How many Miles on you WJ - Page 4 - JeepForum.com
View Poll Results: How many miles on your WJ
0-100K 43 14.19%
100k-200K 204 67.33%
200K-300K 56 18.48%
Voters: 303. You may not vote on this poll
 6Likes
post #46 of 309 Old 09-01-2013, 03:50 PM
ZJeepn08
2007 WK
56000 miles. 04wj Laredo. 4.0L this thing is going to last forever!!!!
ZJeepn08 is offline
post #47 of 309 Old 09-01-2013, 04:20 PM
Leyva_WJawd
105941
1999 Grand Cherokee Limited, 4.7L V8, QT II, AWD, Brush Guard, 31x10.5x15"s. BB otw.
Leyva_WJawd is offline
post #48 of 309 Old 09-01-2013, 04:45 PM
schaef89
1999 Powertech 4.0, 154,300 miles
Conventional oil @3000mi interval
Bought the jeep @ 136k
Tie rod end @ 137k
Heater blower motor resistor @ 137k
Lift gate motor @ 137k
Usual blend door issues noticed @ 137k
Bad wrist pin developed @ 139k
CV shaft @ 139k
Throttle position sensor @ 142k
Water pump @ 144k
Electric fan @ 146k
Rear axle assembly @ 146k
Two tie rod ends @ 154k
I've come to the conclusion that it was neglected by the PO
Mixture of 1 & 2 for Maint scale
89 YJ S, 2.5L/AX-5/NP231
99 WJ Limited, 4.0L/42RE/NP247
93 YJ, 4.0L HO/32RH/NP231 - Sold
schaef89 is offline
post #49 of 309 Old 09-01-2013, 05:28 PM
Jeep_Fanatic
2012 MK Compass
2003
4.0L
204,xxx miles
valvoline conventional 5W-30 (its free at my work)
dont know any fails
#3 maintenance. i even cleaned the back side of the wheels hoping it doesnt affect balancing
-Rescue Green '12 Compass Sport 4x2 2.4L CVT daily driver
-New jeep coming soon
Jeep_Fanatic is offline
post #50 of 309 Old 09-01-2013, 05:52 PM
cbake67
2003 WJ
2003 Laredo
4.0 Powertech (whatever that is)
71,xxx mi
Latest change was to Castrol GTX 10w30 and a Mopar filter
I'm 2.5 on maintenance
I'm the second owner of this Jeep and hope to have it for many more years. Previously dealer maintained and I plan on keeping it up. Its my wifes DD and it will remain stock. Purchased to replace a 98 ZJ with 200,750 miles on it, over 100k by me on a steady diet of Castrol dino oil.
No major issues yet....
cbake67 is offline
post #51 of 309 Old 09-02-2013, 12:20 AM
04beachwheeler
04 4.7, just cracked 89K about 2 days ago
no major problems aside from a slow seeping between the front of the block and the oil pan, and a slow leak above the water pump.
I change the oil every 3000 miles with penzoil 5w-30, going to royal purple synthetic on my next change to get as much out of this big V8 as possible.
I would be a 3, i absolutely lose sleep on the slightest leaks and feel the need to spend my life savings on rebuilding even if it aint broke yet.
04 WJ: 4.5' Clayton F, 4" IRO R, IRO adj front control arms, Ruffstuff OTK one ton tie rod, OBA.
04beachwheeler is offline
post #52 of 309 Old 09-02-2013, 05:54 AM
Crash4x4
164,000
Still can't fix ac...
Crash4x4 is offline
post #53 of 309 Old 09-02-2013, 07:30 PM
XJcory
2004 Laredo 4.7
Bought with 130k, now at 170k and runs perfectly. I've had to replace the axle seals, oil/transmission pans, cv joints, etc. but nothing catastrophic so far. Hell I even still have the factory exhaust without a single leak! I'm also extremely anal about maintenance, and I run pennzoil platinum at 5k mile OCI.
'04 WJ 4.7 176k
'98 XJ 207k
XJcory is offline
post #54 of 309 Old 09-04-2013, 08:03 PM
mckinjc
2001 Laredo
4.0L 6cyl
130,000 miles.
Bought at 128k
In last 2,000 miles I've replaced crankshaft sensor, fuel pump and fuel filter, two vacuum hoses, hood and hatch shocks, and replaced torque convertor.
Running like a champ now.
mckinjc is offline
post #55 of 309 Old 09-04-2013, 10:06 PM
SCAN-MAN
Wj 2004 4.0
180 miles a day, 5x a week
No complaints from this wj
SCAN-MAN is offline
post #56 of 309 Old 09-04-2013, 10:09 PM
SCAN-MAN
Wj
Now @ 180,000+
SCAN-MAN is offline
post #57 of 309 Old 09-04-2013, 10:21 PM
StormChaserTim
Since it won't let me vote.....
2000 Limited 4.7L 2WD. Purchased 8/13, with 160K on it.
Before I continue, allow me disclose, this was purchased knowing it would need some TLC. That said:
Ground in driver's door conduit repaired.
Spark Plugs changed
Oil Pressure Sending unit changed
New tires
New rear brakes, plus rotors machined
Headlights polished back out
A/C repaired (suction hose dry-checked and leaking, replaced accumulator with hoses)
Dent removed from rear hatch
Fuel injectors cleaned
Throttle body cleaned
Oil changed
Crank sensor replaced
Battery terminals cleaned, and cabling inspected
Loose ground repaired
Door panel clips replaced
I still have yet to solve the random dying issue, and I have a problem with the Infinity Gold stereo system where the sound will cut out.....pretty much whenever it pleases. I suspect the BRN/WHT whire to the amp has a break in it somewhere, but that is a small issue that can be fixed when I get it running.
Tim
1995 Jeep Grand Cherokee Laredo, 4.0L 2WD, 355,000 miles.
StormChaserTim is offline
post #58 of 309 Old 09-07-2013, 08:44 PM
Demers350
1987 XJ Cherokee
1999 WJ Laredo 4x4 210,000 or so and still going strong
Demers350 is offline
post #59 of 309 Old 09-07-2013, 11:02 PM
gtg413i
2003 WJ
Like 83000. Engine blew at 50000 or so, so hoping to go to at least 150,000 miles
Brian's Black Betty Build:
gtg413i is offline
post #60 of 309 Old 09-08-2013, 05:13 PM
cbake67
2003 WJ
A photo from when we bought it back in March
My other car is a Toyota--with Pontiac badges
cbake67 is offline
