How often do your window regulators break? - JeepForum.com
post #1 of 11 Old 05-21-2013, 09:37 PM Thread Starter
YZ212
2003 WJ
I've had my 03 wj for 2 years now and have replaced 3 of them and just tonight one that I replaced broke again. It's the same issue on all of them, the cable breaking.
03 Limited 4.7 4" IRO Long arm rear 4.5" custom radius arm front Currie Fab 9" hp front
247-231 swap BFG TA KO 315/70/17 Black Rock 909 Type D wheels 17x8 5x5 and 5.5 bolt pattern 4.5" backspace
YZ212 is offline
post #2 of 11 Old 05-21-2013, 09:45 PM Thread Starter
YZ212
2003 WJ
May have found my solution. Link and partial text from site.
This solid aluminum block replaces the plastic part molded into the slide on 1999-2004 Grand Cherokee power window regulators. When the plastic OEM block cracks, it releases the cable holding the window up and the window will fall down.
http://pocketlogger.com/?pid=jpw
YZ212 is offline
post #3 of 11 Old 05-21-2013, 09:53 PM Thread Starter
YZ212
2003 WJ
Here is a video of them showing you how to install the new cable block.
YZ212 is offline
post #4 of 11 Old 05-22-2013, 12:15 AM
silentbob21
out of stock, haha but yea seems like they would work. Ive replaced quite a few regulators but only seems to happen every couple of years
2004 WJ SE 4.0L I6, NV242, IRO 6.5 LAs D44a Spartan locked, 4.88s, BFG KM2s 35/12.5/15
silentbob21 is offline
post #5 of 11 Old 05-22-2013, 12:39 AM
alfaitalia
Whenever I have the door panels off for work on any car I own I spray the wires and wheels with spray grease....never had to replace one yet. Well... except on my audi 20v quattro...when it was broken when I bought it!
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #6 of 11 Old 05-22-2013, 04:38 AM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
2004 replaced 1 regulator in 9 years.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #7 of 11 Old 05-22-2013, 07:57 AM
Darnice
If your breaking 3 of them in 2 years, your not fixing the problem that's causing them to break.
I have over 30,000 cycles on mine and have never had one break.
Darnice is offline
post #8 of 11 Old 05-22-2013, 10:40 AM
Merc1973
Replaced 2 since 2008. Dont slam the doors with the windows down.,
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #9 of 11 Old 05-22-2013, 11:26 AM
Darnice
That may be it, cause I never shut the doors with the windows down. Good catch!
Roll them up, shut and lock.
Darnice is offline
post #10 of 11 Old 05-22-2013, 11:46 AM
Merc1973
That's how the first one broke. From then On I dont slam the doors hard even if rolled up to be safe.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #11 of 11 Old 05-22-2013, 05:51 PM
gcjeeping
gcjeeping's Avatar
1 since 2001. None recently.
_____________
gcjeeping is online now
