How long can I leave my factory block heater plugged in? - JeepForum.com
post #1 of 12 Old 12-22-2013, 11:13 PM Thread Starter
vanwilder
Wj How long can I leave my factory block heater plugged in?
I have a 01 Grand Cherokee with the factory-block heater (yes it came from Canada and the gauges are in metric too). It doesn't state in the manual how long I can leave it plugged in for. I have a company work truck I use daily, and this last week here in Ohio it didn't get above freezing.
And since I never know when I'll need my jeep I had left it plugged in for 6 days while it sat. Other than maybe burning up the block-heater, will it cause any other damage?
vanwilder is offline
post #2 of 12 Old 12-23-2013, 12:13 AM
bones35
I've done two days. Never 6 but I Don' t think it will hurt anything. I've also never had a block heater burn out. Hope that helps
bones35 is offline
post #3 of 12 Old 12-23-2013, 06:44 AM
jfaulk
When I lived up in Alaska, every now and then I would leave my old K5 blazer plugged in for about a week at a time with no ill effects that I noticed. I've never seen a block heater burned up but I'm sure its possible.
jfaulk is offline
post #4 of 12 Old 12-24-2013, 09:20 AM
Trav1s
I bought a HD timer for engine block heaters at the local farm and fleet store for $25 that allows me to control on and off times. I sat it to come on three hours before I needed the WJ. It works great and saved on electricity.
04 Columbia Ed 4.7 HO/QTII/SSD107/UC/Bilstein 4600/RB4/Moabs/Cooper Discoverer AT3's/PML trans pan
Trav1s is offline
post #5 of 12 Old 12-25-2013, 09:57 AM
86cj74.2L
86cj74.2L's Avatar
When I left my cummins plugged in for more than a day it created a air pocket in the head that you herd pushing around for a few min after startup.
The heater would sizzle when plugged in. That is my indication its that its on and working. Now if needed, I just plug in a few hours before........
The trucks heater is 750w
86cj74.2L is offline
post #6 of 12 Old 12-26-2013, 01:42 PM
EmersonHart13
I run mine for about 3 hours before startup thanks to a nice HD timer. Was 10-15 bucks at Menards.
EmersonHart13 is offline
post #7 of 12 Old 12-26-2013, 07:15 PM
madZJ
Plug it in about three hours before starting, there's no need to have it plugged in all the time. I have an autostart and i fire it up about 15 minutes before I want to leave, and she's nice and warm. The previous owner or the dealer installed a block heater but I never use it. If one was going to buy a block heater I would recommend a tank style over a freeze plug style.
madZJ is offline
post #8 of 12 Old 12-26-2013, 08:49 PM
jbaldry
How hot does it get your block? Enough for it not to be pinned on the coldest temp? I have one by the way but when I used it it didn't seem to do much. It was also only 20 out
2000 Jeep Grand Cherokee Limited, Quadradrive, 4.7 V8
Living life mod by mod
jbaldry is offline
post #9 of 12 Old 12-26-2013, 09:08 PM
86cj74.2L
86cj74.2L's Avatar
My cummins will see 120 after 3hr
post #10 of 12 Old 12-28-2013, 09:51 PM
n7mog
engine block heater or....
I'm a fan of engine block heaters in a freeze plug hole. First choice, however, is a battery blanket usually only 80W. If the battery is warm, it will provide the cranking amps to turn even a cold engine over, but if the battery is cold the capacity will be greatly reduced and may not even be able to crank a warm engine well enough. If a vehicle is not used for a few days in real cold weather, a three stage trickle charger about 1 to 1.5 A is the #2 item I would use after the battery blanket. Surprising how much the standby electronics suck capacity from the battery when it's really cold out. Last would be the engine block heater. I would rarely use a tank or radiator hose heater, they just don't trip my trigger as they provide for more leak points, IMHO. Engine rebuilds that I have done always get a block heater in a freeze plug hole. Heck, I've even put two in big blocks in the past during rebuilds. YMMV.
Bill
N7MOG
2002 Liberty KJ, 1999 Grand Cherokee WJ x2, 1963 404.0 Unimog
n7mog is offline
post #11 of 12 Old 12-28-2013, 10:47 PM
jbaldry
Or you get a Die Hard Platinum with 930 Cold Cranking Amps
jbaldry is offline
post #12 of 12 Old 12-30-2013, 12:41 PM
n7mog
Buying a new battery or bigger battery is fine, but you miss my point. At a reduced temperature any battery loses a quantity of it's capability. If you bother the research this, you will understand my comments. I also stated that you can make your own decisions. I enjoy forums that allow differences of opinion and viewpoints. My opinions have been expressed, I hope that you can accept them as solutions that I have embraced.
Bill
N7MOG
n7mog is offline
