instrument cluster removal? - JeepForum.com
post #1 of 8 Old 03-14-2014, 07:15 AM Thread Starter
snorander
The bulb by my temp & oil gauge is burnt out. How do I get the instrument cluster out? I tried using the search feature, but couldn't find anything. 2001 Grand Cherokee limited.
Thanks!
snorander is offline
post #2 of 8 Old 03-14-2014, 07:42 AM
2000_limited
One of the easiest of any vehicle I have ever owned.
Look under the lip of the top of the cluster there are 2 screws.
Now grab the trim around the bottom part right above the steering column. and gently pull, it only snaps in place. There are then 2 screws behind it.
Gently pull the cluster out and unplug the one and only plug.
http://www.wjjeeps.com/gauges.htm#REMOVAL
2000_limited is offline
post #3 of 8 Old 03-14-2014, 08:03 AM Thread Starter
snorander
Thanks! DO you know what bulbs it takes?
post #4 of 8 Old 03-14-2014, 08:53 AM
rdkendrick
2003 WJ
Pc74's http://www.wjjeeps.com/lamps/lamps.htm
Sent from my iPad using electrons
rdkendrick is offline
post #5 of 8 Old 03-14-2014, 09:00 AM Thread Starter
snorander
Thanks!
PC74's are for the warning lights right? SO I want #103's for the back light I think
post #6 of 8 Old 03-14-2014, 09:35 AM
rdkendrick
2003 WJ
Thanks! PC74's are for the warning lights right? SO I want #103's for the back light I think
I think that's how it works. I have always had the white-faced, electroluminescent gauge clusters, so I have never messed with the other gauges. Check out this thread if you want to switch to LED: http://www.jeepforum.com/forum/f310/.../#post19503049
post #7 of 8 Old 03-14-2014, 10:37 AM Thread Starter
snorander
Hmmm just got back from the auto parts store & they did have any 103 bulbs....not even an empty spot on the shelf where they would go....
EDIT: a little further research tell me the 103 bulb is a special bulb for Chrystler and any 74 will work
post #8 of 8 Old 03-14-2014, 03:59 PM
2000_limited
Get some LED replacements, will be a few bucks more but worth it in the long run. It's my next project.
