howell noise in four wheel drive - JeepForum.com
post #1 of 4 Old 01-22-2014, 06:24 PM Thread Starter
hullfm
I started noticing a howelling noise in full time four wheel drive today but only on deceleration, its a 04 grand cherokee 4.0 selectract, any ideas would be appreciated, thank you
hullfm is offline
post #2 of 4 Old 01-22-2014, 06:29 PM
cykaaro
How's your front driveshaft?
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #3 of 4 Old 01-22-2014, 06:32 PM Thread Starter
hullfm
Not sure, it has 90,000 miles on it, and just put a new transmission in it, ill check the u joints , sounds like its coming from the xfer case
hullfm is offline
post #4 of 4 Old 01-28-2014, 07:52 PM
berndog67
2003 WJ
with transfer case noise only in 4 wheel its usually a worn chain, but not always, def start with checking the driveshaft u-joints, also check the fluid level, if both check out u might have to throw a chain in it, they sell rebuild kits and they arn't too bad to do if u take your time, much much easier than say a trans
2003 WJ Overland, 4.7HO, D30 & D44A (1 tons going in now!), RC Long Arm, lifted 4" Front 6" Rear, RC 2.2 4" Shocks, JKS track bar, custom hi-steer, 35" Procomp M/T's on JK rims, beefed up Overland rock rails, custom skids and dif gaurds, Rugged Ridge 8500 synthetic winch in custom hidden mount
berndog67 is offline
