installing infinity reference 3023cf speakers, but I have questions - JeepForum.com
post #1 of 11 Old 07-16-2013, 08:22 PM Thread Starter
ZJPunk98
Hi Guys,
I just purchased these infinity reference 3032cf speakers after reading several threads on here about how great they sound and so on.
I realize there is a bit of cutting involved, ok that is fine. After reading more about these speakers with an impedance of 2 ohms, I am concerned about the infinity gold system in my 02 overland that is 4 ohms.
Should I return these for another set of speakers that are 4 ohms, place a resistor before the speaker to increase the impedance, or just go with the speakers as is?
I know the amp can run warmer with a lower impedance speaker. What other concerns should I have?
I am really looking forward to some tech help with this decision making process. Thank
edit: I placed the wrong model number on the title: I have 3032cf
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline
post #2 of 11 Old 07-17-2013, 03:19 AM
Thomahawk
No, you will be Good, the factory speakers Are not 4ohm btw, more pics of install in my buildt thread, they sound Way better, Good luck
Buildthread
Thomahawk is offline
post #3 of 11 Old 07-17-2013, 07:16 AM Thread Starter
ZJPunk98
Thank you for the input. I based my info on the website wjjeeps, which states that these systems are 4 ohms.
Erik
ZJPunk98 is offline
post #4 of 11 Old 07-17-2013, 09:16 AM
Jeeples
Jeeples's Avatar
I installed some Reference Series speakers in the front and rear doors of my wife's WJ a couple months ago, and they sound great. I too was concerned about the conflicting info on the impedance (WJJeeps vs. JeepForum), but haven't had any issues with them. Installation was really straight forward and the adapter rings meant I didn't have to cut up or drill new holes into the door panels.
I made sure to get two way speakers for front and rear, but Amazon goofed and shipped me three ways for the front door, which took away a lot of the 'depth' the front speakers provided.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #5 of 11 Old 07-17-2013, 09:42 AM
Merc1973
no resistors needed, read my email...
THey are 4 Ohm
http://www.crutchfield.com/S-ZdFXzs7...ml#details-tab
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #6 of 11 Old 07-18-2013, 07:22 AM Thread Starter
ZJPunk98
True Four Ohm Impedance technology: speaker's 2-ohm impedance combines with speaker wire impedance for a 4-ohm load
just noticed this on the crutchfield site. Thank you Merc. I did get the email as well.
Just reading the impedance on the speaker is what concerned me. I did not realize the accounted for the speaker wire impedance. No concerns now.
Erik
ZJPunk98 is offline
post #7 of 11 Old 07-19-2013, 01:50 PM
Merc1973
Gotcha, let me know if you have any questions or you want to see a pic of my installation.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #8 of 11 Old 11-18-2014, 10:14 AM
WCM3
Following up on this..what did the OP do to help with sound?
I had to do the same with making the oem hole a little bigger. After installing these up front, they are very quiet. Install an amplifier?
WCM3 is offline
post #9 of 11 Old 11-19-2014, 07:18 PM Thread Starter
ZJPunk98
Mine produce excellent sound. did you reverse a wire?
Erik
ZJPunk98 is offline
post #10 of 11 Old 11-20-2014, 07:09 AM
WCM3
I think my issue is I bought the wrong Ohm speakers. Mine are 2 Ohm and the stock are 4 Ohm. I'm just going to return them and buy 4 Ohm. That's easier than wiring up another amp. Thanks!
WCM3 is offline
post #11 of 11 Old 11-20-2014, 08:11 PM Thread Starter
ZJPunk98
did you read this entire thread? the 2 vs 4 ohm issue is addressed in the thread. I am unaware of a 4 ohm version.
Erik
ZJPunk98 is offline
