injector swap question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > injector swap question
CHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-18-2012, 06:16 PM   #1
adhdlacrosse16
any one know the part numbers for the 4 hole bosch injector swap on a 1999 4.0
99' WJ... tank raise mesh grill homebrew cai
magnaflow 11226, banks header, bb sittin on 31s
adhdlacrosse16 is offline   Reply With Quote
Unread 06-18-2012, 07:06 PM   #2
adhdlacrosse16
nobody?
Unread 06-18-2012, 08:24 PM   #3
narnwv
narnwv's Avatar
not sure about the ones for the 4.0, but when looking at autozone, pulling up info for a 2003 pulls up 4 hole injectors.
~Aaron
NarnWVs Build Thread
2000WJ 4.7 247->242 swap,
Rough Country X-series 4",
K&N, Flowmaster Super 44,
JK Moabs+32" BFG KM M/Ts, Addco rear
custom4x4fabrication rear bumper
Hitch-Mount Tire carrier for sale
Originally Posted by jeep04 View Post
I just drive mine with a helmet on (just in case)
narnwv is offline   Reply With Quote
Unread 06-19-2012, 04:29 AM   #4
QuadraTokn
1930 WJ
Are you talking about using the Ford injectors?
QuadraTokn is offline   Reply With Quote
Unread 06-19-2012, 08:25 PM   #5
adhdlacrosse16
i was thinking the ones from a neon? just need a part number to see if they will work.
i think those are a different flow rate. correct me if im wrong though
Unread 06-20-2012, 10:15 PM   #6
adhdlacrosse16
night crew?
Unread 06-23-2012, 08:51 PM   #7
adhdlacrosse16
bump
Unread 06-24-2012, 06:12 AM   #8
Cobra Jeep
They are bosch 0280155784, found in like 98-99 model dodge neons.
I am running a set of these in my 99 WJ 4.0
If buying a set from the junkyard, I highly reccomend sending them out and having them sonic cleaned. You never know how long they have been setting in the junkyard car without being used.
'93 YJ 4.0L, AX-15, NP-231, SYE, CV, 8.8in rear, OME 2.5 lift, WJ knuckle/brake conversion, hydroboost. Warn M10000 winch. Hope to some day build a stroker for it.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Future mods: NV4500, NP205, high pinion D60 front and smooth bottom D60 rear, e-lockers front & rear. SOA with 35X12.50's
Cobra Jeep is offline   Reply With Quote
Unread 06-24-2012, 04:14 PM   #9
adhdlacrosse16
thank you sir! i wont be getting them from a yard. ebay for me
Unread 06-24-2012, 04:15 PM   #10
adhdlacrosse16
did you experience any of the wild claims people are making like increased power blah blah blah. or just smoother running and overall drivability?
Unread 06-24-2012, 05:51 PM   #11
Cobra Jeep
People just make wild claims to make themself look cool and smart. There is 0 performance gain by swapping to these injectors. What they do is better atomize the fuel and will give you a noticely smoother idle and smoother running/sounding engine. And unless your old injectors are really bad shape, mileage shouldnt change any either. If you do get more power or better mileage from the swap, then that just means your old injectors were starting to get stopped up or worn out. So dont spend too much money buying a set, if you spend big bucks on a set and put them in, you might be a little let down on the gains Vs. the price. Thats why I got some good $5 ea junkyard injectors and sonic cleaned them.
Unread 07-01-2012, 11:29 AM   #12
adhdlacrosse16
how much is sonic cleaning?
Unread 07-01-2012, 05:30 PM   #13
Cobra Jeep
http://www.mrinjector.us/index.html
