inside door trim panel - JeepForum.com
post #1 of 5 Old 06-20-2013, 01:07 PM Thread Starter
cnovotny
Wj inside door trim panel
I have the drivers side speaker grill within the door panel broken in. Should I buy a used (entire) door trim panel or a pair of speakers with after market grills?
And how easy is it to de-install and install a door trim panel?
Thanks.
cnovotny is offline
post #2 of 5 Old 06-20-2013, 08:27 PM
vmo23
Broken in? Remove the trim panel and see if you can just pop it out. Removing the door panel takes about 2 minutes.
http://www.wjjeeps.com/doors/doorpanel.htm
vmo23 is offline
post #3 of 5 Old 06-20-2013, 09:06 PM
pyre24
i think vehicle should have the option for aftermarket grill. stock ones are just blah. i love the spider ones.
pyre24 is offline
post #4 of 5 Old 06-20-2013, 10:20 PM
DakMan96
It's so easy to take the door panel off I have it down to a science. Research it on here, be sure to buy door clips
DakMan96 is offline
post #5 of 5 Old 06-21-2013, 03:19 AM
cykaaro
Pick one up from a local wreckers that matches yours, and switch them out. They like to use plastic tabs then melting them to put them together. Easier to do the panel than try to fix. I typically can get the whole complete panel, switches and all for $20. And yes, depending on what type of door clips you have, they can break. Mine are all the one piece kind. Never been an issue for me breaking.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
