Idles rough at first, stalls once and then runs fine. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Idles rough at first, stalls once and then runs fine.
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 12-12-2014, 09:10 AM   #1
casauall002
2002 4.7 HO V8 Overland
So, I know I have exhaust leaks as I can smell them and I have codes. Just donít have the money to get it fixed right now. Recently though, it started acting up and I wanted to see if there was something I could be checking or replacing myself. The mechanic said to start with the mass airflow sensor but I figured Iíd bring the question here first and see what everyone thinks before I start replacing things.
Say I start it up, it idles incredibly rough and bounces and you can hear the muffler making kindof a popping sound some times. From there, if I go and take off, there will be a spot where it kindof stalls even though Iím giving it gas and then the engine will do a quick rev in rpms and it will take off very quickly. After that, it runs fine with no issues including putting it in park and letting it idle. However, if I turn it off and then back on again, it usually doesnít idle well.
Any ideas?
Exhaust related
Muffler
Vacuum Lines
Fuel Pump
Fuel Filter
Mass Airflow Sensor
Other?
I appreciate the help!
casauall002 is offline   Reply With Quote Quick reply to this message
Unread 12-12-2014, 09:29 AM   #2
steve_80
IAC and/or TPS?
I replaced both of those (Mopar ones from Kolak) and now mine idles/drives/shifts like new.
Have you cleaned your Throttle Body and cleaned your sensors (IAC, can't clean TPS)?
http://www.wjjeeps.com/service/tbody.htm
steve_80 is offline   Reply With Quote Quick reply to this message
Unread 12-12-2014, 11:10 AM   #3
86cj74.2L
86cj74.2L's Avatar
Vacuum leaks?
86cj74.2L is online now   Reply With Quote Quick reply to this message
Unread 12-12-2014, 04:52 PM   #4
casauall002
I know this may sound stupid but where is the throttle body? It actually has a brand new engine.
It does feel like a vacuum issue but I'm not sure how to determine it. I know if I smoke tested the thing, it would be pouring smoke from places. I've looked on youtube for an easy way to smoke test them but not really any easy ones. The shop will do it for like $70...Will that show vacuum leaks also? Would either of the above problems cause it to sputter and make the popping noise when idling in park?
Unread 12-12-2014, 05:18 PM   #5
beachblu
Wj
IAC and/or TPS?
What is "IAC"??
beachblu is offline   Reply With Quote Quick reply to this message
Unread 12-12-2014, 07:18 PM   #6
86cj74.2L
86cj74.2L's Avatar
I find vacuum leaks with a can of brake cleaner. Smoke tests to me are for troubleshooting problems with the EVAP system.
Unread 12-14-2014, 04:01 PM   #7
steve_80
Originally Posted by beachblu View Post
IAC and/or TPS?
What is "IAC"??
Idle Air Control... it's right next to the TPS (throttle position sensor) on the throttle body.
see here: [http://www.wjjeeps.com/service/tbody.htm
Unread 12-15-2014, 09:18 AM   #8
casauall002
What's the best method for using that and best place to start?
Unread 01-13-2015, 02:01 PM   #9
casauall002
It's weird. It runs fine after that happens but I can turn it off for 5 seconds, turn it back on and the same problem again.
Unread 01-15-2015, 11:02 AM   #10
beachblu
Steve80: first, my apologies for not responding to your excellent tips. As a long time hobby mechanic but novice WJ owner, I'm slowly catching on..
I followed the very informative links you provided and they will be tried. I once had a 5.0 Ford motor with a sticking "idle gate" that your comment brought out of my fading memory. I'm away from my trusty WJ for a few months now, but when back will followup and provide my "learnings" in another posting reply. Thanks again.
