Ignition Key Stuck in Lock - JeepForum.com
post #1 of 12 Old 07-29-2012, 01:07 AM Thread Starter
terrypack1963
2007 WK
Wj Ignition Key Stuck in Lock
I am having problems with removing the ignition key of my 2002 WJ GC Overland (UK) this morning. I have been looking at the park lock mechanism but can find no fault there at the moment. As a side issue, but likely to be related, is that in the last week or so the electric driverís seat hasnít always been going back to the exit position when I have switched off the ignition.
I am now thinking it is definately the cylinder lock mechanism but would welcome any thoughts or advice anyone can give.
Thanks in anticipation.
terrypack1963 is offline
post #2 of 12 Old 07-29-2012, 04:57 AM
SwissWJ
Is the steering wheel locked? If so try and move it while pulling out the key
SwissWJ is offline
post #3 of 12 Old 07-29-2012, 06:13 AM
Bluefish94
Turn the steering wheel to one side to disengaged the lock, when my cylinder was going bad I had to pull to one side hard enough I thought it would break.
Sent from my ECM
Bluefish94 is offline
post #4 of 12 Old 07-30-2012, 08:00 AM
Double E
Double E's Avatar
Here ya go...http://www.jeepforum.com/forum/f13/k...o-turn-597301/
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #5 of 12 Old 07-30-2012, 08:26 AM
Amadauss
I know this is not the correct fix, but when we have the same issue, I found a slight tap on the key while in the ignition would cause the tumblers to fall into play and the key would work fine. This seems to be a common problem for many jeep owners. We keep a small rubber mallet under the seat and when we have this issue which is not often, but happens, a light tap on the key and it turns no problem. Again, not the correct fix, and we need to replace the tumblers eventually, but it works for us now. I guess when we finally have to use a sledge hammer to get the key to work, will make the correction.
1999 Jeep WJ, 78,072 miles new adco sway bar in rear. new rotors hubs and caliphers, new cv axles up front, Repainted-all black. steering system better stabilizer new tie rods and tubes. New shocks.
Amadauss is offline
post #6 of 12 Old 07-30-2012, 08:32 AM
robby65
2007 XK Commander
if you do get the key out try some graphite and spray it in there,supposed to help with the tumblers.
http://www.amazon.com/Lock-Ease-Grap.../dp/B0006MWPZA
robby65 is offline
post #7 of 12 Old 07-30-2012, 11:25 AM
WJHype
As dumb as it sounds, just hit the end of the key with your hand or a hammer or something and it will free it up. I had to do this often until I replaced the part inside the key ignition.
2001 4.7 WJ 2" BB 15x8 Cragar V5s 31x10.50 Duratracs
WJHype is offline
post #8 of 12 Old 07-31-2012, 03:15 PM Thread Starter
terrypack1963
2007 WK
Hi - thank you all for your replies. I have tried the tap of the key 'solution' and unfortunately that didn't work and have decided the most appropriate course of action (for me) is to take to the Jeep main dealer. That is later this week and I shall report on the outcome. From all the people I have contacted I am convinced it is the tumblers in the lock is at fault.
Terry
post #9 of 12 Old 08-01-2012, 10:34 AM
Jaman
at the risk of sounding dumm, this happens to me on occasion, and is the result of not being completely in "park", if I give the gearshift a wiggle, it'll click in place, and I can then pull the key out... probably not that simple on your end, but u never know... good luck!
Jaman is offline
post #10 of 12 Old 08-01-2012, 11:17 AM
Double E
Double E's Avatar
You need to hit it harder. Hit it in the same direction that it is inserted into the key hole and as you hit it, try to turn the key with your other hand.
It works.
Double E is offline
post #11 of 12 Old 08-01-2012, 11:20 AM
mattcofc
Had this issue where I banged the key with a hammer to get it out. Once you get the key out WD40 the **** out of it and keep working it in the ignition followed by wiping on a towel to clean out the crud that was gumming it up.
mattcofc is offline
post #12 of 12 Old 08-03-2012, 11:29 PM Thread Starter
terrypack1963
2007 WK
Thank you for all your replies. I must admit that I did not try the 'hit key harder and turn' option but did take it to the Jeep dealer who changed the complete barrel of the lock (at a price).
I do find the forum very useful and thanks again for taking the time to respond. Hopefully I will have more time in future to resolve some of these Jeep issues myself.
Rear Lift gate stuck on lock... get_keebsy WJ Grand Cherokee Forum 11 06-07-2012 04:53 AM
Where and which ignition lock cylinder iceman123187 WJ Grand Cherokee Forum 0 01-08-2011 02:41 PM
keys get stuck in ignition CoolGuyDave WJ Grand Cherokee Forum 15 09-18-2010 12:15 PM
Found a fix for ignition switch/barrel lock up! Jet 4.7 WJ Grand Cherokee Forum 1 07-30-2010 07:49 AM
Help! Ignition stuck, 2000 GC Abandoned jasonmoore WJ Grand Cherokee Forum 3 02-08-2004 07:31 AM
