If air conditioner is on should the cooling fan be on - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > If air conditioner is on should the cooling fan be on
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 11-07-2010, 08:34 AM   #1
BillShort
Wj If air conditioner is on should the cooling fan be on
If air conditioner is on should the cooling fan be on - If so what turns it on because mine only comes on when engine temps turns it on.
1999 Grand Cherokee Limited 4.7
BillShort is offline   Reply With Quote
Unread 11-07-2010, 04:48 PM   #2
the88thpianoman
the88thpianoman's Avatar
2003 WJ
As far as I know, our cooling fans are tied only to engine temp and do not stay on with ac.
the88thpianoman is offline   Reply With Quote
Unread 11-07-2010, 05:07 PM   #3
JForest2
Not sure what year WJ you have but on my 03 I6, whenever I put the ac on the fan went on also...
James
JForest2 is offline   Reply With Quote
Unread 11-07-2010, 05:11 PM   #4
the88thpianoman
2003 WJ
Interesting... my 03 I6 does not...
Unread 11-07-2010, 05:11 PM   #5
BillShort
I have a 99 Grand Cherokee Limited 4.7. Sounds like one of you guys may have a problem.
Unread 11-07-2010, 05:21 PM   #6
Bubba3200
I will have to check mine....02 Overland. But the theory here should be that the fan comes on when the a/c is selected. Why?? Because the condensor has to have air across it at all times to cool the freon. Just like your home unit....when it is on the outside condensor fan should be running. If the fan is not running at stop or slow speed the a/c will not work right and a over heat condition could occur.
The hydraulic fan on mine seems to have variable speeds and it seems to adjust accordingly.
Bubba3200 is offline   Reply With Quote
Unread 11-07-2010, 06:04 PM   #7
ultimo
I have both hydraulic and electrical fan, and sometimes the electrical fan does not turn on unless idling for a long time. So i guess thats ok. AS the hydraulic fan blows all the time anyways.
Build Thread-- http://www.jeepforum.com/forum/f197/ultimos-build-1477712/
ultimo is offline   Reply With Quote
Unread 11-07-2010, 06:14 PM   #8
WiCkeDuDe
WiCkeDuDe's Avatar
They didnt put the hydraulic fans on the 4.0s.
WiCkeDuDe is offline   Reply With Quote
Unread 11-07-2010, 07:07 PM   #9
patrick983
on the 4.7's the electric fan should be on with the a/c
2000 White V8 WJ LSR-6in-35's-LA's-242HD-Warn [B]SOLD and missed very badly[/B]
06 GTO - BC Coilovers, JBA Catless mids, Svede Intake
patrick983 is offline   Reply With Quote
Unread 11-07-2010, 07:26 PM   #10
BillShort
Ok Cool the fan should be on with AC. Mine is not coming on, what controls the fan. The fans does come on from from engine temp.
Unread 11-07-2010, 08:32 PM   #11
ultimo
I added it in Bought the mopar part and clutch from Kolak. I believe those with the tow package came with it too
Unread 11-08-2010, 04:49 PM   #12
BillShort
Come on - Somebody must have the answer.
Unread 11-08-2010, 05:03 PM   #13
cedxc2005
Wj
THIS. It is exactly as Bubba said. I have an 04 WJ I6. AC on = electric fan on (no hydraulic fan). Why? Because your AC needs air over the condenser to make cold air. Totally normal. Note that if your Jeep hasn't warmed up all the way, if you turn off the AC, the fan will go off. Theoretically, if you are moving, it should turn off as well, but I don't know if that is the case, and it's kinda hard to check...
Long story short, electric fan operation with AC on is normal. No worries.
My Jeep Thread (not a build thread!) - http://www.jeepforum.com/forum/f310/long-overdue-greetings-root-thread-1128437/
Something useful - http://www.jeep4x4center.com/jeep-service-manuals/index.htm
cedxc2005 is offline   Reply With Quote
Unread 11-08-2010, 05:40 PM   #14
BillShort
Ok guys i know the fan should be on when the ac is turned on. But mine does not, and causes a high pressure problem. The fan comes on when engine temp is over 215, so i know the fan works.
So what am i missing - what turns the the fan on when i press the ac button?
Unread 11-08-2010, 06:07 PM   #15
compcrasher86
compcrasher86's Avatar
OH You're talking about the hydraulic clutch fan. Yeah, the one you tie to the waterpump pully. That comes standard on tow package 4.0s. The other guy was thinking about the main hydraulically operated fan that works off of the power steering pump that is on the 4.7 WJs instead of the electric one we have on the 4.0s
01 WJ Ltd | i6 | QT2 | OME HD Lift | Bilstein 5100s | IRO Links | IRO A-Arm | Dueler AT RHS 255-70-18 (32") | JK Sahara rims | Moog HD steering | Upcountry Skids | Tow Package | KC Dayliters | Cobra 19 | Boston Acoustics Audio | Mopar subwoofer | RB1 | Lou's Catback | Stone White | Agate Interior
Build Thread
RIT Offroaders
Matt
compcrasher86 is offline   Reply With Quote
