Installing lift kit at home?? - Page 2 - JeepForum.com
post #16 of 33 Old 05-22-2013, 08:24 AM
ChrisHager
Administrator
ChrisHager's Avatar
$160 from their site: http://jksmfg.com/i-8952506-grand-ch...-trackbar.html
Kolak sells them as well most likely at a cheaper price.
You may consider upgrading the bushings from KOR for $60 while you're at it: http://www.kevinsoffroad.com/cart/ha...r-track-p-290/
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #17 of 33 Old 05-22-2013, 08:24 AM
adavis39
Originally Posted by aestrad1 View Post
Nope. Your steering and track bar need to stay in relation. The drop bracket lets you use the stock bar. Drop bracket NEEDS the drop pitan arm. This is a band aid and the cheap (and incorrect) way to fix the problem.
With and adjustable track bar (and no drop bracket) you use the stock pitman arm. Ths is the correct way to do it.
yep....spend the little bit extra and do it right. buy a JKS adjustable trac bar and throw in some KOR bushings (the JKS one suk)
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #18 of 33 Old 05-22-2013, 09:04 AM
PhantomWJ
2003 WJ
Originally Posted by Laredo2003WJ View Post
****. I dont think this kit came with the adjustable trac bar
I know it didnt. He needs it. The stock trac bar will shift axle to one side, driver side. Thats why RC supplied the trac bar bracket but if he aint gonna use, he needs an adjustable.
PhantomWJ is online now
post #19 of 33 Old 05-22-2013, 09:24 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Your choice of kits and additional necessary parts aside, you can install it at home with no special tools. If you dont want to use spring compressors, unbolt the sway bar endlinks and lower control arms before you install the springs. That will give you plenty of room to install the springs.
I installed the x-series kit on my last WJ by myself in about 9 hours. Should be even faster if you have a helper.
~James
ezflip is offline
post #20 of 33 Old 05-22-2013, 09:32 AM Thread Starter
Laredo2003WJ
2003 WJ
Just picked up a heavy duty Zone Off Road at my cost for 115! Thanks for all your help guys! Anything else.you can think off besides this that ill need?
Laredo2003WJ is offline
post #21 of 33 Old 05-22-2013, 09:37 AM
Jeeples
Jeeples's Avatar
Glad you got it figured out. I was gonna offer you my old IRO fixed TB for 3"-4" in case you weren't able to find something.
As for other items needed, I didn't see anyone mention a torque wrench, assuming you don't already have one.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #22 of 33 Old 05-22-2013, 09:46 AM Thread Starter
Laredo2003WJ
2003 WJ
Have one of those! Man you guys really rock on here! Always help and no one talks smack! I love it!
post #23 of 33 Old 05-22-2013, 10:20 AM
brouwmat
One thing they didn't tell me in my kit was that I would need pretty much every size of both wrenches and deep sockets. You might also want to consider changing out that rear upper ball joint as well. You will have it 90% off anyway during your install. Those rear bolts on top of the rear differential about brought me to tears getting them out. I didn't want to have to take that apart again - you probably won't either.
brouwmat is offline
post #24 of 33 Old 05-22-2013, 10:25 AM Thread Starter
Laredo2003WJ
2003 WJ
Good to know. Ill look into the rear upper ball joint replacement as well!
post #25 of 33 Old 05-22-2013, 10:50 AM
jpat30
"Your choice of kits and additional necessary parts aside, you can install it at home with no special tools. If you dont want to use spring compressors, unbolt the sway bar endlinks and lower control arms before you install the springs. That will give you plenty of room to install the springs. "
As stated you will not need a spring compressor. I installed my OME HD lift this past weekend without one and it was easy. In the rear, just unbolt the sway bar brackets from the axle leaving the links attached. The bar will dangle out of the way. Then jack up the rear end place jack stands under the frame rails. Unbolt the shocks from the axle-you can leave them bolted uptop unless you are replacing them too. Let the axle droop and the springs will almost fall out. Getting them back in, you may need to jack up one side of the axle to provide you with a little more droop on the other side. I then ended up having a buddy stand on one end as well to get just a hair more room to get the longer springs in. Take your time and you will be fine. Good Luck.
-Carpe Diem Phil 1:20
jpat30 is offline
post #26 of 33 Old 05-22-2013, 12:04 PM
its-me-B
i choose to rent a strut comperssor when i did mine... helped alot cuz i was doing it by myself want to get it done quickly. but i got mine installed in around 8 hours on my own, but i did have a fork truck to help lift the truck for my jack stands.
Do the world a favor, hurt a honda...
Iro 3" lift with pro comp 9000es shocks, adjustable trackbar, led rock lights, all interior lights converted to leds, two 10" kicker comp with Kenwood 600 watt amp
Zombie Outbreak Response Unit #396
its-me-B is offline
post #27 of 33 Old 05-22-2013, 02:48 PM
brouwmat
You will want the strut compressor.. More than likely you will then get the question "I didn't think that the WJ had struts, does it?" At that they are correct but the standard spring compressor goes in the middle of the spring and worked well for removing them. However, the RC springs have pretty tight coils and I could not get the tool out of the middle after I got them in place. The strut compressor goes on either side of the spring so that is not an issue. Additionally, i think that the OME HD springs are technically for a 3" lift.. You have 4" there and I don't think I could have installed my RC X-Series lift without them. I didn't try but I know I had to compress them quite a bit to get them in there with the axle drooping.
I don't know where you live but I would take a look at those spring perches too while you are in there. Mine on the drivers side fell apart when I pulled off the boot.
brouwmat is offline
post #28 of 33 Old 05-22-2013, 07:01 PM
its-me-B
I don't know where you live but it would take a look at those spring perches too while you are in there. Mine on the drivers side fell apart when I pulled off the boot.
exactly what what he said... I had had both spring and strut compressors but used the strut one because the spring compressor just had no chance of fitting inside the spring, stock or iro springs
its-me-B is offline
post #29 of 33 Old 05-22-2013, 07:06 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
You guys just weren't doing it right 4" springs are SOO much easier and faster without compressors. I didn't have a fork lift and I finished mine is the same amount of time as its-me-B. All you have to do in most cases is disconnect the sway bar. If you need more droop than that, unbolt the lower control arms. Plenty of room. I literally had a hard time keeping the springs in while I bolted everything back up. Had to put my jack under the axle and jack it up to keep the springs from falling back out.
If I would have had a forklift, I could have done entire install by myself in about 6 hours.
~James
ezflip is offline
post #30 of 33 Old 05-23-2013, 07:15 AM
ChrisHager
Administrator
ChrisHager's Avatar
I agree with ezflip. If you set the 'frame' high up on jack stands, unbolt the the sway bar end links and shocks, and use a small floor jack under each side of the axle when working on the opposite side, you should have no problems at all...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
