Int. lights won't shut off & windows don't work. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Int. lights won't shut off & windows don't work.
Genright at JeepHutMemorial Day Weekend Sale Starts Friday-Tuesday 10% off + New DEAL OF THE WEEK at ROCKRIDGE 4WD!
Unread 06-01-2012, 08:11 AM   #1
Roodawg
My interior lights suddenly started staying on and door locks and windows stopped working. Any suggestios?
Thanks!
Roodawg is offline   Reply With Quote
Unread 06-01-2012, 08:18 AM   #2
the88thpianoman
the88thpianoman's Avatar
2003 WJ
It's a broken ground wire in the boot going to the driver's door.
WJ front drive shaft and fuse panel for sale
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here: Life lessons and budget build
the88thpianoman is offline   Reply With Quote
Unread 06-01-2012, 08:22 AM   #3
pyrrhus00
2004 WJ Overland
pyrrhus00 is offline   Reply With Quote
Unread 06-01-2012, 09:22 AM   #4
Bake1tEazy
Junior Member
Bake1tEazy's Avatar
copy/paste?
Bake1tEazy is offline   Reply With Quote
Unread 06-01-2012, 09:54 AM   #5
pyrrhus00
Originally Posted by Bake1tEazy View Post
copy/paste?
retyped like a bawss :-P
2004 WJ Overland
Unread 06-01-2012, 10:45 AM   #6
Bake1tEazy
Junior Member
Bake1tEazy's Avatar
Unread 06-01-2012, 10:50 AM   #7
GoreD
I fixed mine about a month ago. Though it was tricky to do, there is a plug there that you can unplug and it helps to pull the broken wire right out and solder in a new one.
Also was not fun driving my wife to the hospital at night with the interior lights on while she was in labour, so I recommend fixing it sooner rather than later.
GoreD is offline   Reply With Quote
Unread 06-01-2012, 05:52 PM   #8
the88thpianoman
2003 WJ
If you adjust the dimmer switch that controls the instrument cluster brightness all the way down, it will force off the interior lights, even with the broken wire or with a door open.
Unread 06-01-2012, 07:56 PM   #9
Kaoz78
@OP, any problems with the rear hatch also? My problem is similar, but I also cannot open the hatch or rear glass.
Kaoz78 is offline   Reply With Quote
Unread 06-01-2012, 11:03 PM   #10
the88thpianoman
2003 WJ
The locks in the hatch are electronically controlled, and will not function without the wiring being intact to the driver door switch (possibly the passenger switch as well). There is a small square cover in the plastic of the hatch that is removable to access a manual lock so you can unlock the hatch without functioning power locks. I don't know offhand if that also sets the glass in the unlock position as well.
Unread 06-02-2012, 08:54 AM   #11
piraterig
same prob i have just happen yesterday, i knew it would after reading the wj issues, so off i go to fight the door boots!
04 WJ stock, saving funds for mods
95 ZJ 30x9.50s kumho at
96 XJ sport with stuff, sold
piraterig is offline   Reply With Quote
Unread 06-02-2012, 09:02 AM   #12
homer8613
Search!!!!!!!!!!!!!!
/thread
96 zj stock 293k -sold
02 wj tires, lights 80k-sold
99 wj 4.6 stroker,iro lift, 265's, and some other crap. 210k-sold
98 zj 5.9 stock for now... 218k
homer8613 is offline   Reply With Quote
Unread 06-02-2012, 09:47 AM   #13
piraterig
Wj
op search? if so yes! search ftw!!!
/thread
i have fixed my drivers before, now it was the passener side.
pics appears that someone had repaired it once before.
unplug to help with short wires and makes it easier to crimp
very simple!!! all fixed.... heres some pics to assist you or anyone else. im sure theres tons of pics and threads of the fix, but sometimes the search bar is "invisible"
Unread 06-04-2012, 05:25 AM   #14
MadderThanMax
Don't Crrimp - SOLDER!! Makes for far better joint..
Looks like it was the same guy that was in at mine
I took the plug out like you said and ordered new wire to the exact colours, clipped the wire off the plug and made up new tails, shrink wrapping the joints as I went, then I found some amazing waterpoof insulation tape on Flea bay and it made the new loom look the Mutts Nuts, and removed the kick panel inside the drivers door and soldered in the new loom there, far better solution and still working so far... touch wood Lols!
P.S Thanks to 4Tom for his help on this..
MadderThanMax is offline   Reply With Quote
Unread 06-04-2012, 08:22 AM   #15
ultimo
Some Jeeps came with optional voice command for lights and doors. Look for a mike in the front.
ultimo is offline   Reply With Quote
