How to replace front axle seal? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > How to replace front axle seal?
Build your Dream Jeep with Poison Spyder's Interactive GarIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 06-24-2011, 12:59 PM   #1
Thomahawk
JEEP ADDICTED
Thomahawk's Avatar
Noticed today both My front rims inside was covered with oil.
I am thinking it is the front axle seals, How to replace Them?
Do i pull the brakes and the 4 bolts holding the axle, pull the axle and replace the seal?
I have done the rear bearings and seal before, Where We Had to cut of the washer and press of the bearing.
Is it the same in the front or is it a simple pull Axel and change the seal?
2000 Grand Cherokee Limited ¤ 4.7 Low output V8 ¤ 545RFE ¤ Quadradrive ¤ Shale Green Metallic ¤ Agate/Carbon interior ¤ Viper 5704 alarm/remote start ¤ Alpine HU ¤ Rockford Fosgate P500-4 +P500-1bd ¤ 4X Infinity Kappa 60.9CS +1X 100.9W ¤ Rugged Ridge floor mats ¤ LED interior light ¤ Tinted windows ¤ Grill mesh mod ¤ Spyder halo headlights ¤ Spyder halo foglights ¤ 6" Hella`s 500 Black magic Lights ¤ Debadged ¤ Rear Wiper Delete ¤ Spyder LED taillights ¤ Smoked LED third brakelight ¤ LED licence plate light ¤ Saguaro 3/4in recovery shackles ¤ 3" Kolak exhaust Magnaflow cat Flowmaster 70 muffler ¤ Superchip ¤ TM snip mod ¤ 2" BDS springs ¤ Bilstein 5100 shocks ¤ Addco swaybars ¤ JKS trackbar ¤ JKS front discos ¤ IRO rear ext endlinks ¤ Moog super trial boss SS ¤ BTF Cryptonite diffcovers ¤ Stillen Rotors/Black matrix pads ¤ Pro Comp 17`s Helldorado Machined polished w/General Grabber AT2 255/70/17 ¤ JK Sahara 18`s w/Nokian Hakkapelitta R SUV 255/60/18 ¤ Urban Assault Vehicle
We dont care how they do it in Japan!
Buildthread ¤ http://www.jeepforum.com/forum/f197/...orway-1193503/ ¤
Thomahawk is offline   Reply With Quote
Unread 06-24-2011, 01:48 PM   #2
Buddha_Kip
Perpetually Lost
Buddha_Kip's Avatar
  • pull wheels
  • open diff cover
  • remove inner axle seals with a prybar
  • remove any remaining sealer from original seals
  • install new seals with special tool discs 8110 and turnbuckle 6797...or you can make your own with threaded rod, 4 bolts, elevator washers and a turnbuckle.
  • re-install diff cover
  • fill with oil to spec.
pic of special tool and install to give you an idea what to make -
2000 WJ Limited - 2.5" Rusty's springs ¤ WAAG 1-piece front brush guard ¤ custom built WAAG nerf bars ¤ PIAA 580 lighting ¤ Custom Paint ¤ Custom Aluminum Treadplate Door Entry Guards ¤ Custom Aluminum Treadplate Rear Bumper Step
1986.5 Porsche 928S - 18" Moda MD1 ¤ Autothority Chips ¤ Rear Muffler Bypass ¤ Short-Shift Kit
Buddha_Kip is offline   Reply With Quote
Unread 06-24-2011, 01:51 PM   #3
roach68
Is it your CV boots Torn?
FOR SALE.
PAC SWI-Jack Steering wheel control interface-$35 shipped
roach68 is offline   Reply With Quote
Unread 06-24-2011, 01:56 PM   #4
Thomahawk
JEEP ADDICTED
Thomahawk's Avatar
I have to check but i got new axle and cv joint and boot installed in january when i was on vacation. So i dont Think its cv boot and it Looks like oil not grease.
Unread 06-24-2011, 01:56 PM   #5
Buddha_Kip
Perpetually Lost
Buddha_Kip's Avatar
if it's the cv's it'd be more big blobs of grease instead of oil.
Unread 06-24-2011, 01:59 PM   #6
Thomahawk
JEEP ADDICTED
Thomahawk's Avatar
Originally Posted by Buddha_Kip
[*]pull wheels[*]open diff cover[*]remove inner axle seals with a prybar[*]remove any remaining sealer from original seals[*]install new seals with special tool discs 8110 and turnbuckle 6797...or you can make your own with threaded rod, 4 bolts, elevator washers and a turnbuckle.[*]re-install diff cover[*]fill with oil to spec.
Ok, Thanks man. As i understand the front is not same as the rear. The rear have the seal out on the axle, outside the bearing.
The front axle seal is inside the diff, right?
Do i need special tool or How to Go, Sorry i am Really stupid...... Lol
Unread 06-24-2011, 02:07 PM   #7
Buddha_Kip
Perpetually Lost
Buddha_Kip's Avatar
no. pry them off with a prybar or flathead screwdriver. jeep techs use a special tool (listed in my post) but if you look at the picture i posted, you can make that tool with some threaded rod (or two bolts) a couple nuts, a couple fender washers, and a turnbuckle. i'll sketch up the homemade special tool and post.
Unread 06-24-2011, 02:13 PM   #8
Thomahawk
JEEP ADDICTED
Thomahawk's Avatar
Thanks alot Buddha_kip, you Are the man.
Ok i Think i Get it, i need this to press the seal into place. The tool press outwords and put the seals into place, right?
Do i need to Take out the diff from the diff housing or can it be done with axle and diff still in place?
Do i have to pull out the axles?
So There no seal out on the axle?
Unread 06-24-2011, 03:50 PM   #9
nickblack
You need to pull out the whole differential. Make sure you don't mix up the bearing caps and keep all the shims in the same order and on the same side. And, yes you need to pull the half shafts too.
nickblack is offline   Reply With Quote
Unread 06-24-2011, 04:17 PM   #10
Thomahawk
JEEP ADDICTED
Thomahawk's Avatar
AaaaaHHHHHH. Fcuk.
My mecanic friend started his Holiday today, and i dont Think i can do this myself without a Garage, a lift, all the proper tools, torque wrench tool etc.
I love My Jeep when everything works.
Unread 06-24-2011, 05:20 PM   #11
Thomahawk
JEEP ADDICTED
Thomahawk's Avatar
So If i understand this right, the procedure is:
Pull wheels
Pull brakes
Pull axels
Pull diff cover
Pull diff
Replace new seals
Mount diff, axles, brakes, diff cover, fluid, wheels.
That's all, right? Rofl
Unread 06-24-2011, 06:17 PM   #12
Thomahawk
JEEP ADDICTED
Thomahawk's Avatar
Found this write up,
http://www.stu-offroad.com/axle/d30seals/seal-1.htm
Looks like to much fun for me....
Unread 06-25-2011, 07:34 AM   #13
Thomahawk
JEEP ADDICTED
Thomahawk's Avatar
Anybody That have the part number/OEM number for the axle seals for this? (dana30 front diff)
Are There Any aftermarket ones or only the OEM parts for this?
Thomas
Unread 06-25-2011, 11:45 AM   #14
Thomahawk
JEEP ADDICTED
Thomahawk's Avatar
Found the part at teamgrandcherokee.com
Omix Brand direct replacement OE style front inner axle seals dana 30. Pair fit inner seals #16526-02
Price 9.95$
Anybody used this or should i Go for OEM? Anybody That have the OEM/mopar number for These seals?
Unread 06-25-2011, 10:13 PM   #15
Buddha_Kip
Perpetually Lost
Buddha_Kip's Avatar
the OEM number for the seals is - 4874 477
I've never had any problem with Omix stuff.
this may help you out for future endeavors...full parts catalog for your year WJ - http://members.cox.net/clasikautollc/00WJ.pdf
it's in pdf form. you can just right click, save as,, or just access it from where it is.
