interchangeable parts off other vehicles. - JeepForum.com
post #1 of 17 Old 03-10-2014, 01:45 PM Thread Starter
behappynwise
I heard Ford ranger springs work and f150 rims. Any other parts like seats off other vehicles fit?
behappynwise is offline
post #2 of 17 Old 03-10-2014, 01:54 PM
fayceoff
fayceoff's Avatar
Thought F150's were 6-lug like my Expedition...
"It's almost always cheaper to it right than it is to do it twice." - Dad
"Be polite. Be professional. But have a plan to kill everyone you meet." - Gen. James Mattis
fayceoff is offline
post #3 of 17 Old 03-10-2014, 02:09 PM Thread Starter
behappynwise
Older ones are 5 bolt I was told...
post #4 of 17 Old 03-14-2014, 01:52 PM Thread Starter
behappynwise
Any ideas guys?
post #5 of 17 Old 03-14-2014, 02:00 PM
99WJ539918
I heard the rear springs off of a F150 work and we'll give you 6" of lift. It'll ride like crap, though. A lot of runs will fit, just check the offset and spacing.
Build Thread
99WJ539918 is offline
post #6 of 17 Old 03-14-2014, 02:14 PM Thread Starter
behappynwise
I want it to drive well and don't want to lift too high as other parts are need then. Jeep is daily driver and money is minimal for extras. Trying to make it look different cheap. I also need another seat as there is a bar sticking in my back
post #7 of 17 Old 03-14-2014, 03:17 PM
pinky2252s
Every ranger Ive worked on has had 6 lugs. Not going to work. Nothing about lifting a WJ is going to be cheap, besides 2 inch pucks..
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #8 of 17 Old 03-14-2014, 03:21 PM
ChrisHager
Administrator
ChrisHager's Avatar
http://www.jeepforum.com/forum/f310/...es-wj-1410777/
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #9 of 17 Old 03-14-2014, 03:43 PM Thread Starter
behappynwise
Don't want to lift jeep as I bought new shock already and can't afford to have to get longer ones. May go with the pucks
post #10 of 17 Old 03-14-2014, 03:54 PM Thread Starter
behappynwise
I want to get 4 springs all round or pucks. Any ideas where is cheapest ? I'm in Canada.
post #11 of 17 Old 03-14-2014, 04:00 PM Thread Starter
behappynwise
I also have a rubber sqweek sound when I hit a dip. Was thinking it may be the spring isolators as the sound is high up and my mechanic says everything's tight. Money's tight so was possibly thinking used springs and iso if I can find them. Your thoughts?
post #12 of 17 Old 03-14-2014, 04:32 PM
the88thpianoman
2003 WJ
For a bare bones 4" lift, with all the cheapest options and only what you absolutely need, budget at minimum $1000 for the springs, cheap shocks, adjustable track bar, front control arms, sway bar links, and A-arm spacer, assuming you can find most of those parts used. Unless you already have a double cardon u-joint front drive shaft, budget another $100 for a used drive shaft or $300 for a new one. Of course to deal with the death wobble that you'll have at 4" of lift on short arms, you'll need to budget another few hundred bucks to replace the steering stabilizer, any worn tie rod ends or the front control arm bushings located in the front axle (and these items will be heavily worn if they are original), and at least one alignment to get it resembling driveable. And, if you want to actually lift it the right way (still the "cheap" way), budget another $400 to replace the rear lower control arms and rear sway bar, and while you've got the springs out, it only makes sense to replace the isolators, so budget another $120 for all eight of those.
This doesn't even mention long arm kits, but you're probably getting the point that you cannot lift a WJ cheaply. Even with 2" pucks, you're going to very quickly blow out the stock length shocks in the front (rears will be fine), and you'll want to replace those because it's going to ride like crap at that point. Look for used 2" springs or pucks. Do not under any circumstances buy or use pucks that are more than 2.5" in height. They are unsafe, period. Buy the best front shocks you can afford for the better ride quality, but at least get them in the right length or it's going to ride like crap.
There is no point in putting in used isolators, you might as well just leave yours in there.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #13 of 17 Old 03-14-2014, 04:37 PM Thread Starter
behappynwise
Thanks
post #14 of 17 Old 03-14-2014, 04:40 PM Thread Starter
behappynwise
I already put 4 new shocks on it . Just wanting to maintain and drive. Keeping mostly stock as that's the best cost efficient way to go.
post #15 of 17 Old 03-14-2014, 04:44 PM Thread Starter
behappynwise
I also put new rotors and pads all round.
