Install of Bilstein shocks and OME half inch spacers - Page 2 - JeepForum.com
post #16 of 18 Old 06-09-2013, 07:33 PM
CLUBSFIT
2003 WJ
I have 3 3/4" on stock arms, and rides fine. Only issue is not as much caster as I would like, but nothing real noticeable. I have the Fox (BDS) shocks, and have zero clunks, and they fit perfect. I am running the JKS bar pin eliminators in the front only.
03 limited 4.7 H.0., Superchips, TM wire snip mod, K&N drop in with custom intake box. 265/70/17 TKO's
BDS 4" coils, KOR .75 rear spacers, Fox shocks, BDS adj LCA's, A-arm spacer, adj.track bar, quick disc. front links, extended rear links, dual SS, Addco rear sway bar.
CLUBSFIT is offline
post #17 of 18 Old 06-09-2013, 08:22 PM
Terminal
Hey, I was wondering, can you take a side picture of your front drive shaft where it connects to the transfer case? I want see how bad that angle is. I'm wanting to lift mine, too, but there are a lot factors I'm concerned with.
Also, a side snapshot view of your jeep using the camera centered with the rear axle so you can still see the quarter panel. I want to see how bad your axles are off with stock control arms.
Terminal is offline
post #18 of 18 Old 06-10-2013, 01:59 AM
ADragg
2003 WJ
Talk to Kolak (his name is Nick). He is the Guru of the WJ and he is who sells a LOT of satisfied people on this forum their lifts (among many other things). Satisfied not only by the price but also because he will talk with you about any concerns you have and help you through it all. He will also work with you to get you the best possible setup within your budget.
If you get a good adjustable track bar (JKS) and extended rear sway bar links, you'll be fine up to 4 inches of lift. Basically what he told me was that 4" is where it practically drops off like a cliff, meaning you're fine up to that point, but anything higher will pretty much require other components (especially adjustable control arms and rear a-arm spacer) to avoid death wobble and bad wear on components.
Of course, any amount of lift will cause some increased wear on stock components and shorted their life to some degree (you'll probably have to replace things like tie rod ends, ball joints, certain bushings, etc, a little sooner) but you shouldn't have much issue under 4", other than the lift sooner wearing out components that were already on their last legs. One issue is the front drive shaft, though. Depending on the type you have, if may wear. I don't think it is usually much of an issue until you get to 4"+, but you may need to sooner upgrade or replace if you have a double cardan CV shaft.
Really, just talk to Kolak. He will answer any questions you have an will most likely put your mind at ease if you want to go with a 3 or 3.5" lift and let you know what you'll need for a 4"+ lift.
ADragg is offline
