I blowed up another PS pump! WTF!?!? - JeepForum.com
post #1 of 9 Old 03-22-2010, 08:21 AM Thread Starter
Crewdude007
2000 WJ, 4.0L, about 165K, no lift, not wheeled, DD.
My factory original PS pump on my WJ died in November with about 160K on it so I replaced it. Followed all the advice I could find, i.e. used the correct fluid, bled all the air out, etc. Well, the replacement pump died on me on Saturday. I was sitting at a stop light when I saw smoke and smelled something burning. Sure enough, the pump had puked all over itself. Now I need to get the replacement replaced. It lasted less than 4 months. What did I do wrong? Was this just a bad pump? Should I install an inline filter to get rid of any crap that may still be in the lines? Any advice?
BTW, I did search for this first. I just want to hear what you all have to say.
Currently Jeepless
2001 XJ - SOLD
2000 WJ - SOLD
Crewdude007 is offline
post #2 of 9 Old 03-22-2010, 12:12 PM
kadetklapp
1997 XJ Cherokee
Reman pump? My guess is a junk pump. Unless you got a factory new part from the dealer, it's a crap shoot. Does your Jeep have a power steering cooler? If so, it's possible that fluid is not getting cycled back into the reservoir fast enough or at all.
**1997 Jeep Cherokee SE**
Former Police Car assigned to 54-26, RIP.
kadetklapp is offline
post #3 of 9 Old 03-22-2010, 01:01 PM
ZeeJay1997
If it's the reservoir seal, be sure your cap is venting reservoir pressure out
ZeeJay1997 is offline
post #4 of 9 Old 03-22-2010, 03:59 PM
bigbill888
You just have a leak somewhere. I bet the pump is fine.
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #5 of 9 Old 03-22-2010, 04:25 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
the high pressure hose likes to take a dump from time to time. check that out before you throw another pump at it.
ratmonkey is offline
post #6 of 9 Old 03-22-2010, 04:26 PM
ZJcrawler45
you "blowed" it up? lolllllllllll its blew
Captain Nate
ZJcrawler45 is offline
post #7 of 9 Old 03-23-2010, 08:13 AM Thread Starter
Crewdude007
I'm sure it's not just a leak. I checked it periodically b/c it made noise at full lock turns ever since it was installed and there wasn't a drop of ps fluid anywhere until it died. Then it was everywhere. It was pouring out the top of the reservoir even with the cap still on and tight.
I replaced that hose when I put the pump in. It's only 4 months old as well. I'd rather just replace the pump since it's under warranty instead of spending a week fighting with the hose.
Lol. I know.
When I install the new pump (probably tomorrow), should I flush the old fluid out of the lines first?
Currently Jeepless
2001 XJ - SOLD
2000 WJ - SOLD
post #8 of 9 Old 03-23-2010, 08:44 AM
StellaTheZJ
There's a TSB on the WJs for hoses that rub each other. Usually the owner complains about a noise or vibration, and the dealership bends them a bit further apart or something. Check this out just in case it's a hose that's rubbed through. I think you'll find info on this on on WJJeeps.com - Jeep Grand Cherokee WJ 1999-2004
StellaTheZJ is offline
post #9 of 9 Old 03-23-2010, 12:33 PM
bigbill888
Making noise at full lock is normal. Put another pump in, it's your $$
All work well
power steering pump , pump , steering
water pump + power steering pump z rated ZJ Grand Cherokee Forum 3 09-16-2014 05:50 AM
New power steering pump and pressure hose, now excessive pump noise Jeeples ZJ Grand Cherokee Forum 14 03-15-2011 03:59 PM
New aftermarket high quality fuel pump? second pump in 3 years?!!!!? SPL Tech ZJ Grand Cherokee Forum 8 11-02-2010 05:12 PM
'96 GC 5.2 -- Oil pump help please.... gp49 ZJ Grand Cherokee Forum 2 11-08-2006 03:24 PM
Fuel pump wont pump Sakman ZJ Grand Cherokee Forum 14 05-15-2006 06:41 AM
