How many Miles on you WJ - Page 7 - JeepForum.com
View Poll Results: How many miles on your WJ
0-100K 43 14.19%
100k-200K 204 67.33%
200K-300K 56 18.48%
Voters: 303. You may not vote on this poll
 6Likes
post #91 of 309 Old 01-24-2014, 08:09 PM
CopperDeer
175k on my 99 4.0 Limited with NV 247. Maintenance between #2-3 since buying at 139k. Head & valve cover gaskets at 170k but it was barely having symptoms. Had to replace front rotors & calipers due to calipers sticking at 158k. TPS went bad and was replaced at 172k. Front drive shaft starting making noise so it's been temporarily removed. Shocks and some bushings wore out, replaced at 165k. Rear differential is shot right now. Some intermittent interior / electrical problems - dome lights, rear wiper, AZC blend doors, rear driver side window. Radiator developed a leak at 161k and was replaced.
Just bought a 00 4.0 2WD Laredo with every option with 271k. Engine is not the original and needed a head gasket pretty badly. Transmission is shot. Suspension/steering linkage is pretty worn out. Sunroof will tilt but gets jammed up and won't slide back all the way. Driver's window regulator has similar problem. Everything else on it is in great shape, including the HVAC. Probably going to part out the 99 to use all the mechanical parts for this body.
CopperDeer is offline
post #92 of 309 Old 01-24-2014, 08:30 PM
2KXJJEEP
-2002 WJ 4.0 L6 4x4 Laredo sport w/ 178K 2nd owner bought it 6 months ago with 172K change oil ever 3,000 miles Valvoline conventional 10w30 in winter and Delo 400le 15w40 in summer so far so go just need a LIFT & TIRES!!!
-2000 XJ 4.0 L6 4x4 sport w/ 142K 3rd owner bought it with 113K 3 years ago, I replaced the junky cracked 0331 head at 124K same maintenance ^
2000 XJ Sport|4.5" Lift|35's|4.56's|"NO SWAY BARS"
2002 WJ Laredo Sport|Stock On 17" Moabs
2KXJJEEP is offline
post #93 of 309 Old 01-25-2014, 03:53 AM
gphunkplp
99 wj 150,000 4.0 inline 6
note 3
gphunkplp is offline
post #94 of 309 Old 01-25-2014, 04:31 AM
JakeV11
2004 4.7 bought with 168,541 now has 168,887. Bought 01-17-14 haven't even changed oil yet. Doing that Monday. Not one issue so far. Has been check with code reader.
2004 Wj 4.7 Quadra Drive - Stock for now.
JakeV11 is offline
post #95 of 309 Old 01-26-2014, 06:13 AM
msd58
I have 155,000 on my Limited
msd58 is offline
post #96 of 309 Old 01-26-2014, 07:58 AM
kfowler22
2015 JK Wrangler
2003 WJ 4.0L with 168,700 miles and counting!
kfowler22 is offline
post #97 of 309 Old 03-02-2014, 03:56 PM
Locutus
2014 WK
99 WJ
4.0
rotella t5
If it ain't broke, fix it till it is
Locutus is offline
post #98 of 309 Old 03-02-2014, 04:01 PM
kmcnulty79
2012 WK
03 overland just hit 80,000
kmcnulty79 is offline
post #99 of 309 Old 03-02-2014, 04:18 PM
HavasuRat
04 Laredo Freedom Edition 4.0 117K
SATAN is my animal spirit!
HavasuRat is offline
post #100 of 309 Old 03-02-2014, 04:34 PM
powell3wj
Now I'm at 125134 but hit this other day on my 02 wj
(Instagram @powell3d)
powell3wj is offline
post #101 of 309 Old 03-02-2014, 04:36 PM
poisoness
Wj 01 limited 4.7
100,483 MIES BOUGHT 6 YRS AGO w/82,000 so far replaced blend doors about yrs ago ,radiator w/hoses 1 yr ago, all 4 window regulators,fixed power seat myself w/recommended grease, doing heated seats next week or so,also getting autostart fixed, next power steering hose. ill see what else comes up, I love this car, great mileage for the power it has.
poisoness is offline
post #102 of 309 Old 03-02-2014, 05:02 PM
limitmike
2001 4.7L V8. Pennzoil 5w-30. 121,000 total. Power steering pump cracked at 90k. Switched to Mopar fluid and she runs great. My maintenance is a 1 and I'm not proud of it.
limitmike is offline
post #103 of 309 Old 03-02-2014, 06:04 PM
Scrmngchicken
2001 ans at 252k. I aim to take it to 350 before any major overhauls.
Scrmngchicken is offline
post #104 of 309 Old 03-02-2014, 06:30 PM
shockracer
We should have people like you posted as a sticky on top of this forum to offer hope for others, LOL.
163K, factory Mopar fluids
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #105 of 309 Old 03-02-2014, 08:15 PM
sn95guy
04 4.7 Limited model
Quadra drive, 105k miles, Brake rotors etc, in shop now getting head gasket replaced.. cylinder #8...
2004 Grand Cherokee Limited- 3in IRO Lift, 265/70/17 Kenda M/Ts, Adustable Trac Bar, Sway Bar Discos, IRO Front Adjustable Control Arms, IRO Dual Stabilizer Kit, Trimmed Bumper, 242hd Tcase Swap, K&N Intake...Soon.. T-case Skid, Raise Gas Tank, Over The Knuckle Steering, Front Recovery Points and Hidden Winch
sn95guy is offline
