I need serious help! I'm stumped - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > I need serious help! I'm stumped
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 11-24-2013, 03:35 PM   #16
doorjamm
Originally Posted by Toreyjw1
Very interesting. How is that swapping out? Any retrofitting? Or is just a direct bolt up? And what about the selector lever? Mine currently has just 4wd all time neutral and 4lo
And regarding the PC and its expense, it seems as if they're about 500? What's the cost of a 242? And can it be 4wd and used on pavement? I intend using it this winter w/ ice for work. My company is a service company and snow around these parts halts everything. So well be mobile.
Regards!
If I were you, I'd just do the 242 swap. It'll take less work and be better for you in the end. The 242 Selectrac will allow 2wd, but also the 4wd all time that you are asking for, along with more selections. The swap is direct, but you need the rear drive shaft from the same vehicle as they are different between the 242 and 247. And then there is a minor adjustment that takes 30 seconds with the cable bracket. Look up the thread on here, and junk the 247 in my opinion. My 242hd and rear driveshaft cost 550 at LKQ in northern California and many people have gotten them cheaper. I believe gcjeeping has a couple in his garage, maybe you can contact him about picking one up
doorjamm is offline   Reply With Quote Quick reply to this message
Unread 11-24-2013, 06:36 PM   #17
Toreyjw1
Man, that's awesome! I will definitely look into it. This binding is getting very annoying. Thanks a lot!
Toreyjw1 is offline   Reply With Quote Quick reply to this message
Unread 11-24-2013, 10:00 PM   #18
99_wj_QD
Take my word for it, Im a mechanic and I too own a 99 with the 4.7L, they only offered one platform of 4WD that year with the V8
You do not have an open diff, you DO have LSD in both axles. http://wjjeeps.com/tcases.htm
Don't worry too much just yet, do a diff service on both the front and rear, when you add the new gear oil you will need to also add 4 oz. of the friction modifier to ensure proper operation of the LSD clutch packs.
99_wj_QD is offline   Reply With Quote Quick reply to this message
Unread 11-24-2013, 10:04 PM   #19
99_wj_QD
Please grow something that resembles a logical brain, she just bought this thing and you are actually proposing something this radical when her most likely problem is lack of friction modifier??
If you are going to convert anything in your driveline the only thing that is going to be really worth your money is to drop a wrangler rubicon setup into your WJ, something that is truly designed to GO OFF ROAD
Unread 11-24-2013, 10:04 PM   #20
ezflip
ezflip's Avatar
Umm what? You have no clue what you are talking about. Please get down from your soapbox and quit giving horrible information. You are not the know all end all of anything. In fact, I have not seen you post a single thing that was true or factual. Please, for the sake of the new people who don't know any better, go away.
~James
2002 Overland - 4.7 HO, "Select-Drive", 4" RC long arms, TAG front winch bumper, 32" BFG KM's, 3" exhaust, Magnaflow hi-flow cat, Flowmaster 50 series
Build Thread
ezflip is offline   Reply With Quote Quick reply to this message
Unread 11-24-2013, 10:09 PM   #21
car5car
2002 M-38
Originally Posted by Jeeples View Post
OP-
Are you sure it's not the t-case binding up?
That is what it is. Very common problem.
People usually remove front shaft, easy solution. BTW, it is how you can diagnose problem.
01 XJ 2wd 4.0
car5car is offline   Reply With Quote Quick reply to this message
Unread 11-24-2013, 10:09 PM   #22
99_wj_QD
so the 99 WJ with the quadra trac doesn't have limited slip clutch packs??? And actually I will take one thing back, I do believe I was wrong about LSD in the front axle, but I can verify exactly what is in the 99 V8 platform tomorrow. What is your training/knowledge of automotive powertrains? or of anything else I have posted about??
If you learn anything from a majority of the posts on this forum it is that most ppl posting know one thing and one thing only, get the code then throw the part at the thing hoping it will fix the problem....or better yet, drop a junkyard trans in your jeep if you have s problem with your current one
Unread 11-24-2013, 10:12 PM   #23
ezflip
ezflip's Avatar
so the 99 WJ with the quadra trac doesn't have limited slip clutch packs??? What is your training/knowledge of automotive powertrains? or of anything else I have posted about??
Nope, it sure doesn't. The diffs are open and the transfer case has a progressive coupler. Neither of which require any amount of friction modifier. I've torn down and rebuilt enough of these to know how they work. I didn't learn in some class room. If I were you, I'd consider asking for a refund on your "training".
~James
Build Thread
Unread 11-24-2013, 10:18 PM   #24
99_wj_QD
yep that transfer case does but there are clutch packs in that axle, and the front one too, that comes straight from the manufacturer service info...or are we all just adding friction modifier to our diffs for no reason???????
The tires are spinning in opposite directions with the rear axle off the ground because when in park your trans locks up the driveline which doesnt allow the wheels to turn any other way, which is why it is called a parking gear it prevents the vehicle from moving
Unread 11-24-2013, 10:18 PM   #25
MuddyWJ
No you retard quadra-trac does not have limited slip clutch packs. My knowledge and training would be rebuilding my first engine in 7th grade. You started a great career in life and started a lifelong career in hell on this forum with your absurd and arrogant post last week. If you want to help people sign up to be a big brother or volunteer at a homeless shelter because the words that come off your keyboard are complete and udder bull****. Get the hell off the forum, nobody likes you and how long till you give someone bad information that leads to the destruction of their rig or worse gets someone hurt?!?! "Mechanics" like you think they know everything because you read a book but when it comes down to "experience " you've got none. Wake up.
MuddyWJ is offline   Reply With Quote Quick reply to this message
Unread 11-24-2013, 10:20 PM   #26
gcjeeping
gcjeeping's Avatar
Take my word for it, Im a mechanic...
And the number count continues. LOL
__________________________________________________ _________
-GCJEEPING's build/mod thread-IT'S A GREEN THING...
gcjeeping is offline   Reply With Quote Quick reply to this message
Unread 11-24-2013, 10:26 PM   #27
ezflip
ezflip's Avatar
Quadra DRIVE has variloc axles. Quadra TRACK II has open diffs. You even linked to the wjjeeps page that explains it. Did you not read the info YOU posted? People with Quadra DRIVE put friction modifier in their axles. People with Quadra TRACK II do not. But by all means, if you want to waste the money and throw fm into your axles, be my guest. I agree with the above, your god awful advice is going to cause someone more damage to their rig, or worse, get someone hurt.
~James
Build Thread
Unread 11-24-2013, 10:28 PM   #28
99_wj_QD
OK MUDDY
then can you explain to me what vari-lok is, this retard actually enjoys learning new things
Unread 11-24-2013, 10:30 PM   #29
gcjeeping
gcjeeping's Avatar
LOL.
He can fall back on the space program since he went to space camp one year too. I'm sure he has let NASA know his email address in case they have any problems.
Unread 11-24-2013, 10:35 PM   #30
MuddyWJ
This!
