how to properley adjust a track bar? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > how to properley adjust a track bar?
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 10-10-2011, 06:33 PM   #1
bcurto
Wj how to properley adjust a track bar?
what is the correct way to adjust a track bar.. i was told to have it on a flat level surface and bounce the jeep and whare it sits is the proper adjustment? any other ideas. it is a RC adjustable one
bcurto is offline   Reply With Quote
Unread 10-10-2011, 06:44 PM   #2
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Level ground, bounce it a little to settle the axle.
Measure and adjust accordingly.
Didn't think those RC trac bars were worth a crap from what I have heard, but best of luck with it.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee....
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover 4.6 HSE
2000 4.7 4WD WJ with a rebuilt motor.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
Years to gain the hands on experience, and offer it freely.
Minutes to gain the knowledge from the internet, and quote it just as freely.
Choose wisely!
leftlanetruckin is offline   Reply With Quote
Unread 10-10-2011, 07:00 PM   #3
PhantomWJ
2003 WJ
bouncing it will not help, but its fun...and no "where it sit is not the proper adjustment.
The RC one adjusts from the joint side towards the body not the axles; I used to own one of those.
park the WJ next to a fixed point you can use to ratchet (or use a come along) your body over the one side or the other. If the body is offset to the driver side, your fixed point will be on the passenger side as you want to move it to the left (as you face it).
Disconnect the trac bar (pic 1)
Get a straight edge and press it against the top and bottom center or your tire side wall, measure from the edge of the straight edge to the fender....measure both side....(Pic 2) If the distance is more on one side, then you need to pull from that side. In my case, the body was further on the driver side so I had to pull it over to the passenger side.
Move the body with a ratchet or come along (pic 3)
Once the measurement are close enough for you, some say 1/16 is close enough; I get it as dead on even as possible. then you adjust the trac bar to slide in place and bolt it tight. If the holes dont line up, readjust the bar not the body. As soon as the bolt is threaded or tight then you can release the ratchet or come along.
Finally....TORQUE both ENDs...TIGHT...especially the RC TB as it has a joint at one end...
PhantomWJ is offline   Reply With Quote
Unread 10-10-2011, 07:42 PM   #4
bcurto
are RC adj. track bars not really good? what are the bad sides of them cus this is what i just oardered
Unread 10-10-2011, 07:47 PM   #5
PhantomWJ
2003 WJ
They are fine...its the heim joint side that is sometimes problematic...just make sure it is always TIGHT!
Unread 10-10-2011, 07:54 PM   #6
leftlanetruckin
XJ on 37's
Knowing them on the XJ side, they look scary to me, but all my stuff is home made and maybe a little over kill....
Get what ye pay for in my experiences.
If your not going to wheel it hard, probably be OK.
Martin
http://www.jeepforum.com/forum/showthread.php?t=324622
Choose wisely!
Unread 10-10-2011, 08:09 PM   #7
ezflip
I ran the rc x series kit on my last wj. No problems what so ever and will probably start with that kit again for my current build. Only thing I am planning on replacing is the shocks and I'm planning on long arms up front and moving the adj. lower control arms from the rc kit to the rear. But again, I never had a problem with my track bar and will be using it again.
2002 Overland - 4.7 HO, "Select-Drive", 4" RC long arms, TAG front winch bumper, 32" BFG KM's
Build Thread
ezflip is offline   Reply With Quote
Unread 10-11-2011, 06:05 AM   #8
bcurto
Is there a place to get a replacement end?
Unread 10-11-2011, 07:23 AM   #9
leftlanetruckin
XJ on 37's
Any of the normal places that sell rod ends etc.
Just Google "adjustable rod ends".
I try to stick to the name brand stuff myself, but each to their own.
Here is all my stuff on the XJ, all home made from 1.5" DOM. Kind of hard to see the trac bar, but it is directly behind the drag link (where they belong BTW)
Martin.
Choose wisely!
Unread 10-11-2011, 08:58 AM   #10
PhantomWJ
2003 WJ
What replacement end? If its a RC part you bought, call them they will send you new bushings...
Unread 10-11-2011, 09:49 AM   #11
bcurto
Its the end that connects to the frame. Its like a wobbol ball joint. Im sure they could send me a new adjustable end
Unread 10-11-2011, 10:24 AM   #12
PhantomWJ
2003 WJ
call them...
Unread 10-13-2011, 04:16 AM   #13
dmextreme77
Yes. if you have the rc trackbar and your heim joint gets bad or is loose-they will replace it for free just as they did for me not 4 weeks ago or so.
2001 Grand Cherokee 4L
-4"RC
-265/70 Treadwright's on JK Moabs
-Bunch of misc crap
JOCCI Jeep Club
My Build Thread!!
dmextreme77 is offline   Reply With Quote
Unread 10-13-2011, 12:43 PM   #14
PhantomWJ
2003 WJ
And, while you are at it request the bushings for the other end and any other bushings you may have from control arms to steering stabilizers and shocks....
