Input Needed - I'm writing a Winter Weather 101 thread. - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Input Needed - I'm writing a Winter Weather 101 thread.
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 10-26-2012, 08:01 AM   #31
ChrisHager
ChrisHager's Avatar
On the list! I've used kitty litter as ice grip and oil dry for years. A friend of mine thought I was joking when I had my wife pick up a couple of the cheapest bags of kitty litter she could find for the garage. He was shocked to see how well it worked, yet still gave me crap for not buying 'real' oil dry.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 10-26-2012, 08:51 AM   #32
ZB_WJ
Oil Dry = Most expensive cat litter on the planet
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline   Reply With Quote Quick reply to this message
Unread 10-26-2012, 11:02 AM   #33
funkduck
2015 KL Cherokee
The most recent build in my garage is sponsored by Special Kitty Racing Litter
funkduck is offline   Reply With Quote Quick reply to this message
Unread 10-28-2012, 05:16 PM   #34
billzcat1
Chicken in a Turkey Suit
2003 WJ
So where's the thread already?
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 10-29-2012, 08:18 AM   #35
ChrisHager
ChrisHager's Avatar
Hey now! Some of us are busy folks!
I have most of it complied in regards to adding this information to my list. I have a few more things I want to research but hope to get it out this week. I do feel bad that it's been so long since I started this thread!
Hang tight fellas! I'm hurrying (trying to beat the snow)!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 10-31-2012, 12:17 AM   #36
Akjeep92
haha well too late for us folks in Alaska. Its here already.
Back on topic though, just my two cents:
-no matter how big your tires, how high your lift is, or 4x4, it wont help braking. Ive seen countless Giant lifted trucks stuck in the snow banks; usually first ones to see there.
-Think always of worst case scenerio-keep food, med kit, tool kit, warmth, clothing, tow straps, jumper cables, BOTTLE OF WASHER FLUID (best idea ever), anything and everything that might be needed in emergency.
-Someone said earlier about changing oil (if time comes) to thinner in winter. Ive always gone to a thinner oil, especially when it gets down to 30 below, it helps the engine get going for sure.
-cat litter, sandbags, gravel, or even chains can help give you traction in times of need. I carry a large chain "borrowed" from work in my wj in winter. Tossing it under the wheels help get some traction going.
-When coming to a stop, like someone said earlier, I like to shift into Neutral. Stops the drive train forward pull.
-Lastly, here in AK at least, many folks put a piece of cardboard or something similar in front of the radiator. Dont cover it completely, but partially so the engine heats up better and keeps at good temps. Negative temps tend to keep the temp lower than wanted.
Cant think of much else, cant wait to see the final outcome.
2000 Jeep Grand Cherokee 4.0, 100,000 miles. More coming soon!
Akjeep92 is offline   Reply With Quote Quick reply to this message
Unread 10-31-2012, 09:16 AM   #37
ChrisHager
ChrisHager's Avatar
Good stuff.
I think I have it all together. I want to proofread it a few times (going to make my brothers look over it as well since I've been looking at it so much) then post it up. Should have it up this afternoon! :fingerscrossed:
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 10-31-2012, 09:27 AM   #38
Thomahawk
Thomahawk's Avatar
Got some winter related Stuff done to the Jeep today,
Bought:
Jumper cables,
Tow strap 4 ton,
"emergency" washer fluid.
Fixed:
Check level transfluid, ok,
Check level engine Oil, ok, added 1dl,
Check freezing temp Coolant, -30C, ok,
Silicon spray all door seals, to prevent freeze up.
Lock Oil in door Locks.
And i bought the best winter tire EVER, they provide awsome traction on water and black ice, not got to rear them on snow yet.
Jeep is good prepared for a harsh winter now.
Just need a kick A.. Shovel though.
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is offline   Reply With Quote Quick reply to this message
Unread 10-31-2012, 12:03 PM   #39
billzcat1
2003 WJ
I have a folding Gerber E-tool ($44) in the back seat pocket at all times and carry a cheap shorty flat-blade shovel (better for scraping roads) when it's snowy. Really impressed with the E-tool in snow, used it to dig out a whole campsite and it cuts snow and ice like nothing. And its not too big you get worn out lifting heavy show.
Unread 10-31-2012, 12:28 PM   #40
BrownWJ
1988 XJ Cherokee
A bottle of isopropyl alcohol allows you to freeze protect non winter washer fluid and helps remove frost ice from the windshield. Just put a pinhole in the paper seal and spray on the windshield.
Narrow tires give more bite. ( for snow)
Wide tires give more float. (For mud/sand)
BrownWJ
BrownWJ is offline   Reply With Quote Quick reply to this message
Unread 10-31-2012, 02:49 PM   #41
Thomahawk
Thomahawk's Avatar
Thats what i am talking about, that thing is sweet, can be used as an axe also, right???
Unread 10-31-2012, 04:38 PM   #42
billzcat1
2003 WJ
Sort of. It's got a serrated edge. http://www.amazon.com/Gerber-30-0000...folding+shovel
PS: Sorry for mucking up your thread, ChrisHager!
Unread 10-31-2012, 05:02 PM   #43
Thomahawk
Thomahawk's Avatar
Its a shovel thread now, its still on topic, its winter emergency related.
I was looking at something like this, yours is kick A to,
http://www.youtube.com/watch?v=#/watch?v=j7Edh...dhnReYH0&gl=NO
Unread 10-31-2012, 05:21 PM   #44
billzcat1
2003 WJ
I like the fold-up handle since it tucks into the map pocket like it's not even there. Both are good choices though, just telling you what swayed my buying decision. First aid kit + emergency shovel in one pocket, electrical repair parts and tools in the other.
Unread 10-31-2012, 05:24 PM   #45
Thomahawk
Thomahawk's Avatar
Yes its very handy with the fold up handle, price wasnt to bad either.
driving , ice , information , snow , winter
