Huh?? What is it??? - JeepForum.com
post #1 of 8 Old 05-07-2014, 04:26 PM Thread Starter
DanniK13
Huh?? What is it???
Hi! I'm new to working on vehicles, but I can fix almost anything when put to it. So can anyone explain this to me?
The hose is covered in a very clean oil. It doesn't look like engine oil. It drips every so often.
Help?
DanniK13 is offline
post #2 of 8 Old 05-07-2014, 04:31 PM
Jeeples
Jeeples's Avatar
Power steering hose.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #3 of 8 Old 05-07-2014, 04:41 PM Thread Starter
DanniK13
That's what I was thinking but the question is, should I just replace the hose? Power steering goes out when I try to park or cuts on and off while driving. Should I think about doing the pump too?
DanniK13 is offline
post #4 of 8 Old 05-07-2014, 04:42 PM
gold01wj
Does it have fluid in it??? If it's been run low for a while the pump is probably shot
2000 wj limited quadradrive 4.7 family vehicle-was stock, then lifted 4",now stock again
gold01wj is offline
post #5 of 8 Old 05-07-2014, 04:46 PM Thread Starter
DanniK13
It is 100% full, that's why I'm stumped.
DanniK13 is offline
post #6 of 8 Old 05-08-2014, 09:28 AM
Jeeples
Jeeples's Avatar
I had a similar experience with an aftermarket A1 Cardone pump, where the power assist would cut out when turning the wheel at low speed (parking lots, turning from a stop light, etc). It took a couple of tries to get a pump that was quiet like the OE pump or wouldn't randomly cut out. If I were to do it again I would go with a reman'd Mopar pump.
Jeeples is offline
post #7 of 8 Old 05-08-2014, 10:09 AM
Double E
Double E's Avatar
Common replacement item.
You're losing pressure and air goes in & out, reducing assistance. Do not overfill that reservoir.
Take great care in putting the new hose in. It's easy to cross thread. Carefully examine the part the dealer provides you as a replacement too as some have reported getting a part that was not right.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #8 of 8 Old 05-08-2014, 12:04 PM Thread Starter
DanniK13
Thanks so much for the help! I really appreciate it!
DanniK13 is offline
