How to replace an axle shaft and/or a wheel hub bearing assembly w/PICS! - Page 11 - JeepForum.com
 4Likes
post #151 of 340 Old 02-01-2010, 12:33 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Yeah the replacement should be the exact same length as the original one...so when you pull the shaft compare them at that point. IIRC there is about a 1" difference between the two. I believe QD shafts are slightly shorter.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #152 of 340 Old 02-01-2010, 12:34 PM
00JGC00
Ok cool. Thx!
"The" Matt | '00 Limited WJ | "The White Wolf" aka "Willow" aka "Cool Whip" aka "Sweet 'N Low" aka "AKA"
Utah JeepCrew #39 | Club Matt #1
December '11 GCOTM | Build: http://www.jeepforum.com/forum/f197/life-times-979511/
00JGC00 is offline
post #153 of 340 Old 02-01-2010, 12:39 PM
adam03wj
2003 WJ
done this plenty of times! never on my jeep though, (mostly wranglers, few pickup trucks) but glad to know if i need to it's real easy. question though, i know on wranglers and some other jeeps the pad snaps into the caliper which makes things real easy when you slip it over the rotor. Is it the same for the WJ? Recently did a brake job on a mazda b2200 and it was a pain in the ***. thanks in advance arlo!
adam03wj is offline
post #154 of 340 Old 02-28-2010, 12:51 PM
00JGC00
Another question. What kind of poundage would an impact wrench need to get that axle nut off?
00JGC00 is offline
post #155 of 340 Old 02-28-2010, 02:21 PM
jtsjeep99
The 3 hub bolts are the biggest PITA I've ever dealt with. I had to heat them up with a torch to melt the large amount of thread locker the factory used then they came out.
JTsJeep99
jtsjeep99 is offline
post #156 of 340 Old 02-28-2010, 02:37 PM
longboy
2006 WK
Theoretically, it's held on with 175lb/ft of torque. But that number can grow immensely depending on rust and scale. I used my impact gun on my '99 and it zipped right off. I think I did let some PB Blaster soak in there for a few minutes beforehand-
2006 5.7l WK
longboy is offline
post #157 of 340 Old 02-28-2010, 03:17 PM
sdowney717
I heated the nut almost red hot with an oxy-acetylene torch and a small tip so the heat stayed mostly on the nut.
Let it cool some and PB Blasted it. Then it came right off.
I then cleaned up the shafts, ended up scraping scrubbing them clean and baked them in an oven at 500 degrees.
I then JB welded the shaft to keep down the rust and replaced the u joint.
I greased it all well when putting it back together.
If you want jb weld to speed up the cure to an hour or less, simply heat the part you put it on to around 120 to 140 degrees.
sdowney717 is offline
post #158 of 340 Old 02-28-2010, 04:07 PM
00JGC00
The impact wrench I got can do 240 lbs I think and I got a can of pb blaster as well. I'm probably going to be tackling this in the next week or two. I want to do it but keep procrastinating because I'm afraid of something going wrong . I just need to man up and get 'er done.
00JGC00 is offline
post #159 of 340 Old 02-28-2010, 04:42 PM
SplitNail
Its super simple. It was the first thing I have ever done to my jeep. I was shocked how easy it was. Just soak the bolts on PB Blast or some liquid wrench and they should come right off.
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #160 of 340 Old 03-06-2010, 08:31 AM
00JGC00
Today is the today! Wish me luck!
00JGC00 is offline
post #161 of 340 Old 04-10-2010, 06:24 PM
kjopen
Great write-up! I followed this today when fitting my new drive shaft - excellent, many thanks.
97 GC TSi
5.2
NP 249 TC
kjopen is offline
post #162 of 340 Old 05-17-2010, 10:07 PM
soul_Less
1994 ZJ
well i just finished the right cv shaft.. those 3 bolts were a PITA, and the hub was seized up real good too.. used A LOT of PB Blaster.
Im not sure if anyone wrote about doing this (i didnt read 10 pages of replies), but to remove those 3 bolts without a torch, i proped the base of the handle of my wrench on the jack and pumped until it was fully extended.. then i readjusted the wrench and repeated.
soul_Less is offline
post #163 of 340 Old 05-18-2010, 07:09 AM
FPKites
ZJjazzyJim
FPKites's Avatar
Just a tip for those that do this - use anti-seize on all bolts as well as the lip of the unit bearing. Makes the next time a whole lot easier.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #164 of 340 Old 05-18-2010, 07:33 PM
Midnightluckey
Awesome write up, just wondering why you didn't switch to u joint shafts? I'm just waiting until i blow another CV and them I'm getting Ujointed shafts.
95 Limited Chargold ZJ 5.2L -5.5" lift (IRO, Ironman, and RC parts), 33" BFG M/T's, 15x8 procomp crawlers, 242 swap, 2 12" subs, 1000w amp, cherry bomb, full skid package, Kevins rear stealth bumper clone w 3/4" D rings, Rlcwelding front bumper w 3/8" D rings, XRC-8, front tow hooks, 2 daylighter fairlead lights, 2 daylighter windsheild lights, 2 55w driving lights, OBA, Cobra 18 CB, dual 4' whips, RC disconnects, smittybuilt jack, optima yellowtop.
Built not bought #512
Midnightluckey is offline
post #165 of 340 Old 05-18-2010, 08:16 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Find me cheap U-joint shafts for a WJ
Front wheel bearing/hub replace question EBT531 ZJ Grand Cherokee Forum 7 05-13-2010 06:36 AM
How to replace wheel bearing Mustang ZJ Grand Cherokee Forum 3 03-20-2009 10:56 PM
wheel bearing vs axle bearing. cifer6425 ZJ Grand Cherokee Forum 5 06-21-2007 01:04 PM
Front axle bearing replace wahoo50 ZJ Grand Cherokee Forum 1 03-19-2007 07:41 PM
Need Help!!! front wheel bearing hub assembly 97 JGC FieroGT914 ZJ Grand Cherokee Forum 13 01-28-2007 08:22 AM
