If I seal the heater core leak into the cab where will the coolant go? - JeepForum.com
post #1 of 3 Old 09-21-2017, 10:22 AM Thread Starter
livebait
Unhappy If I seal the heater core leak into the cab where will the coolant go?
I've had the dreaded drip-drip-drip of coolant onto the front passenger floor for 2 years. I dont have time, money or energy to replace the core. If I put JB Weld around the little bolt-head where its coming into the cab, where will the coolant build up and go to from there? Is there an overflow port that it will just spill outside the vehicle? Or will it just come out somewhere else inside the cab?
Thanks.
LB
livebait is offline
post #2 of 3 Old 09-21-2017, 10:33 AM
ChrisHager
Administrator
ChrisHager's Avatar
Have you considered disconnecting the heater core hoses from under the hood and routing them into themselves? This will bypass the heater core and allow the coolant to flow as it usually would.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #3 of 3 Old 09-21-2017, 11:09 AM
JMZ101586
Out the hvac drain in the firewall
Stable:
04 WJ Special Edition 4.7
98 Camaro SLP SS with LS2 swap
05 STS4 4.6 Northstar AWD
JMZ101586 is online now
