I could really use some help. 9hrs away from home. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > I could really use some help. 9hrs away from home.
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 03-16-2015, 11:06 AM   #1
Jay8five
My 01 wj 4.0 stalled when I was trying to enter a hwy. It later started but I found this hose open. I'm hoping it's the culprit. I'm on my phone with painfully slow Internet so ask for your help... What is this? And where does it go?
Thank you jeepforum.
Jay8five is offline   Reply With Quote Quick reply to this message
Unread 03-16-2015, 11:08 AM   #2
Satrebil
Pic not included. Also, need more details. Please fill out your profile.
01 WJ Limited Inferno Red 4.0L Selec-Trac
04 WJ Limited Inferno Red 4.7L Quadra-Drive
Satrebil is offline   Reply With Quote Quick reply to this message
Unread 03-16-2015, 11:10 AM   #3
Jay8five
It says error when I try. I'll get them up asap
Unread 03-16-2015, 11:15 AM   #4
Jay8five
[/IMG]
Unread 03-16-2015, 11:18 AM   #5
Jay8five
Unread 03-16-2015, 11:24 AM   #6
Jay8five
I apologize. Pics should be up now.
Unread 03-16-2015, 11:31 AM   #7
BlakeCary
At home for lunch and just checked. 99% sure that's the Evaporator drain. Mine is open also. Any codes? When you turn the key is it crank no start?
BlakeCary is offline   Reply With Quote Quick reply to this message
Unread 03-16-2015, 11:41 AM   #8
Jay8five
After it died on me, it wouldn't start, 10 min later I tried again and it ran normally, I'm now in a parking lot researching this issue.
That open hose was the first thing I saw and I was hoping it was the culprit
Unread 03-16-2015, 11:45 AM   #9
ChrisHager
ChrisHager's Avatar
Sounds to me like the Crankshaft Position Sensor is on its way out. I recommend checking for any codes first.
If it is the CKS: 2004 4.0 Crankshaft Position Sensor Replacement
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 03-16-2015, 11:45 AM   #10
JTS97Z28
Yeah that's definetely just a drain and not ur culprit. Like others have said are you getting any codes?
JTS97Z28 is offline   Reply With Quote Quick reply to this message
Unread 03-16-2015, 11:47 AM   #11
Jay8five
Thanks guys, I have no codes.
Unread 03-16-2015, 11:48 AM   #12
Jay8five
Yesterday on the highway, the jeep jerked and turned off my cruise control.. Other than that, it drove fine.
Unread 03-16-2015, 12:44 PM   #13
fiveseven15
when my crank/cam position sensors were going out they wouldnt always throw a code....would get stalling, bucking right before it died, wouldnt restart if it was hot. had to let it sit for a bit
fiveseven15 is offline   Reply With Quote Quick reply to this message
