I need help with my 99 WJ to get it on the road.Please and thank u - JeepForum.com
post #1 of 11 Old 09-14-2010, 06:55 PM Thread Starter
jeepboy99705
Wj I need help with my 99 WJ to get it on the road.Please and thank u
to start i blew my motor (wich is a 4.0) i got a whole part jeep a 2000 wj only had 60.000 miles on it.So i swapped the motor out now it dosent want to start up.Iv put a new crank sensor,flex plate and a a new coil rail all from the dealer.Still no start it seems to back fire,and it seems as if the timing is off. im out of ideas and realy just want to get it back on the road any ideas??
jeepboy99705 is offline
post #2 of 11 Old 09-14-2010, 06:59 PM
metalhead
2011 WK
Computer problem maybe?
metalhead is offline
post #3 of 11 Old 09-14-2010, 07:20 PM
insjim
You need to give a better description....Start by what year is the jeep you put the motor in?.....Did you use the externals off your jeep motor sensors etc.?
insjim is offline
post #4 of 11 Old 09-14-2010, 07:22 PM
88yjproject
Did you use the spacer for the new crank sensor to get it spaced right?
2002 WJ 4.0 3" IRO, ES9000 shocks. Midland CB. 245/75R16 Dunlop M/T.
HydroLocked Offroad
88yjproject is offline
post #5 of 11 Old 09-14-2010, 07:25 PM Thread Starter
jeepboy99705
and i used the sensors from the 00WJ
post #6 of 11 Old 09-14-2010, 07:27 PM Thread Starter
jeepboy99705
Yes i did the dealer has a big note about it when u buy the new one.
post #7 of 11 Old 09-14-2010, 07:34 PM
little_Jeep
Double check the Crank Sensor and the distributless distributor that is in the 2000 WJ to make sure they are installed and adjusted correctly.
little_Jeep is offline
post #8 of 11 Old 09-14-2010, 07:45 PM Thread Starter
jeepboy99705
Il looked at the "distributor" but another thing i just thout of that i heard it run in the 2000 before i did the swap.
post #9 of 11 Old 09-14-2010, 07:58 PM
little_Jeep
Are you using computer out of the 2000 or out of the 99? You could have an issue with sensors communicating with computer... Did the 99 have the distributorless system? I know my 98 doesn't, but my 2000 does.
post #10 of 11 Old 09-14-2010, 08:12 PM
insjim
Bingo, Switch all sensors from your 99 for your computer or upgrade computer
insjim is offline
post #11 of 11 Old 09-14-2010, 08:27 PM
tsconver
2003 WJ
did you move the camshaft sensor? It has to be timed tothe fuel injectors, you can not do it by hand, it has to be done with a DRBIII scan tool. YOu can get it close and it will run but to get it right it has to be done with the scantool. Sound sto me like you might be off by a bit on the camshaft position sensor.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
A few goodies
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
2006 Red Liberty
Wife's ride, pretty stock
tsconver is offline
WJ Road Noise Big_C WJ Grand Cherokee Forum 1 05-11-2010 08:12 PM
What is the best WJ lift for on/off road use ? nierace WJ Grand Cherokee Forum 38 07-31-2007 08:42 AM
Road Taxes mitrop WJ Grand Cherokee Forum 4 01-16-2004 12:03 AM
Road Noise??!!?? scorpio31 WJ Grand Cherokee Forum 0 10-10-2003 12:03 AM
