How to replace an axle shaft and/or a wheel hub bearing assembly w/PICS! - Page 7 - JeepForum.com
 4Likes
post #91 of 340 Old 02-15-2009, 06:25 PM
thehun13
Thanks for the great write up....I never touched and axle before and was able to do a front brake job and replace my trashed CV joints with u-joints. All in all it took about 2 hours. The hub bolts were the hardest to remove, cant get a impact back there but a box end and a 5lb sledge works great...
thehun13 is offline
post #92 of 340 Old 02-16-2009, 09:43 PM
jeepmanW11
99 jeep cherokee cv joints
How do you change cv joints on 99 jeep grand cherokee? I was watching the 96 replacement and looks easy. Is it the same? Reading manual it says I have to measure the cv joint cup to cv boot end.5 - 39/64 inches. Need help.
jeepmanW11 is offline
post #93 of 340 Old 02-16-2009, 09:52 PM
thudson331
exactly like this thread shows
Good tattoos aren't cheap, Cheap tattoos aren't good!
thudson331 is offline
post #94 of 340 Old 02-16-2009, 10:02 PM
jopolly3
great write up... i did a few things this weekend that i thought might leave me needing this info, this makes me feel slightly more confident i could handle things
Joe
2013 JKU Rubicon 6spd: ARB Dana 44 covers F&R, Expedition One front bumper & swaybar skid, Hella driving lamps, JKS adjustable track bars F&R, MBRP SS off-road exhaust, OME HD springs and shocks, OME relocated SS, Rock Hard 4x4 gas tank skid, Rock Hard 4x4 oil pan skid, Rock Hard 4x4 rock sliders, Rock Hard 4x4 transfer case skid, Spidertrax wheel spacers, Superwinch LP8500 Gen 1
2002 Subaru WRX: Cobb intake, Mishimoto aluminum radiator, Kartboy short throw shifter and bushings
1960 CJ-6: Never ending project rig
Build Threads:
JKUR -
CJ6 -
WJ -
"BFG makes some good rubbers, if they sold condoms I'd buy them" -Owen Horner
jopolly3 is offline
post #95 of 340 Old 02-16-2009, 10:57 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Only "difficult" part to this job can be breaking the 3 knuckle bolts, the hub nut, or pulling off the wheel bearing assembly from the knuckle. In all three cases...rust sucks
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #96 of 340 Old 02-16-2009, 11:00 PM
RickyZJ
This writeup helped me a ton
Also found these videos on youtube of the step by step replace of the cv axle on a 94 ZJ, if you need a little extra help
Part 1
Part 2
Part 3
1996 Grand Cherokee -- 4.5" IRO, 35's, Long Arms, so on and so forth.
RickyZJ is offline
post #97 of 340 Old 02-17-2009, 02:16 AM
SoCalDevyn
nice write up
ive had to replace both my left and right hubs after some good muddin
98 ZJ Limited 5.2, Blacked Out, 6.5" IRO Long Arm, 15x8 Pro Comp 97's, 35" MTZ's, Custom Front Bumper, Rusty's Disco's, KOR Light Bar, 8000K HID's, Magnaflow, CB, 5% Tint, System, TJ Gas Bezel, JKS Rear Trac Bar, Rusty's Front Trac Bar, KOR Stabilizer, Cold Air Intake, E-Fan, RCX Diff Guard, Clayton Brake Lines, MSD Ignition, Gen Right Louvers, Custom Sliders, IRO Belly Skid, Rigid Lights
SoCalDevyn is offline
post #98 of 340 Old 02-17-2009, 07:37 AM
YJdad
use the socket behind the hub if you have a buddy and watch your fingers!..this is actually easier than it looks..
94' YJ Stock 2.5L -
/ BFG 30x9.5x15 / Herculiner / Stereo console - Currently parked for overhaul
98' ZJ GCL - Stock V8
75% of the world is covered by water, the rest is covered by Jeep!
YJdad is offline
post #99 of 340 Old 03-02-2009, 02:50 PM
RichieW13
I replaced my hubs over the weekend. That ended up being a pretty easy project. I had one hub bolt that was difficult to remove. Once I bought a longer breaker bar, it broke free pretty easily. I was able to do the second hub in less than an hour.
The only problem is the grinding noise from the front end is still there! The old hubs seemed to be in decent shape. So now there is either something wrong with something in the axle assembly or it's just the natural sounds that come from having an AWD front end.
1998 Grand Cherokee 5.2L V8
14.1 MPG :(
RichieW13 is offline
post #100 of 340 Old 03-02-2009, 03:21 PM
CrazyWalnut13
I'd check out your CV joints on the front DS.
Zak
Formerly Default Jeeper #13
2000 WJ Limited 4.7 with stuff. Look left for the deets.
CrazyWalnut13 is offline
post #101 of 340 Old 03-16-2009, 05:40 PM
chrisbranham
A 99 WJ with Quadra-drive would need the Vari-Lok axles correct? I am replacing the left one.
chrisbranham is offline
post #102 of 340 Old 03-19-2009, 08:55 PM
hfjeff
hfjeff's Avatar
Son's first Jeep and I have to fix it already
Jumping over from the CJ forum where I gained years of knowledge from many great fellow jeepers.
Got my son his first vehicle: 1996 GCL with the 5.2 and 116K miles. Brought home and discovered the CV boots were torn in half and joints full of gunk. That would explain the ticking or cracking when backing up with the wheel turned. Panicked a bit at first until I searched and found this thread. If I built my CJ7 from scratch including rebuilding the transmission and t-case, I should be able to handle the front shaft swap. They are fairly cheap ($54 at the local Napa) and this thread will be a great help.
Looking forward to learning a lot more from the GC forum. Have several more repairs to make. Thanks.
MINE: 1995 YJ/2.5L/115K/Completely Stock
MY DAD's: 1978 CJ7/ AMC 360 .030" over/ Motorcraft 2100/ Edelbrock Performer/ Proform HEI Ignition/ Hedman Headers with dual Flowmaster 40's/ Taurus Fan/ FK-35 Control/ Painless Harness/ Rebuilt T150 & Dana 20/ 4" Lift/ 31" Procomp Mud Terrains/ All Fiberglass. (SOLD)
MY BROTHER's: 1996 ZJ Limited/5.2L/117K & Completely Stock.(SOLD)
hfjeff is offline
post #103 of 340 Old 03-19-2009, 09:39 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Good luck Jeff, hopefully you don't have too much rust on that ZJ...
post #104 of 340 Old 03-19-2009, 10:13 PM
xJoshxx
2012 WK
when in doubt BFH
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #105 of 340 Old 03-21-2009, 08:31 PM
hfjeff
hfjeff's Avatar
One down, one to go. Old woman winter is not kind to chassis and underbodies of vehicles in WI. My trouble isn't that I don't have the right tools or can't get the bolts out. My problem is the rust. It took about 3 hours to get the drivers side done. With all the bolts removed I could not get the hub off. After an hour and a half with a chisel and heavy duty putty knife, it came off. The assembly was cake.
Now on to the passenger side. I have all the bolts out including the hub bolts and the rotor or hub won't come off. Used half a can of PB Blaster and a hammer and pry bar and it won't budge. Any suggestions?
hfjeff is offline
Front wheel bearing/hub replace question EBT531 ZJ Grand Cherokee Forum 7 05-13-2010 07:36 AM
How to replace wheel bearing Mustang ZJ Grand Cherokee Forum 3 03-20-2009 11:56 PM
wheel bearing vs axle bearing. cifer6425 ZJ Grand Cherokee Forum 5 06-21-2007 02:04 PM
Front axle bearing replace wahoo50 ZJ Grand Cherokee Forum 1 03-19-2007 08:41 PM
Need Help!!! front wheel bearing hub assembly 97 JGC FieroGT914 ZJ Grand Cherokee Forum 13 01-28-2007 09:22 AM
