How many Miles on you WJ - Page 18 - JeepForum.com
View Poll Results: How many miles on your WJ
0-100K 43 14.19%
100k-200K 204 67.33%
200K-300K 56 18.48%
Voters: 303. You may not vote on this poll
 6Likes
post #256 of 309 Old 05-03-2016, 01:31 PM
alfaitalia
Wrong thread?
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #257 of 309 Old 05-03-2016, 07:20 PM
acgenrich6777
Cool Many adventures...
I have an 02 WJ limited, special edition, with Quadradrive, 4.7L H.O.
I currently have 159,508 miles. Been running 10w30 valvoline with Fram Tough Guard filters. I've been through 2 radiators, one water pump, rear diff. rebuild, heater core, and now my A/C went out and its about to be summer time here in Houston, TX. Oh boy.
acgenrich6777 is offline
post #258 of 309 Old 05-03-2016, 07:45 PM
RCMech
2000 4.0 w/SelecTrac. 375,000km. Drove it off the showroom floor, obsessive maintenance since new. Nearly everything except the seat belts has been replaced at least once, all suspension components at least twice. Piston skirt fracture at 368,000km, driveshafts at that point, brake lines are currently being replaced.
RCMech is offline
post #259 of 309 Old 06-12-2016, 05:24 PM
sdg3205
Big day.
sdg3205 is offline
post #260 of 309 Old 06-13-2016, 10:28 AM
laxman1306
just rolled 250k last week.... runs like a top hardly no oil consumption .... gets wheeled regularly too...oh and its a 4.7 v8
laxman1306 is offline
post #261 of 309 Old 06-13-2016, 11:28 AM
HarryH3
Our '01 is just getting broken in. Just rolled past 128K miles last week.
HarryH3 is offline
post #262 of 309 Old 06-13-2016, 06:22 PM
msd58
187,000 trans just went. Its was replaced at 48,000 miles 1999 LTD. Not fixing it. Too bad its a straight body still shines nice.
msd58 is offline
post #263 of 309 Old 06-13-2016, 07:28 PM
Turbozcs2003
so what happens to the radiators?
slow leak at the crimp between the core and tanks or a catastrophic failure of the plastic tank?
what mileage do they tend to fail?
I ask because I only have 63K miles on mine
Turbozcs2003 is offline
post #264 of 309 Old 06-14-2016, 12:59 AM
ZamoraDC
Since I've bought my 99 Laredo 4.7 in March of 2015 I've put 15K miles on her. Now she's sitting at 145,7xx miles. Since then I've replaced the radiator twice, water pump, thermostat, cooling fan relay, and replaced all the fluids after I bought her. All oil changes have been with Rotella T6 5w40 and Fleetguard LF3604 oil filters. I take her wheeling about once a month and she's showing no signs of slowing down.
Sent from my Nexus 6 using Tapatalk
ZamoraDC is offline
post #265 of 309 Old 07-18-2016, 01:46 PM
acgenrich6777
The first radiator blew a leak one month after buying it (used) from a Chevy dealer. hmm wonder what they did.
Second radiator something got in between the fan and the radiator and made swiss cheese out of it. Barely got it home. No engine damage. Runs great. Besides the fact I have no A/C right now and the standing temp is in the high 90's with a real feel of 110+/-.
post #266 of 309 Old 07-18-2016, 02:11 PM
acgenrich6777
there is no about mileage for a radiator to blow out. It depends on you preventative maintenance schedule, climate, driving habits, and the possibility there is a flaw from the manufacture. There are to many variables.
post #267 of 309 Old 07-19-2016, 12:08 PM
three_jeeps
4.7L SO
114K
Qudra-drive 54RFE
Bought new
Purchased extended 3yr warranty
First 3 years, did maint 'by the book' except for oil&filter - 4.5K-5K intervals.
Major forced repairs:
Blend doors at about 50K - dealership
Radiator about 75K
transmission cooling lines failed about 80K due to rust out
Replaced OE waterpump at 85K (was still working) with Advance Auto one - failed after 28Kmiles. Replaced with OEM pump. Replace thermostat, upper & lower rad hoses at same time.
I get about 30-35K (or sooner if rotors warp) on brake pads and with the exception of the first pad change, I end up changing rotors with pads due to warpage - thus far, two sets of front rotors, and will be doing them again very shortly. Will also replace front calipers.
One set of rear rotors due to rusting away - out of thickness spec.
Rear wiper motor at about 70K, died again at about 105K, haven't replaced it yet.
OE starter died/replaced about 75K
Oil pressure sender at about 95K (unit failed)
Tranny pan replaced (rusted out) at 100K
Brake lines at about 110K (rust out) - independent garage
Rest of stuff has been regular maint and I tend to do almost all myself, including:
Brakes, rotors, plugs (factory spec champions), all fluids, including differential, transmission, transfer case,etc, air filter. Use all mopar fluids.
Oil has been: penzoil, valvoline, (sporadically alternate) Fram/purlator/Mobil1 filters
Uses about 3/4 to a quart of oil between changes
Past year have been updating parts that tend to fail (but havent yet) e.g. crankshaft position sensor, camshaft position sensor, precat O2 sensors, AIC, PCV.
Fuel filter, PCV breather lines, rebuild alternator, and all shocks are up next.
Use zerex HOAT G5 antifreeze.
Battery replacement every 4.5-6 years, usually proactive before failure.
Installed remote starter.
At 105K replaces entire exhaust after cat with OE SS exhaust.
At 110K miles replace OE wheels with 2011 JKs as 3 out of 4 OE leaked due to corrosion.
Maint approach: by the book, maybe stretching intervals by 5-10%. (except for oil as noted above). SInce I plan on keeping jeep for a while longer, replacing items that are prone to failure...I *hate* to be stranded by unreliable vehicle.
Engine runs great!....just hope it doesnt get bit by the 'dropped valve seat' problem..
three_jeeps is offline
post #268 of 309 Old 07-23-2016, 08:13 PM
purplecty
2003 WJ
198k 4.0 WJ laredo
Pearl Blue WJ Laredo 4.0-(202,xxx Miles) - COMPLETELY STOCK!!!
purplecty is offline
post #269 of 309 Old 07-27-2016, 04:10 PM
leadsled jeep
187k miles (300k km) on my 4.7HO. Amsoil 5w30 since purchased at 110k miles. Consuming about 1qt oil each 1k miles now. Switching to 10w30 Amsoil.
All PVC CCV etc changed out and I suspect it's wear/ loose but she runs like a champ. Likely go with a Jasper engine down the road as I like their upgrades to factory issues. TBD and hopefully that's a LONG way off.
Chris
'02 Overland 190k+ miles. 2.5" lift w/springs. All Control Arms upgraded, dual Addco sways.
leadsled jeep is offline
post #270 of 309 Old 08-07-2016, 02:20 PM
Locutus
2014 WK
If it ain't broke, fix it till it is
Locutus is online now
