How many Miles on you WJ - Page 10 - JeepForum.com
View Poll Results: How many miles on your WJ
0-100K 43 14.73%
100k-200K 197 67.47%
200K-300K 52 17.81%
Voters: 292. You may not vote on this poll
 6Likes
post #136 of 291 Old 03-29-2014, 02:28 PM
Locutus
Wj
5 qts Rotella T5
1qt MMO
Purolator PL30001 Filter
no probs on any thing engine related
If it ain't broke, fix it till it is
Locutus is online now
post #137 of 291 Old 03-29-2014, 06:12 PM
Turbozcs2003
02 WJ Laredo 4.7 242 545 RFE 3.73 open trailer tow
61600 miles ( have 9 cars
Bought new 8/2002
3 on the scale here
Run xw-30 synthetics every 5K or so with AMsoil or mobil 1 filters, Amsoil air filter
Have changed diffs with amsoil 75w-140 twice
Run Amsoil ATF in trans have chaged twice
Run Amsoil MTF in the 242 changed twice
Run Amsoil Power Steering fluid
Drain and refill with Hoat5 zerex distilled water every other year.
Only repairs, two sets of champ plugs, 1 H valve and recharge AC, rear calipers rotors/pads, front rotors and pads, 1 idler pulley for the belt.
Bled brakes a few times. One set of tweeters in dash, new upper and lower rad hoses as precaution., wix fuel filter this year.
No leaks, sqeaks or ticks
Rust proofed with Eastwoods rust encapsulator/chasis black/fluid film
Basic maintenance
Turbozcs2003 is offline
post #138 of 291 Old 03-29-2014, 07:04 PM
jeep365
217,000 and counting...
...and all mine.
jeep365 is offline
post #139 of 291 Old 03-30-2014, 08:31 PM
bambam634
Still runs pretty good
bambam634 is offline
post #140 of 291 Old 04-11-2014, 05:26 PM
jrandallc
2000 Grand Cherokee Laredo
230,000 miles
I bought mine used four years ago. I don't remember the mileage when I bought it. I've done a lot of work on it. Entire new cooling system, new crankshaft position sensor, including the latest job of new camshaft, lifters and of course head gasket, timing chain, etc that goes along with that job.
I plan on riding this Jeep well over 300,000. She is running pretty smooth after the camshaft job.
jrandallc is offline
post #141 of 291 Old 04-11-2014, 05:53 PM
Thomahawk
Hopefully we Get insane amount more miles out of them!!!
What to do when we run out of replacement WJ's???
Buildthread
Thomahawk is offline
post #142 of 291 Old 04-11-2014, 06:02 PM
Thegdog
Originally Posted by Thomahawk
Hopefully we Get insane amount more miles out of them!!! What to do when we run out of replacement WJ's???
I doubt that will be a problem for a good long time. Have you seen how many WJs are out there. I see at least 8 on my 15 mile trip to work each day!
Thegdog is offline
post #143 of 291 Old 04-11-2014, 07:20 PM
Thomahawk
Ok, but not over here
Buildthread
post #144 of 291 Old 04-11-2014, 07:28 PM
Thegdog
haha no worries, there is plenty where I live! Gosh, probably like 10,000 of them around here! :-)
Thegdog is offline
post #145 of 291 Old 04-11-2014, 10:57 PM
KayCeeJeep
Yeah they are everywhere here even though the newest of them is now 10 years old. Good Jeeps. They last, I still see lots of ZJ's and XJ's too.
STOCK WJ WARRIOR
2004 4.0 Laredo Selec-Trac at 132k
General Grabber AT2's
KayCeeJeep is offline
post #146 of 291 Old 04-12-2014, 12:21 PM
Super6XJ
Down here in South TX there is only a select few in good condition. rest are beat to ***** and runnging bad, i had to settle for a 2wd,
right now Shes doing good, she has 158k right now, got her when she had 142k back in november
Your Welcome
Super6XJ is offline
post #147 of 291 Old 04-12-2014, 02:00 PM
4WDlifeform
4WDlifeform's Avatar
2004 4.0 Laredo
Bought it with about 218k for 2,200. It looked good, ran good, and I figured with the 4.0, high mileage is nothing. At 230k now. Currently runs strong, handles well, and no codes... anymore.
I am probably closer to a 2 on the scale, but certainly growing as this jeep has been keeping me busy!
I think I have all the common problems. I have only had the jeep for a couple of months (I drive a lot for my job!), so all of this is pretty recent.
Rotted fuel tank cover - Trying to find one yet..
O2 sensors - Just replaced.
Broken Driver Seat Mount - Happened around 220k
Rear Lower Control Arms - Just replaced, bad when I got it.
Rear Axle Bearing - Bought it just as it was going bad... Still running it... Have the parts, hoping to do it next week.
I think I have a cracked flex plate..
Rear driver side window motor/mechanism, was broke when I bought it. Replaced with new.
Rear Wiper Motor, was seized when I bought it. Tried to salvage, but it was GONE. Replaced with new.
Muffler was leaking. Replaced with glass pack.
ABS sensor is bad somewhere... its on the list...
Front fenders rusted out above wheel. Bought it just as it was bubbling the paint, now there are holes. WOW. Not sure what to do yet..
All gas lift struts were shot. Replaced them all.
Window seal rubbery things getting rust under the ends. I see this on every other WJ. On the list.
Typical Maintenance:
I am trying to use semi-synthetic high mileage oil, though I usually go with a high-mileage brand that is on sale! I always add a quart of MMO. Rear main is leaky, so I keep an eye on the level. Always change at 3k.
Rotate tires every other oil change. Check pressure. Always torque lug nuts.
'04 WJ 4.0 295k 2" Coils 255/70 AT on JK take-offs
-- If it jams, force it. If it breaks, it needed replacing anyway --
4WDlifeform is offline
post #148 of 291 Old 04-26-2014, 08:17 AM
knudsen
year, 1999
engine, I6
oil used,Mobile 1, until recently, now what's on sale but good synthetic
any major failure, NONE! But, back axle is whiney and I'm afraid I'll be digging that rascal out soon. I have some awesome heavy late 60's TLC axles with a locker in the front that I'm tempted to meld in if I am physically able when the time comes, otherwise I'll be looking for a D44 at the yard. The TLC's are for leaf springs, so a lot of fab work. Rear offset is off too.
Maintenance scale
1) I just change my oil and fix things when they break.
2) I follow the owners manual "scheduled maintenance".
3) I am obsessive compulsive about maintenance and loose sleep when I don't understand the chemical compounds of a fluid I am using in my JEEP.
I'll say between 1 and 2.
Bought at 130Kish IIRC, now close to 170K. Had it at least 5 years, not sure. Change oil by time, not miles, b/c I usually don't put the miles on it for change interval to be good. Old oil is bad oil, regardless of miles on it.
knudsen is offline
post #149 of 291 Old 08-22-2014, 01:58 PM Thread Starter
wsar10
2003 WJ
BUMP....
an update for mine,
I'm switching to Rotella T6 (currently using T5 and PNZL HM) and no longer using P1 filters, going back to WIX with all the recent Puralator problems.
now @ 150K
in the next week or so I will be replacing almost everything under the front of the WJ.
TRE's
Sleeves
sway bar bushing (frame and end links)
Ball Joints (heavy duty "alloy")
shortly there after
shocks
spring isolators
maybe coil springs.
It needs ball joints and I figure @150K i'm just gonna do the rest as maintenance.
than its time to start over with all the fluids again !
QUOTE=billzcat1;wsar10 is right on point on this oil thread - as usual. Anyone reading this would be well-served taking his advice.
-03 WJ laredo 4.0 120k a few minor mods
-93 XJ 5spd, 3" zone lift
wsar10 is offline
post #150 of 291 Old 08-22-2014, 03:05 PM
Spyder328
2000 Laredo 4.0 I6
195,700
Rotella T5 10w30 with a Mopar filter
oil change every 4000
Just got it in June so thats it
2000 WJ Laredo, 255/70R16, 2.5" front and 2" rear BB, 1.25" wheel spacers
Last edited by Spyder328; 08-23-2014 at 03:59 PM. Reason: Forgot to add a few things...
Spyder328 is offline
