How many Miles on you WJ - Page 6 - JeepForum.com
View Poll Results: How many miles on your WJ
0-100K 43 14.63%
100k-200K 198 67.35%
200K-300K 53 18.03%
Voters: 294. You may not vote on this poll
 6Likes
post #76 of 297 Old 11-26-2013, 06:42 AM
porrsher
1994 ZJ
165k 4.7 HO
226k on my ZJ
1994 Hunter Green ZJ 5.2L Quadratrac
228k Miles, 2" BB.
2002 Slate Grey Grand Cherokee Overland
161k Bone Stock
2008 Black JK Sahara Unlimited (Love it!)
porrsher is offline
post #77 of 297 Old 11-26-2013, 09:58 AM
Pockets518
2001 4.0 almost 150k, use store brand oil 10w30 and usually fram filters every 3500 miles, had to do (rough mileage) headgasket at like 120k, crank sensor at 135k trans flush at 130k, trans rear output speed sender and govenor solenoid at 139k, oil pan and rear main seal at 144k.
maintenance wise prob 1 lol i mean i dont go looking for issues every day but if i notice somehting i check it and repair it, and i give it a once over at every oil change when i have it in the air.
this is my second wj and third jeep (had a 98 wrangler)
F.T.P.
Pockets518 is offline
post #78 of 297 Old 11-26-2013, 07:40 PM
R0CKKR4WL3R
2001 WJ 4.0 Laredo...3rd owner. Bought it for $1,500.00 with 224,000 miles. Currently has 265,000 miles. I had to replace the radiator, fan and fan relay. Fan created havoc as the polarity was backwards. Swapped out 7 radiators in a month and a half and 8 relays in 2 weeks, before FINALLY finding the issue. Lesson learned? Don't trust aftermarket parts.
Just replaced the passenger CV axle shaft and have brand new rear upper control arm and ball joint waiting for a nice day to be installed.
Upgraded quite a few items...
INSTALLED:
- factory foglights, multi-function switch, and relay.
- factory auto-dimming mirror.
- luminescent gauges.
-'03 grille painted black (plasti-dip) with chrome rings
-'04 Overland rock rails
-Jeep brand push bar
-Jeep brand bug deflector
-'10 Wrangler Unlimited X steel 5-stars (plasti-dipped black)
Driving a 12 year old vehicle with really high mileage and LOVING it!
R0CKKR4WL3R is offline
post #79 of 297 Old 11-26-2013, 08:29 PM
mike12899
Just hit 117k on my 04
4.0 2nd owner, bought it around 100k
mike12899 is offline
post #80 of 297 Old 11-27-2013, 02:08 PM
YJSXJ
1993 XJ Cherokee
196,000 on my wj
My 93 xj had over 280,000
YJSXJ is offline
post #81 of 297 Old 11-27-2013, 08:09 PM
stephenpegler
2003 WJ
2003 4.7 Limited. 155,000 miles.
Always Mobil 1.
Maintenance #2.
No engine or drive train problems. Some valve noise on cold start but it goes away on warm up.
Two replacements of the stupid blend doors, one under warrantee, one at 125,000.
One replacement of AC compressor, lots of hard use, I live in AZ.
Three replacements of the stupid power windows drive system.
The usual brake pad and disc services.
Lots of hard off-road use on the old mining "roads" of Arizona.
Total replacement of the loose stock low ground clearance suspension system with a IRO 4" long arm lift front and rear. Great lift kit! Replaced front drive shaft while everything was taken apart. Worn out suspension bushings were my excuse to do this :-) 32" Goodyear SilentArmor tires. Great tires, quiet on highway, adequate traction and Kevlar toughness off road. New rear bumper spare tire carrier because big tires don't fit inside anymore. Now it's an off road beast but still a civilized daily driver. Wife's only complaint is that it's "higher".
Right now, knock on wood, runs like a new car. No complaints, no desire to replace. Great car.
Steve
stephenpegler is offline
post #82 of 297 Old 11-28-2013, 08:47 PM
multmigs
2003 WJ
190k on my 03
multmigs is offline
post #83 of 297 Old 11-29-2013, 11:52 AM
Zombieslammed
168,086
Zombiekid
Zombieslammed is offline
post #84 of 297 Old 11-30-2013, 01:32 PM
STGjeep
99 4.7L limited
125,000
247TC
D44 with Yukon 3.73 gears, Spartan Locker
Maint scale #3
Use Mobile 1 High Mileage Synthetic
At 125,080 My PCM went bad. Rplaced it from a unit from autoemcs.com with no problems thus far.
Have some problems with my AZC, think my blend doors are bad.
Vibration on decel at speeds over 45 mph.
STGjeep is offline
post #85 of 297 Old 11-30-2013, 08:22 PM
Black2000cl
2000...148000
Black2000cl is offline
post #86 of 297 Old 11-30-2013, 08:31 PM
sfjacks1
2004 v8 157,000
sfjacks1 is offline
post #87 of 297 Old 12-01-2013, 04:33 PM
Double E
Double E's Avatar
186,000.. I'm a 3+ and strict about maintenance.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #88 of 297 Old 12-01-2013, 06:45 PM
bigteal
209,00 on our 4.0.
The wife bought it 10 years ago, put 185,000 miles on it. I took it over after I bought her the escape. Put 3,000 on it in 2 months. Dead nuts reliable. In ten years, I've put 5 radiators in it, just replaced the factory water pump 4 months ago, 1 cooling fan and a transfer case ( wife's fault, she ran over a stump and tore it off).
It needs a rebuild badly. Very worn wrist pins. Sounds like an old detroit on a cold morning. Still runs good though, so screw it. Gonna drive it until it breaks something.
bigteal is offline
post #89 of 297 Old 01-24-2014, 04:54 PM
mangymarmot
2004 4.7 with 168,000 miles...
mangymarmot is offline
post #90 of 297 Old 01-24-2014, 04:56 PM
nickmills77
1999 4.7 with 132, 313
nickmills77 is offline
