How to tell if a ignition coil is going bad - Page 3 - JeepForum.com
post #31 of 37 Old 07-22-2014, 05:07 AM
86cj74.2L
86cj74.2L's Avatar
Originally Posted by outofrng623
Two round trip drives this week that would normally trigger the p0420...Did not. The only differences are, I put in a new battery (yes I have disconnected and reset prior to changing), so its not the reset, maybe the voltage...and I disconnected my obd2 scanner.
So you hooked the ground strap back up too?
Plus you always has good highway milage. Correct? Just crapy city milage and the P0420 code at times with a new CAT.
86cj74.2L is offline
post #32 of 37 Old 07-22-2014, 06:39 AM
outofrng623
Didn't touch the strap yet.
Highway is usually pretty good and the code throws cause that's part of the test parameter to test it. 40-50 mph x rpms x amount of time etc.
Without a doubt both of those trips, round trip, would've set the code 4 times after resetting cel each leg of the trip.
outofrng623 is offline
post #33 of 37 Old 09-08-2014, 04:04 PM
outofrng623
I am sure you (86) have seen it already, but for everyone else, ground strap was replaced again, no change. Injector leakdown and compression test done, both pass with flying colors. Smoke test also done, no leaks...
post #34 of 37 Old 09-08-2014, 04:28 PM Thread Starter
Gunrunner23
Reflash yet?
2004 wj limited 4.7
IRO 3in lift with skyjacker hydro
265/75/16 TreadWright Claws
Gunrunner23 is offline
post #35 of 37 Old 09-08-2014, 06:48 PM
outofrng623
The two tests were done today, so...my reflash debate is in my head. Do I spend 125 to reflash and take the chance on the pcm actually being good or do I find a refurb ecm?
post #36 of 37 Old 09-08-2014, 07:43 PM Thread Starter
Gunrunner23
Hmmmm good point. I would imagine if the pcm was bad more would be wrong from what I've read. But you never know. Same goes for if u get a new pcm, will it be updated? I'd hope.
2004 wj limited 4.7
post #37 of 37 Old 09-08-2014, 08:12 PM
SleepyFloyd
A bit late on the topic but a good way to test coils is to just shoot some water on them with a spray gun during idle. If it bucks and miss-fires then the insulation is flawed and you're arcing.
SleepyFloyd is offline
Ignition coil O-rings steelstr45 WJ Grand Cherokee Forum 9 12-10-2013 03:19 PM
High Performance Ignition Coil packs for 4.7l?? ddusmc WJ Grand Cherokee Forum 17 06-11-2012 07:53 PM
Ignition Coil Install for '99 Grand Cherokee Laredo L6 4.0L bearhug9 WJ Grand Cherokee Forum 5 08-30-2011 09:53 AM
ignition coil jeepjeepgc99 WJ Grand Cherokee Forum 3 12-06-2010 10:26 AM
WJ Ignition Coil Packs safari2000 WJ Grand Cherokee Forum 0 11-15-2010 06:27 PM
