install Ford Injectors in your jeep. - JeepForum.com
post #1 of 12 Old 03-02-2012, 05:27 PM Thread Starter
wvracer821
Wj install Ford Injectors in your jeep.
i picked up a set of bosch single hole injectors from ebay. motorcraft part number CM4956 they are from a 2000 ford mustang with the 3.8L V6
these are not the 4 hole injector that came in the dodge neon but they still have a mist pattern rather than the stream from the factory injector.
here is my write up on the install.
remove air cleaner
remove cable linkage bracket from intake and disconnect from throttle body.
also remove the breather line that goes to the valve cover
heres a picture of the rail after i removed it
Dirty hole.....ill fix this
take one ford 302 pushrod
equip dremel tool with cutting wheel.
cut slot in the end of the pushrod
insert small piece of sand paper folded in half
drill with pushrod in the chuck
this is used as a simple hone to clean up the holes while not creating groves in them.
the best way to do this is to put a blowgun in one of the injector holes that you are not working in and blow air through the intake while you run the drill and clean up the holes this will create positive pressure in the intake to blow out any particles that might make their way into the holes
here is the hole cleaned up
comparison
comparison
the only flaw that i can see in this is that you cant use the factory clips that go over the injector to hold it to the fuel rail.
new injector o rings all lubed up
jeep rail full of mustang injectors
reassembly went very smooth and after some fuel rail priming the beast fired right up seems to be running smooth but i will have to report back on this after i drive it a bit. hope this helps anybody that needs it.
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
post #2 of 12 Old 03-02-2012, 05:49 PM
chrism1367
2003 WJ
Just curious why would you want to do this? More power? Fuel economy?
chrism1367 is offline
post #3 of 12 Old 03-02-2012, 06:35 PM
MEinSoCal
cost for all 6 injectors?
MEinSoCal is offline
post #4 of 12 Old 03-03-2012, 09:32 AM Thread Starter
wvracer821
120$ shipped.
they are supposed to be a better design ive read both cases where nothing different happens and they think it is a waste and also some people have reported better response and better mpg. mine seems to be running smoother at idle.
Junk: 2000 WJ, 4.0L
Build Thread:
post #5 of 12 Old 03-03-2012, 10:13 AM
FrankU
By all mean's document and report back.
04 WJ 4.0, OME Kolak 3" lift, Addco's F&R ,18" JK Sahara's
FrankU is offline
post #6 of 12 Old 03-03-2012, 07:17 PM
77nomad
FWIW I have a Holley Stealth Ram on a SBC it uses FoMoCo injectors and a Dodge IAC it was a hard pill to swallow.
77nomad is offline
post #7 of 12 Old 03-04-2012, 06:49 PM Thread Starter
wvracer821
the injectors seem to be fine. jeep has much better throttle response and seems to be running smoother and more consistent. but this could be a result of just having new injectors rather than ford injectors. will report back in a couple days with any benefits in mileage
Junk: 2000 WJ, 4.0L
Build Thread:
post #8 of 12 Old 03-10-2012, 06:10 PM
FrankU
What's the verdict ?
FrankU is offline
post #9 of 12 Old 03-10-2012, 07:18 PM
86cj74.2L
86cj74.2L's Avatar
I don't know when it happened but most manufactures went to closed valve injection cycle instead of a open intake valve injection cycle.
In closed injection cycle most all the gas is vaporized before the valve opens up. That may be why some noticed a change and some didn't. I think in closed valve cycle it only matters on how fine the spray pattern is during warm up.
86cj74.2L is offline
post #10 of 12 Old 03-18-2012, 10:06 AM Thread Starter
wvracer821
after having the injectors in for a while i have some improvement in economy. i drive in the same patterns every week and fill up at the same station all the time. my driving consists of everything from gravel roads to winding country road, city driving, and highway. the over head display has shown 12.6 average mpg for about 4 months now since the last time it got reset. it now reads 12.9 average mpg. driving pattern has not changed although i did fix an exhaust leak.
this improvement could be due to the injectors being NEW rather than being a different design but who knows?. i am happy with them and i feel that if you are in need of a new set then this is a good alternative to OEM.
Junk: 2000 WJ, 4.0L
Build Thread:
post #11 of 12 Old 08-21-2015, 11:19 PM
Konoc
I have heard something about 4nozzle injectors from a Taurus helping to quiet valvetrain noise and smooth out the idle. with fuel economy boosts also.
Very thankful for your write-up and results! Thank you!
I will be looking into this further and giving it a shot!
r.
Konoc is offline
post #12 of 12 Old 08-22-2015, 01:17 AM
alfaitalia
The evic will not be showing an accurate figure as it's set to work with factory injectors. It does not "know" the flow rate of your new injectors. It works out mpg based on injector duration. If your new injectors inject more fuel in the same duration than your old ones your evic will show better mpg even though it might be worse. Tank top to tank top calculations by hand are the only way to know.
My CRD had a turning box that changed injector pressure and duration. The evic showed 5-6 mpg better.....reality was about 1.5 worse!
Sent from the Dark Side (of the Pond) using only the Force.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is online now
ford injector , wj
Injectors 4.0 jakj WJ Grand Cherokee Forum 3 11-29-2011 08:47 AM
99 WJ injectors Giwill WJ Grand Cherokee Forum 0 09-19-2011 09:51 PM
Bad injectors, ticking? circa27 WJ Grand Cherokee Forum 26 08-18-2011 05:44 PM
Injectors narnwv WJ Grand Cherokee Forum 17 05-31-2011 10:58 AM
