I want to order some brakes today - Page 2 - JeepForum.com
post #16 of 35 Old 06-10-2010, 01:46 PM
ZJPunk98
I'm going to agree with technohead in that there is a happy medium between surface area and total mass for the best breaking. Finding this medium is what performance companies are trying to do. From what I've read and learned, EBC slotted and dippled rotors are the bang for your buck. I run them with EBC yellow stuff pads, not to mention I'm running a vanco brake system. It greatly improves stopping ability.
www.perfectbrakes.com - online shopping for quality disc brake pads and brake rotors
powerbrakes hydroboosts vacuum boosters everything for your extreme braking needs
As someone mentioned, you need to look at the whole system when you want to improve your braking
ZJPunk98 is offline
post #17 of 35 Old 06-10-2010, 04:20 PM Thread Starter
matrix849
I wouldn't mind doing a "system overhaul" but, knowing what to buy is the hard part.
Like the Vanco Powerbrake system isn't compatible with a 2002 jeep grand cherokee.
matrix849 is offline
post #18 of 35 Old 06-10-2010, 06:07 PM
WJ04
Stillen rotors and metal matrix pads... FTW!!!!
2004 WJ Laredo-selectrac 242-I6- Custom XJ intake w/Amsoil cone filter- PSC HD Pump & Res- PSC ported box- B&M trans cooler- B&M PS cooler- Custom chevy 1 Ton over the knuckle steering- Rough Stuff 1 Ton tierod & draglink ends- Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -Relocated OME SD-40 Steering Stabilizer-BDS stabilizer brackets-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Still to come: Flowmaster 50suv
Some of my videos:
Originally Posted by billyjp2 View Post
I burnout on puppies and kittens
Originally Posted by vwmaniacx View Post
Lets not and say we didn't.
WJ04 is offline
post #19 of 35 Old 06-10-2010, 06:35 PM
xJoshxx
2012 WK
this thread /thread
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #20 of 35 Old 06-11-2010, 07:36 PM
freakinheep89
Originally Posted by matrix849 View Post
Same size rotors though?
yes they are the same size rotors, the caliper follows the same contour of the old one but it just extends a little longer. i looked at them last night and cant find a part number or brand name, i just know we got them from morris 4x4 center.com.
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #21 of 35 Old 07-23-2010, 03:29 PM Thread Starter
matrix849
Well I have decided against aftermarket calipers, I am going to the stealership tommorow to pick up some akebono calipers, then i'll prob stop by a local parts store for pads and rotors.
All I need from the stealership is the caliper and caliper bracket right?
I can use the old bolts/pins? Or should I get that as well?
And I shouldn't have a problem with the old factory rims right?
Also, while I'm down there any other maintenance suggestions? Busings... etc? I"ll be going on a long drive friday this week, and i'd like to make sure everything is up to speed.
2002 jeep w. 75k miles
post #22 of 35 Old 07-23-2010, 04:09 PM
SnowLeopard
I'd think Kolak, aka Nick, could give you a far better deal on those Akebono calipers, and he has other brake pad and rotor options that aren't so high-end. He also gives JF members a discount. Just a head's up. He's a great guy to work with.
SnowLeopard is offline
post #23 of 35 Old 07-23-2010, 04:53 PM
WiCkeDuDe
No reason to buy the akobonos from the dealer unless you like to waste your money.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #24 of 35 Old 07-23-2010, 05:14 PM
Double E
Double E's Avatar
Keep your calipers. They're most likely fine.... Check my sig for what I've had on for 4 years now, towing a heavy old boat all over the East. Good equipment.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #25 of 35 Old 07-23-2010, 05:47 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Brake Performance - Slotted and Drilled Brake Rotors This is what I am running. They are zinc coated, and have a lifetime warranty against warping. I have been very pleased with their performance so far. They were 187 delivered to my door with pads.
xjfever is offline
post #26 of 35 Old 07-23-2010, 06:19 PM Thread Starter
matrix849
Do you suggest special pads to run with those rotors?
Or will regular pads do the job?
post #27 of 35 Old 07-23-2010, 10:52 PM
straty1987
can i ask why you pieced these rotors over the ones from stillen?
straty1987 is offline
post #28 of 35 Old 07-24-2010, 05:59 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The price, and the fact that they come with a lifetime warranty against warping. The ones I bought were 187.00 with free pads and free shipping. The stillens are 230 without shipping or pads. And the stillen warranty says limited lifetime which usually doesn't cover much.
xjfever is offline
post #29 of 35 Old 07-24-2010, 06:43 AM
Kolak
Vendor
Kolak's Avatar
I sell the Stillen rotors for $160.00 for the front pair - far less than their web site pricing.
The quality of their rotors is such that warranty claims are nearly nonexistant. I've had customers replace them after 50,000 or 60,000 miles, just because they've worn them out, but that's impressive life without any warping issues.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is online now
post #30 of 35 Old 07-24-2010, 04:52 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I wasn't trying to knock the stillens, as I personally have no experience with them. I was looking at those and the EBC brakes when I found the ones I purchased, I was pleased with the price and the similarities to the other two, and thought I would give them a try. I have only been running them for a few weeks so I can't give any real info on them except they look to be of excellent quality and so far have improved braking power slightly with no wobbles everytime I hit the brakes. I will update later with how they last and give a very honest summary. If they warp and I have warranty problems I will share those as well. I assume the stillens or EBC'S would be of equal quality and didn't want to steer anyone away from those two, just posting a different option.
xjfever is offline
Need to pump brakes in order to get pressure 97DCZJ ZJ Grand Cherokee Forum 42 05-23-2016 02:09 PM
HP Dana 30 find today - possible to keep anti lock brakes? Area.3.Fiftyone ZJ Grand Cherokee Forum 9 10-09-2009 06:25 AM
Changing Brakes today...what brand? adgjqetuo ZJ Grand Cherokee Forum 3 09-29-2008 10:11 AM
Placed an order with IronRock today!!! 04WJfreedom ZJ Grand Cherokee Forum 12 05-17-2007 07:59 PM
Put in a lil' order at IRO today... JayIV ZJ Grand Cherokee Forum 47 05-10-2007 11:23 AM
