Installing a lift...on a lift? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Installing a lift...on a lift?
Savvy Billet LED Tail LightsWant to be able to SEE? DOT Approved Headlights for under We have FLASHLIGHTS! Great for your Emergency bag!
Unread 12-10-2014, 06:28 PM   #1
BumpinWJ
I have access to a hydraulic lift that a buddy lets me use when I need to work on my jeep. I want to put in a budget boost with new shocks and bushings, and I'd rather do it with the jeep in the air than on the ground. A lot of the lift write ups show the axles being supported while removing sway bars and shocks and such, would that still be necessary? I think I could use a really large jack stands if I need to, but do I need to?
BumpinWJ is offline   Reply With Quote Quick reply to this message
Unread 12-10-2014, 09:02 PM   #2
DKern
I just installed my 3" IRO kit and CA's, supported from the frame, and let the axles just droop. Remember to tighten all bushings at ride height and you should be good to go. Watch the brake lines, especially the front, just in case.
DKern is offline   Reply With Quote Quick reply to this message
Unread 12-11-2014, 10:02 AM   #3
Merc1973
Use the lift! You will still need to loosen all control arm bolts, remove sway bar links, remove and replace shocks.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline   Reply With Quote Quick reply to this message
Unread 12-11-2014, 11:13 AM   #4
ezflip
NEWS FLASH It snows in MI
ezflip's Avatar
You should not have to do any of that to install a BB. Remove the upper shock bolts with it on the ground, then raise it with the lift. The axles will droop far enough for you to slide the pucks in place. Ive installed 4" coils without a lift and without spring compressors. So a BB should be no problem at all.
~James
2002 Overland - 4.7 HO, "Select-Drive", 4" RC long arms, TAG front winch bumper, 32" BFG KM's, Kolak 3" exhaust, Flowmaster 50 series
Build Thread
WJ
HOLIDAY THEMED GIVEAWAY!
Grand Cherokee General Discussion Holiday Giveaway
ezflip is offline   Reply With Quote Quick reply to this message
Unread 12-11-2014, 12:00 PM   #5
corpulent
Might be wise to support it, so the axle doesn't drop too quickly or further than you want.
Good advice.
Also sound advice.
corpulent is offline   Reply With Quote Quick reply to this message
