Installing lift kit at home?? - JeepForum.com
post #1 of 33 Old 05-22-2013, 07:27 AM Thread Starter
Laredo2003WJ
2003 WJ
Question Installing lift kit at home??
I purchased the 4 inch rough country lift. Not the x series just the basic kit, and im wondering how hard its going to be to install In my garage with one buddy to help me?? I have all power tools but no spring compressor or fancy things..
Laredo2003WJ is offline
post #2 of 33 Old 05-22-2013, 07:35 AM
perfeng702
I did my IRO long arm lift at home with all hand tools. I didn't have to use a spring compressor up front, but I did in the rear. They can be rented at most auto parts stores. I also have a pretty big floor jack to help get the truck in the air. You shouldn't have much trouble.
1999 WJ 4.7, 242HD, IRO 4" Long Arm, IRO Adj Track Bar, JKS BPE, JKS Quick Disco, 15" Cragar D-Window, 32" BFG KM2, V3 Projectors, DDM Tuning 55w 5k HIDs
perfeng702 is offline
post #3 of 33 Old 05-22-2013, 07:40 AM Thread Starter
Laredo2003WJ
2003 WJ
Damn thats badass. What about a pitman arm puller?
post #4 of 33 Old 05-22-2013, 07:47 AM
adavis39
you dont need it because your first step should be throwing the drop pitman that comes in the kit in the trash
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #5 of 33 Old 05-22-2013, 07:52 AM Thread Starter
Laredo2003WJ
2003 WJ
Haha really?! How come?
post #6 of 33 Old 05-22-2013, 08:04 AM
adavis39
dropping your trac bar and drag link arent needed at 4''. and the drop pitman will only add unnecessary strain on your steering box
TNJEEPS.COM
BUILD:
adavis39 is offline
post #7 of 33 Old 05-22-2013, 08:27 AM
aestrad1
Agreed. Ditch the drop pitman arm and the track bar drop bracket. Its asking for trouble.
You can do it at home just give yourself lots of time and have another vehicle so you can get parts you may need. Make sure you have a good jack and stands as you will need to get the WJ up high to droop everything out. I use wood blocks along with my jack. Also be sure to get some really good rachet straps to help get the axles in place.
Also AutoZone will rent you spring compressors for free
aestrad1 is offline
post #8 of 33 Old 05-22-2013, 08:44 AM Thread Starter
Laredo2003WJ
2003 WJ
Nice! What would I do without you guys! So the pitman arm in it will reach fine and also the track bar? No issues?
post #9 of 33 Old 05-22-2013, 08:52 AM
PhantomWJ
2003 WJ
Make sure you have an adjustable trac bar....and yes no drop pitman arm drop kit for trac bar
PhantomWJ is offline
post #10 of 33 Old 05-22-2013, 08:58 AM Thread Starter
Laredo2003WJ
2003 WJ
****. I dont think this kit came with the adjustable trac bar
post #11 of 33 Old 05-22-2013, 09:02 AM
aestrad1
Nope, you need the X-series kit to get the track bar See if you can exchange it maybe
aestrad1 is offline
post #12 of 33 Old 05-22-2013, 09:07 AM Thread Starter
Laredo2003WJ
2003 WJ
So can I still use the stock pitman arm without an adjustable trac bar?
post #13 of 33 Old 05-22-2013, 09:12 AM
aestrad1
Nope. Your steering and track bar need to stay in relation. The drop bracket lets you use the stock bar. Drop bracket NEEDS the drop pitan arm. This is a band aid and the cheap (and incorrect) way to fix the problem.
With and adjustable track bar (and no drop bracket) you use the stock pitman arm. Ths is the correct way to do it.
aestrad1 is offline
post #14 of 33 Old 05-22-2013, 09:17 AM Thread Starter
Laredo2003WJ
2003 WJ
I wonder how much just an adjustable trac bar will be
post #15 of 33 Old 05-22-2013, 09:23 AM
aestrad1
$140 for the JKS. Just installed the JKS a few weeks ago in my WJ
aestrad1 is offline
