How to tell if a ignition coil is going bad - JeepForum.com
post #1 of 37 Old 06-28-2012, 07:55 PM Thread Starter
Gunrunner23
My phone accidentally posted this in the wk threads. Is there a way to tell if a coil is going bad without a voltage meter? I looked on google but couldn't really find anything. Looked at a rx8 forum and something about a white scoring mark. Id buy 8 new ines but that's 160-200 dollars.
2004 wj limited 4.7
IRO 3in lift with skyjacker hydro
265/75/16 TreadWright Claws
Gunrunner23 is offline
post #2 of 37 Old 06-28-2012, 08:41 PM
boomersoonerGC
If you can visually see they are bad then they are likely very bad. Its possible for them to get weak but you would need to test them with a multimeter.
boomersoonerGC is offline
post #3 of 37 Old 06-28-2012, 08:50 PM Thread Starter
Gunrunner23
I didn't know if there would be obvious scoring. Olive changed the plugs and remember the out side of one looking rough but didn't think anything of it. All the plugs were crap. Wish I remembered which one it was.
2004 wj limited 4.7
post #4 of 37 Old 06-28-2012, 08:53 PM
Jacko84
Do you have any symptoms?
02 WJ Limited | 4.7L HO | quadra-drive | 3" KOLAK lift: Bilstein 5100s shocks, OME HD coils | Moog steering stabilizer | JKS adjustable track bar | 245/70R17 General Grabbers | 17" JK MOABS
Jacko84 is offline
post #5 of 37 Old 06-28-2012, 08:59 PM Thread Starter
Gunrunner23
Yeah fighting a rough idle and low idle when coming to a stop. I've done all the typical stuff. I've scanned and checked my rpm matching what the dash says.
2004 wj limited 4.7
post #6 of 37 Old 06-28-2012, 09:05 PM
Jacko84
What's the "typical stuff"? Sounds like your problem may be the TPS, IAC or you need to clean your throttle body. Visit this page for more info on how to take care of those 3 things: http://wjjeeps.com/service/tbody.htm
Jacko84 is offline
post #7 of 37 Old 06-28-2012, 09:16 PM Thread Starter
Gunrunner23
Yeah that's the typical stuff. I've been there some that... took of the tv cleaned it. Cleailned IAC replaced the TPS checked map replaces fuel filter. Ran scanner tool.
2004 wj limited 4.7
post #8 of 37 Old 06-28-2012, 09:17 PM Thread Starter
Gunrunner23
Sorry damn phone auto correct. Been there done that** And TB**
2004 wj limited 4.7
post #9 of 37 Old 06-28-2012, 09:22 PM
Jacko84
Sometimes just cleaning the IAC doesn't do it, may need a new one i had similar symptoms in my 4.7L HO, at stop lights the rpms would drop and idle rough, I got an aftermarket TPS a few months ago and it was good for a few weeks, then the symptoms were back. 3 weeks ago I got a MOPAR TPS and it's back to normal idle and no kore drops in rpm. I've heard a lot of folks having issues with off brand sensors. Have you replaced your plugs? Is it a regular 4.7L or the HO?
Jacko84 is offline
post #10 of 37 Old 06-28-2012, 09:29 PM Thread Starter
Gunrunner23
Regular. I replaced them a month ago. I opted for a bwd because bord-warner is a pretty good brand. Plus 1 year warranty.
2004 wj limited 4.7
post #11 of 37 Old 06-28-2012, 09:44 PM
boomersoonerGC
BWD has done nothing good on my WJ. Every single BWD sensor has been replaced by Mopar and gotten much better results.
Mopar parts, if purchased from an authorized dealer, offer a 12mo 12000mi warranty too.
post #12 of 37 Old 06-28-2012, 09:45 PM
Jacko84
^^ this!
Jacko84 is offline
post #13 of 37 Old 06-28-2012, 09:48 PM Thread Starter
Gunrunner23
Its my understanding that a bad TPS jacks the rpms way up. Which is why I was gonna buy a IAC tomorrow.
2004 wj limited 4.7
post #14 of 37 Old 06-28-2012, 09:56 PM
Jacko84
Not necessarily... Just rough idle in general for most people
Jacko84 is offline
post #15 of 37 Old 06-28-2012, 10:09 PM Thread Starter
Gunrunner23
It's not THAT rough. Just not steady. But dips down to 350-400 rpm at some stops.
2004 wj limited 4.7
Ignition coil O-rings steelstr45 WJ Grand Cherokee Forum 9 12-10-2013 03:19 PM
High Performance Ignition Coil packs for 4.7l?? ddusmc WJ Grand Cherokee Forum 17 06-11-2012 07:53 PM
Ignition Coil Install for '99 Grand Cherokee Laredo L6 4.0L bearhug9 WJ Grand Cherokee Forum 5 08-30-2011 09:53 AM
ignition coil jeepjeepgc99 WJ Grand Cherokee Forum 3 12-06-2010 10:26 AM
WJ Ignition Coil Packs safari2000 WJ Grand Cherokee Forum 0 11-15-2010 06:27 PM
