Humming Sounds While Driving - JeepForum.com
post #1 of 4 Old 04-16-2014, 03:40 PM Thread Starter
crizo
Wj Humming Sounds While Driving
Hi guys,
I'm having an issue with my '02 Overland that I can't seem to figure out. As I'm driving there's a constant humming sound coming from somewhere under the car sounds to be around the front end. Fist off I know I need new wheels they are worn and don't appear to be the worn evenly possibly an alignment issue I ordered new tie rods,track bar and pitman arm want to install this stuff before I get an alignment done. My jeep is all time all wheel drive so I know this causes stress on the transfer case. However I've had the jeep for about a year and never had the issue till recently the sound is loud and annoying Does anyone know what could cause this or anyone experience this before?
Thank You
crizo is offline
post #2 of 4 Old 04-16-2014, 04:36 PM
Amadauss
When I hear about a humming noise, usually think wheel bearings. Any wet looking stuff on the inside of your tires?
1999 Jeep WJ, 78,072 miles new adco sway bar in rear. new rotors hubs and caliphers, new cv axles up front, Repainted-all black. steering system better stabilizer new tie rods and tubes. New shocks.
Amadauss is offline
post #3 of 4 Old 04-16-2014, 04:41 PM
pinky2252s
Originally Posted by crizo View Post
Hi guys,
Thank You
It could be the wheel bearings, but normally they produce a squeak. It may also be the differential (case) side bearings. Does the sound change with speed?
The transer case is made to operate in AWD (247). Driving it normally puts no stress on it at all.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #4 of 4 Old 04-16-2014, 06:06 PM
TexomaSmitty
X3 on the bearings. When my left rear started going bad it made a low pitch "humming" sound. When i replaced the hub I jacked up my ABS sleeve and had to replace it too, just FYI to go easy if you plan on doing it yourself.
TexomaSmitty is offline
