How to tell if you have Up Country Suspension? - JeepForum.com
post #1 of 35 Old 05-10-2011, 06:45 PM Thread Starter
99JGCWJ
So I did my TRE's and brought the Jeep in for an alignment. I picked it up and didn't really look at the top of the sheet as I was more concerned with the numbers. Driving home it drove great steering is tight, wheel is straight and everything is fine. So I go to put the paperwork in my book (Yes, I keep a Jeep book with all work I've done ie: part receipts or receipts for work I've had done at my mechanic) and on the top I see Jeep : Grand Cherokee :1999-2004 (WJ) 4x4 : except Up-Country Suspension. It doesn't say anything about it on my build sheet from Jeep. So I call the shop and ask the guy does that mean I have this on my Jeep and his answer was "They either put that in when the Jeep has it or doesn't have it I'm not sure which". I said "ok, thanks" and hung up. So now I come to the experts asking how can I tell if I have it? Thanks in advance for the help.
SIX IN A ROW MAKES IT GO!!!
99JGCWJ is offline
post #2 of 35 Old 05-11-2011, 06:17 AM Thread Starter
99JGCWJ
Bump.
Sent from my VM670 using JeepForum
99JGCWJ is offline
post #3 of 35 Old 05-11-2011, 08:35 AM
brianestep
As far as I know (unless the PO, assuming there was one, only upgraded springs and shocks) the Up Country package also includes tow hooks, skid plates, and "upgraded" tires, I'm thinking 245/70's. WJJEEPS lists all the features of the package, so check them out. I don't have access to it here at work, or I'd tell you for sure.
-Brian- 2000 WJ Four liter, 4" RC springs; Bilstein 5100s; JKS trackbar w/KOR bushings; Stillen rotors; KOR (RC) 1.5" wheel spacers; 265/75/16 Treadwright Guard Dogs; Rusty AirTube, Amsoil Cone; Thule M.O.A.B.; Bumper delete; rear seat disco
brianestep is offline
post #4 of 35 Old 05-11-2011, 08:42 AM
brianestep
Also, the word "except" would steer me to believe you don't have it. Meaning that all Upcountry WJ's that shop sees would just be called "Jeep WJ (1999-2004): Standard" or something like that.
post #5 of 35 Old 05-11-2011, 09:29 AM Thread Starter
99JGCWJ
I figured I didn't have it and yes there was a po. I only have on skidplate on the gastank and that's it. Thanks.
99JGCWJ is offline
post #6 of 35 Old 05-11-2011, 09:37 AM
rm2001wj
rm2001wj's Avatar
Probably the specified range values apply only to those WJs without the Up-Country suspension. They may be different for an Up-Country suspension.
rm2001wj is offline
post #7 of 35 Old 05-11-2011, 12:26 PM
jemrey81
I have an 01 UpCountry... your build sheet would say if it was UC... my build sheet says:
AWE Up Country Suspension Group
SDUP Heavy Duty Suspension w/Gas Shocks
ZLEP Spring - Left Front
ZLVP Spring - Left Rear
ZZEP Spring - Right Front
ZZVP Spring - Right Rear
As far as the skid plates go:
ADLP Skid Plate Group
XEEP Fuel Tank Skid Plate Shield
XEFP Transfer Case Skid Plate Shield
XEUP Front Suspension Skid Plate
As far as the tires - they are the same size as any other WJ with the 17", Goodyear All Terrain 235/65/17.
You can also measure your center of wheel to fender and see what it is.... I think UC is around 19" - I could be wrong.... maybe it's 18"?
jemrey81 is offline
post #8 of 35 Old 05-11-2011, 12:32 PM
WJHahn
Yup. Get your build sheet from Jeep, do a search here for the link. Mine took about 2-3 days before they replied.
WJHahn is offline
post #9 of 35 Old 05-11-2011, 01:51 PM Thread Starter
99JGCWJ
I have my build sheet and it's not on there but I'm not the original owner either so I wasn't sure what the PO did to it.
99JGCWJ is offline
post #10 of 35 Old 05-11-2011, 01:58 PM
little_Jeep
I ordered my 2000 WJ with the Up Country package. There is no PO. On my 2000 WJ, tow hooks, skids, upgraded tires (245/70/16) and upcountry springs were all part of the Up Country package. There may have been more, but I'd have to hunt up my build sheet to tell you for sure.
Click http://www.jeep.com/wccsapp/universa...ull&category=U here to order a build sheet for your Jeep........ it's free.
little_Jeep is offline
post #11 of 35 Old 05-11-2011, 01:59 PM
Hack
2003 WJ
I just looked at the tag on my springs and cross referenced the part numbers with wjjeeps.com
Hack is offline
post #12 of 35 Old 05-11-2011, 02:04 PM
brianestep
Why did you quote me on this and then say exactly what I said? haha
post #13 of 35 Old 05-11-2011, 02:53 PM
little_Jeep
Because you were not sure if you had the Up Country package on your Jeep, or if the PO upgraded the springs. I was confirming that I know you are correct because I ordered my WJ and there isn't a PO of my Jeep.
post #14 of 35 Old 05-11-2011, 04:06 PM
brianestep
Haha not me!!! I was answering the OP's question. I know I don't have Up Country!! Not with my lift, and all...
post #15 of 35 Old 05-11-2011, 04:35 PM
straty1987
seams like your caster and toe need the alignment and your last name is TV
noticed your over in long island. can i ask how much it cost you?
straty1987 is offline
Upgrading to Up Country suspension skreeks WJ Grand Cherokee Forum 9 04-06-2011 11:12 PM
Rough Country ecu2005 WJ Grand Cherokee Forum 11 11-03-2010 03:40 PM
up country springs ssuper_nova_71 WJ Grand Cherokee Forum 31 08-27-2010 07:12 PM
Up country n.code JMOSS WJ Grand Cherokee Forum 5 08-03-2010 02:29 AM
WJ up country suspention? USA_PRIDE WJ Grand Cherokee Forum 6 02-02-2009 07:52 PM
