I need quick brake help! - JeepForum.com
post #1 of 6 Old 03-03-2004, 08:41 AM Thread Starter
McStealth R/T
Hey guys... I have the front wheel pulled off my 99 WJ I6 and am trying to replace the pads. Can anyone tell me the size of the allen fitting for the bolt that's securing the caliper?? I've tried all that I have and none of them fit (standard and metric)!
Thanks!
McStealth R/T is offline
post #2 of 6 Old 03-03-2004, 09:01 AM
Meerkat
Thanks!
I don't remember the size offhand.. But I'm thinking 10mm. However, if I'm not mistaken, it is a torx head and not an allen head. You might want to get a flashlight and check that...
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 6 Old 03-03-2004, 05:05 PM Thread Starter
McStealth R/T
Thanks for the reply. I actually took one of the bolts that I *was* able to pop out with a 1/4 allen wrench to NAPA and we found a match! A 7mm allen for my socket was the perfect fit! Now, are you guys ready for the rest of the story??
Well, I actually did this brake job because I was having trouble with the front driver's side wheel getting super hot to the touch after a drive... often without much braking. It would smell terrible and the brakes would fade a bit. I figured the brake job may be a fix because anything that might be making the caliper malfunction would be fixed after I compressed the pistons and bled everything out.
I was WRONG!! This morning, after putting on the new pads, I was headed to see my wife and I started to smell *that* smell again. I stopped at a red light and I can actually see SMOKE billowing up from the wheel well. I only had about 2 more blocks to my wife's office, so I limped along til I got there (smoking wheel and all).
I called a local Jeep specialist and he informed me of the caliper upgrade, so I bummed a car from my sister in law and drove down to the $tealership to pick up my new parts. After that, headed to the house and picked up every concievable tool that may be needed and headed back over to the Jeep. After a couple of hours, the Jeep is now riding on a brand new brake setup!
Anyways... to make a long story short... stock brakes on the 99-01 are CRAP. What were the engineers thinking when they slapped these things together??
post #4 of 6 Old 03-03-2004, 05:12 PM
Meerkat
Glad you were able to figure it out in spite of my help!
What's that about brake upgrade? I'd like to know more.
Warren
Meerkat is offline
post #5 of 6 Old 03-03-2004, 05:22 PM Thread Starter
McStealth R/T
It's a beefier set of calipers, new pads, and rotors. I think they're the same units found on the 01 and up, but not entirely sure. They're also easier to work on!! Entire setup cost me $350 (with new rotors), which is amazing coming from the dealership!
post #6 of 6 Old 03-03-2004, 06:02 PM
Meerkat
I'll say it is!
Thanks 4 the info!
Warren
Meerkat is offline
quick brake question... egleas522 ZJ Grand Cherokee Forum 3 08-13-2009 01:00 AM
quick brake question dmolaver15 ZJ Grand Cherokee Forum 5 02-12-2009 08:20 PM
ATTN: Need quick help with brake lines Casper4x4 ZJ Grand Cherokee Forum 9 07-03-2008 11:58 PM
Quick brake question FreedomCherokee ZJ Grand Cherokee Forum 9 11-15-2006 07:44 AM
Quick Brake Bleeding Question... mr_user ZJ Grand Cherokee Forum 2 04-07-2006 05:20 PM
