how long does your dub take to heat up? - JeepForum.com
post #1 of 16 Old 02-06-2013, 07:04 AM Thread Starter
WJlover
i just want to make sure im not the only one.
on a cold morning, i run out to my jeep, start it and run back inside like any new englander does.
but it seems to be taking upwards of 30 minutes to get to temp! every other car ive owned has taken 10-15 minutes.
that and my heat is luke warm so its not like letting it heat up really matters.
anyone else?
WJlover is offline
post #2 of 16 Old 02-06-2013, 07:14 AM
AntonWJ
My WJ I6 takes about 15min to warm up on a cold morning (28F) but it never even reaches close to the 240 mark on the temp gauge (dead center). But I do have a problem with the thermostat that I need to replace.
AntonWJ is offline
post #3 of 16 Old 02-06-2013, 07:35 AM
ChrisHager
Administrator
ChrisHager's Avatar
I think today it was high 20's when I started mine. I drove 2 miles and it was warming up enough to turn the heat on. Usually, 5 minutes of driving or so and I'm good to go. I agree with the above as well - mine never reaches the 240 mark.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #4 of 16 Old 02-06-2013, 07:39 AM
jefflacy
I had that problem with my jeep before the motor locked up. would go out 20 min early and start it 10-20deg out side and drive to work 10 min with no heat. I had a leak at the thermostat. Pulled in in the shop to look at it because the temps was dropping to 0-5 deg. Found out had air in the system I think from the leak. Got that out did same thing on the really cold days and had hot heat hot a nuff I had to turn it down.
jefflacy is offline
post #5 of 16 Old 02-06-2013, 09:12 AM
vettedude
2011 JK Wrangler
The temp outside today 10 degrees, drove about 2 miles and the engine temp got to 150 and the heat turned on.
2011 Wrangler Unlimited 4X4 -Stock
2004 WJ Overland Sold 5/2017
vettedude is offline
post #6 of 16 Old 02-06-2013, 09:25 AM
Cirruslydakota
Same, after about 5 2-3 minutes its hitting 140-150 on my temp gauge and I turn the heat on low, by 10 minutes the thermostat has already opened up and its toasty warm air coming out of the vents.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #7 of 16 Old 02-06-2013, 11:58 AM Thread Starter
WJlover
i could drive mine for 5 miles and it will just be getting warm by the end.
WJlover is offline
post #8 of 16 Old 02-06-2013, 12:02 PM
1salem1
It depends on the oil you use i was using 5w30 and it take less time to get warm than the 10w30 which i now use
1salem1 is offline
post #9 of 16 Old 02-06-2013, 12:05 PM Thread Starter
WJlover
im using 5w 30 now. was using 10w40 before and no change.
once i have the money ill replace the thermo and maybe do a coolant flush.
probably needing one anyways.
WJlover is offline
post #10 of 16 Old 02-06-2013, 12:34 PM
KonLegend
2005 WK
I would start with your cooling system. It is a possibility that your thermostat is open or partially stuck open, not allowing your vehicle to warm up to temp without not being cooled down. 30 minutes is quite a bit to reach temp, even in these temperatures. Air in the cooling system will actually do the opposite, and the thermostat may not want to open due to the trapped air. Causing it to not open and reach optimal temp faster than usual.
Start with the easy things first, and I would start by checking on your thermostat to be sure it isn't open all the time.
2005 WK 5.7 Hemi Limited
Superchip Performance Tune
K&N Intake
Flowmaster Super 40 w/reso delete
KonLegend is offline
post #11 of 16 Old 02-06-2013, 12:36 PM
KonLegend
2005 WK
And if your heat isn't very warm after it's optimal temperature, you may have 1 or more things going on. Low coolant, stuck open thermostat, plugged heater core, air in the system, plugged cooling system aswell. Recirc doors go, blend doors go, HVAC assemblies go....
K&N Intake
post #12 of 16 Old 02-06-2013, 12:42 PM Thread Starter
WJlover
ill start with the cooling system.
dont know much about the heater core but i see enough on here that makes me never want to go near it.
WJlover is offline
post #13 of 16 Old 02-06-2013, 12:50 PM
uberjon
Quick question. My jeep seems to output great heat on the recirculation setting, but rather poorly on all others. Would that suggest recirculating door fine but blend faulty?
uberjon is offline
post #14 of 16 Old 02-06-2013, 07:34 PM
KonLegend
2005 WK
That usually is the case, although I have seen malfunctioning recirc doors and blend doors at the same time that have that same symptom. But yes, that does shout blend door to me, may want a few opinions
K&N Intake
post #15 of 16 Old 02-06-2013, 07:40 PM
KonLegend
2005 WK
Is yours the 4.0 or 4.7? Heater cores are fairly simply to flush, the 4.7's best spot is right behind your PCV Valve, or oil cap. Follow those lines down and you will see it plug into the block, that's where I flush mine out. The 4.0's are easier, and the trick to doing those flushes, is to back flush the core a few times. I would start with flushing it the way the coolant goes through, ( usually it's the top heater core hose ).
Hook a hose up to one end and let it run out the other hose, ( you should have 2 heater lines disconnected ). Then repeat the opposite way. Some use compressed air as well, just be careful not to use too much as you can rupture a core doing so. Make sure there is water in the core if you use air.
It's a good maintenance anyways to do, I work at a Midas shop so I get really good discounts, but I flush the heater core out at least once a year.
K&N Intake
