How to remove Lock cylinder when key will not turn?? - JeepForum.com
post #1 of 8 Old 01-29-2011, 11:01 PM Thread Starter
j_internet
Wj How to remove Lock cylinder when key will not turn??
Hi,
I have a 2002 GC. Was having problems iwth the ignition key and now it will not unlock. I have pulled the colum casing and the console cable so I know that it is the lock cylinder.
From reading the fourms if I get the key to go forward I can depress the tab and it will come out. Thie issue is that I can not move the key forward so the tab will be free to depress.
How can I get the cylinder out? Is there a write up somewhere?
Thanks !!
j_internet is offline
post #2 of 8 Old 01-30-2011, 07:06 AM
mrJ
2002 KJ Liberty
i called a locksmith. he built a cylinder to fit my factory keys for about $200
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #3 of 8 Old 01-30-2011, 08:05 AM
Phranc
Originally Posted by j_internet View Post
Hi,
Thanks !!
Have you tried "bumping" it? Put pressure on the key with one hand, trying to turn it to run. Tap the end with a hammer. You may have to do it a time or two. you may also have to rap it pretty smartly, Be sure to keep the pressure on the key while bumping.
Whoever said, "A boat is a hole in the water to throw money in", obviously never owned a Jeep.
Phranc is offline
post #4 of 8 Old 01-30-2011, 04:09 PM Thread Starter
j_internet
Yes I did try that. I had no luck after a couple of hours in the cold sitting at Mobil at the pumps..... So I ended up taking it apart to start it. I ended up going to the dealer as they would do right away. They socked it too me for 375. Even though I had the colum apart and all they needed to do remove the cylinder and put it back together. So two book hours later... (really took them 45 min) it was done. My question is how did they get it out if the ley would not turn..
post #5 of 8 Old 01-30-2011, 04:18 PM
Phranc
They probably weren't afraid to really smack the crap out of the end of the key to jar the tumblers loose. Or they have some sooper-secret tool.
Phranc is offline
post #6 of 8 Old 01-30-2011, 05:45 PM
compcrasher86
I had the same exact issue on my XJ... key got stuck in the ignition cylinder and I couldnt turn it to get it out. After about 2 hrs in a parking lot one of my friends leaned on the steering wheel which rotated it just enough to disengage the... yupp... you guessed it... steering wheel lock. Yeah turns out all I had to do was wiggle the wheel and it woulda unlatched itself. Glad I didnt call a tow truck. This may have been a contributing factor to your issue. If it was I'd be very dissapointed if the techs charged this long. Chances are they couldnt figure it out either lol and charged you on labor.
Matt
compcrasher86 is offline
post #7 of 8 Old 01-31-2011, 10:33 AM
Double E
Double E's Avatar
That's too bad about the cost on that. For reference, here was my similar issue. Hope it can help someone else out in the future.
http://www.jeepforum.com/forum/f13/k...o-turn-597301/
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #8 of 8 Old 02-07-2013, 04:23 PM
dyanab
Wj key in ignition wont turn
I had this happen to my 2000 GC, had it towed home & husband couldn't get it out. This afternoon I was so mad. I got in the jeep, put key in and pushed hard while turning to start, (with left hand) then with right hand hit the end of key with hammer 3x while I had pressure holding the key in and turning to start. It finally released!!. So if you use the tapping method make sure to push key in firmly while turning!! That's the secret...if I can do it, anyone can!!
dyanab is offline
Replaced Lock Cylinder, still nothing!!!! iceman123187 WJ Grand Cherokee Forum 1 01-09-2011 03:28 PM
Where and which ignition lock cylinder iceman123187 WJ Grand Cherokee Forum 0 01-08-2011 01:41 PM
How to remove HVAC (especially how to remove pipes conestions; plumbings) ? diogene WJ Grand Cherokee Forum 6 11-28-2010 07:58 AM
Ignition Cylinder wont turn High_Output WJ Grand Cherokee Forum 7 09-19-2010 10:15 AM
new ignition lock cylinder now wont stay running WJsteve WJ Grand Cherokee Forum 3 06-04-2010 03:59 PM
