me that it would be so predictable each morning. If it were a short I'd think it would be random and more likely on days I drove more and opened the door more. You can bet I'll be checking the wires and dressing them with elect tape before I put the door panel back on but I'm more inclined to think it's something like the electronic window levers or switches.(still waiting for delivery of the window regulator before i put the panels back on, supposedly FedEx lost the 1st one, Haha been over 3 weeks now )
Rick14 is offline
post #11 of 30 Old 08-30-2014, 02:30 AM
MadderThanMax
Here's how I cured mine... I changed the EVIC module (?) in the overhead console as I damaged mine trying to change to LEDs (Ham Fisted I Know.. laugh all you want ) But I ordered another and.. guess what? It stopped doing it, I can't explain why but it did.. needless to say I'm a happy bunny..
MadderThanMax is offline
post #12 of 30 Old 09-01-2014, 11:47 PM Thread Starter
Rick14
This is very strange but explains why it isn't just a random occurrence. Got my window regulator today and will be installing it tomorrow, thinking about just not hooking up the elect for the driver side window?
Rick14 is offline
post #13 of 30 Old 09-02-2014, 10:33 AM
rdkendrick
2003 WJ
Unhook your memory switches, see if that helps. I have also heard that cleaning the contacts, inside the mirror housing has helped some people.
post #14 of 30 Old 09-03-2014, 12:07 PM Thread Starter
Rick14
Door panel is back on, I'll see what it does this morning. Unhooking the memory switches may have been a good idea but cleaning the mirror housing wouldn't make sense if the mirror stays in place when the door panel is off.
Thanks for the advice though!
EDIT: I may unhook my memory switches if the problem persist, that's the best idea I've heard of yet, LOL.
Rick14 is offline
post #15 of 30 Old 09-03-2014, 01:40 PM
rdkendrick
2003 WJ
Door panel is back on, I'll see what it does this morning. Unhooking the memory switches may have been a good idea but cleaning the mirror housing wouldn't make sense if the mirror stays in place when the door panel is off. Thanks for the advice though! EDIT: I may unhook my memory switches if the problem persist, that's the best idea I've heard of yet, LOL.
I got the idea from the Chrysler Mini-van site. My wife has a Town & Country AWD, and her mirrors don't stay memorized, either. Someone there said, also, to push the mirrors in all directions to clean the contacts, but that didn't work on her van.
Also, my youngest daughter got her license this summer and has been driving my Jeep. The rear passenger window regulator cable broke, and I have the regulator, now, it's just that she has volleyball and soccer practices and games to go to, or it's raining, so I still have not gotten the chance to replace it yet, kinda like your problem.
We need to get her a car. It's a good thing that I work from home.
