How to install a trailer brake controller in a WJ. - JeepForum.com
 2Likes
post #1 of 16 Old 09-12-2012, 10:52 AM Thread Starter
BigFire
I decided to make a thread on this because when I searched for myself, there wasn't a great complete thread on how to do it, and to benefit others. Mods might make this a sticky?
I bought a Tekonsha P2 brake controller through work. Here it is from their website: http://www.tekonsha.com/content/products.aspx?lvl=3&parentid=1400&catID=1435&part= 90885
It is WAY more than I need, but I got a good deal on it. It can control up to 4 trailer axles, and can control electric over hydralic trailer brakes. It also has a "boost" feature which can up the output if you are towing a heavier than usual load.
Doing this yourself is easy, and I think most anyone can do it. The only hard part is working under the dash, and getting up into some tight spaces. Save your moolah and do it yourself!
Hokay. First off, this is what comes in the box:
You get the trailer brake controller (I will call that the TBC from here on), the wiring harness, a pocket mount, and bar mount, assorted butt connectors, mounting screws, and instructions.
I bought a few other things for the install. 14ga control wire (a roll of black for power, and a roll of white for ground), a pack of 14ga ring terminals, a 20amp circuit breaker, and a cheap soldering iron since I can't find my Weller.
Here is a good diagram for the connection you are going to make: http://www.wjjeeps.com/electric_brake_inst.jpg
First, start off by disconnecting the negative cable on the battery.
I started the wiring underneath the hood. I couldn't find a suitable place to run the two power and ground wires through the firewall, so I drilled my own hole, and installed a grommet I had left over from the Autometer gauges I put in my CJ. The hole was a 3/8 bit to fit the grommet. Yours may be different depending on which size grommet you use. I ended up drilling from underneath the dash, underneath one of the main harnesses, right in the middle of the hood release and the throttle cable. I then pulled the two wires into the interior underneath the dash.
Inside
Under the hood on the firewall
At this point, I connected these two wires to the harness of the TBC. Black to black for power, white to white for ground. I removed about an inch of insulation from each end, slid on a piece of shrink wrap, wrapped the two wires together for a inline splice, and soldered. Slide the shrink wrap over the joint, heat, done.
Next, go under the hood to make the power and ground connections at that end. Now, I didn't fully understand initially, but the instructions tell you to run the power wire directly to the battery, with a 20 or 30 amp circuit breaker just before the battery. I choose a 20 amp due to the fact that the most trailer axles I will ever run is 2. They suggest if you ever run a trailer with 3-4 axles, put in a 30 amp. Same with the gauge of wiring, they suggest 14ga for 1-2 axles, 12ga for 3-4.
Now for the white ground wire, they emphasize to run that directly to the negative post on the battery. The reason being is that running to a chassis ground can cause noise interference, which can lead to interrupted braking to the trailer, which is bad. Especially in a panic braking situation with your crawler on the trailer behind you pushing you into whatever. I opted to heed their words, and it's easy.
I ran the ground wire along the back of the firewall, following some brake and vacuum hardlines, down the passenger side of the inner fender line, under the coolent reservoir to the battery. I soldered a ring connector to the wire (cut the plastic bit off with a razor blade so you can solder), heat shrinked, and put the ring around the clamp bolt. For the positive, same thing but, you have to add the circuit breaker. The circuit breaker protects against a short in the system or a overload in power. It is self resetting so you shouldn't have to worry about it. The breaker posts are labeled "to aux" and "to battery", so mount accordingly. I found a good spot above the coolent reservoir on the pinch weld of the fender. There was already a hole from the factory there, so I drilled out the hole bigger with a 1/4 bit I believe, and used a bolt and nut to mount.
Cut the black power wire where it will end at the "aux" terminal of the circuit breaker. Strip, crimp, solder, heat shrink, mount. Now make a length of black wire from the "batt" terminal of the circuit breaker to the positive clamp of the battery. Strip, crimp, solder, heat shrink a ring terminal on both ends of the wire. Mount to breaker, and mount to tightening bolt on battery clamp.
Tighten up the wires along the run from the battery to under the dash, and zip tie them down along the run so they are nice and neat. I think I am going to go back when I have time and put these wires in a split loom so you can't see them, and zip tie the loom.
Now to the fun part! Under the dash!
There are two more wires to hook up under here. The blue wire, which controls the actual voltage going out to the trailer through the 7 pin connector to power the trailer brakes. And the red wire, which connects to the brake lamp switch output for the stoplight.
The blue wire is up behind the fuse panel in the upper left corner under the dash. There are a lot of wiring looms in this spot, and I had to hunt for it, but it IS there, IF your WJ came with the factory tow package. Here it is pulled out:
Inline splice this to the blue wire on the TBC harness. Strip, twist, solder, heatshrink. I orginally used a butt connector for this, but I ended up soldering every other connection, so I cut the butt connector off and soldered this one as well.
Now to the really fun part! You are looking for the white/tan wire connected to pin 5 of the brake switch connector. Open up the loom above the connector to find the wire. This is it here:
Originally I had been told to use a scotchlock splice here, but when I did, it didnt cut into the tan/white wire at all due to the different size of it and the red wire from the TBC harness. This caused the TBC to not function correctly under regular braking with the trailer hooked up (no trailer brakes!) I decided to solder it.
Very carefully use a wire stripper to cut about a 1" section of insulation out. I ended up kinda cutting the two sides with a stripper, then using a razor blade to cut along between the two, and then peeled the insulation off. Be very carefull here as you do not want to cut any of the copper wire. I then cut 1" of insulation off the red wired from the TBC harness, separated and made a "gap" between the copper wire on the white/tan wire, and "braided" the red wire into the white/tan wire. Sure, this is overkill, but I wanted to make sure the wire had the best possible contact. I then soldered this connection, and used electrical tape to wrap it up and protect it. Unfortunately, I did not get a picture of this connection.
I should also add that when you are wiring under the dash, make sure you don't get wire tangled up, so you can coil up the excess, and zip tie them up nice and neat!
With the wiring done, time to mount the TBC. I was going to mount it by my left leg under the edge of the dash, but figuring I am a righty, I decided to mount it to the right almost against the center console. I used the pocket mount as it hold it up tighter to the dash, and I wouldnt be able to put the screw in the right side of the mount if I used the bar mount.
Line up the pocket straight under the dash, and drive in the two self tapping screws to mount it, making sure you do not screw through anything important on the other side up underneath the dash. Slide in the TBC till it locks in place, plug in the TBC harness connector, and reconnect the negative battery cable.
You're done!
02' WJ, 4" Hybrid Lift, Custom Rub
BigFire is offline
post #2 of 16 Old 09-12-2012, 11:17 AM
bradywgn71
bradywgn71's Avatar
I think this should be a "Sticky" and included in the FAQ. Nice write up.
bradywgn71 is offline
post #3 of 16 Old 09-12-2012, 11:25 AM Thread Starter
BigFire
Now to test it!
Hook up to your trailer. Safety chains, 7 pin, hitch, etc.
Find an open back road where you can stop frequently. At a complete stop, move the manual lever on the TBC all the way to the left. It will display the current voltage setting. Adjust the setting to about 6. Let go of the lever. This is the base starting point. Now accelerate to 25 mph, and without touching the brake pedal, pull the TBC lever all the way to the left. You should feel the trailer braking itself. Now you want to get to the point that the trailer brakes lock up, or almost lock up, and then back off a bit from there. Keep repeating this step until you have it dialed in. You will want to adjust this everytime you change the weight on the trailer (i.e. the trailer is loaded or empty).
Now drive normally to 40mph and brake normally. You should feel the trailer braking itself, and you SHOULD SEE the voltage going to the trailer on the TBC. This value varies due to how light or hard you are braking at the moment.
That's it! You are good to go.
I added my TBC because I built a rockcrawlering CJ that has to be trailered to the trail, and my WJ is my only tow rig at the moment. Being a non-pro on trailering, I thought this would be good for you guys and gals who are new to towing. Just remember to be safe, go slow, give yourself enough room to brake, and make sure your load is secure!
BigFire is offline
post #4 of 16 Old 09-12-2012, 11:31 AM Thread Starter
BigFire
Thanks mang. I try.
BigFire is offline
post #5 of 16 Old 09-14-2012, 09:25 PM
SirWilliam
I've got the Prodigy too. It's a great unit. I tow a 20' flatbed 7000# hydraulic tilt deck car hauler (heavy) with brakes on both axles and it's been excellent for that. I mostly just haul hay on it now....it used to haul cars when I still had my Powerstroke. I like that I can just set to Boost 2 when it's loaded then back to no boost when it's empty and don't have to worry other than that. It's also nice to manually add some trailer braking going downhill into a curve to help keep the trailer from wanting to push the Jeep too much. I'm running with just under 5" lift and 32" tires, and it still tows 3500lbs without issue.
2004 WJ Overland - 4.5" Lift - 2012 JK Sahara 18" 7-Spoke Polished Wheels with stock JK Bridgestones
SirWilliam is offline
post #6 of 16 Old 09-14-2012, 10:00 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Not quite what we're looking for as a sticky, but it would be a GREAT write up for the FAQ. Please do us all a favor and immortalize this write up by copy/pasting into the FAQ thread stickied at the top of the forum.
~Richard
billzcat1 is offline
post #7 of 16 Old 06-19-2013, 08:29 PM
Hondovious
FYI. On the 2004 the brake light lead is not white and tan, it is purple and tan.
Hondovious is offline
post #8 of 16 Old 06-19-2013, 10:44 PM
gtg413i
2003 WJ
Black for power and white for ground? Isn't it usually the other way around?
Brian's Black Betty Build:
gtg413i is offline
post #9 of 16 Old 06-20-2013, 01:01 PM
cubalz
What an excellent write up!!!!! Great job.
2003 Rubicon - 33x12.50x15 GY Duratracs, 15x10 MT Classic Locks, 2" BL, 2" BB, Warn Front Bumper, Garvin ATS Rear Bumper, Body Armor Extreme Rock Rails, Nth Degree Tummy Tucker, Skid Row Engine, LCA and Gas Tank Skid Plates, Teraflex Quick Disco's, Uniden Pro 520xl CB, 3' Firestik Antenna, BW Flat Fender Flares, Tom Woods DS, Currie Rear Adj Arms
cubalz is offline
post #10 of 16 Old 06-20-2013, 01:23 PM
briandor
I'm one of the lucky ones with a 2001 WJ that came with the tow prep package. The 2001 came pre-wired for the trailer brake assist. Apparently it is the only year that did. It's a blue 4-pin connector tucked up into the kick plate next to the fuse panel. You can see it if you shine a flashlight up in there. Tekonsha even makes an adapter for it.
For anyone with a 2001 looking to add the brake assign this pic is what you are looking for: http://wjjeeps.com/trailer_14.jpg
Tumbleweed1954 likes this.
briandor is offline
post #11 of 16 Old 08-18-2013, 01:55 AM
gtg413i
2003 WJ
I just installed a primus tbc. To do this a little better you should use an ignition switched relay or the tbc stays on for 15 minutes until it goes into sleep mode. By the way, thanks for the tool tips you have in your pic. Your wife is so kind to be in the pictures for you.
gtg413i is offline
post #12 of 16 Old 08-18-2013, 12:20 PM
Merc1973
subscribed.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #13 of 16 Old 04-23-2016, 09:48 PM
lacofdfireman
Perfect timing. I'm just getting ready to do this on mine. I'll be installing a Prodigy also to tow my OffRoad teardrop style trailer I'm building right now.
madZJ likes this.
lacofdfireman is offline
post #14 of 16 Old 04-24-2016, 12:53 PM
ShinyWJ
I realize this thread and particular comment are pretty old, but to bump it to the bottom of the thread-
Trailer stuff has a different standard for colors. White is ground and black is power, just like in a house white is neutral and black is hot. (AC of course)
Just thought I'd throw that out there!
2002 WJ Limited | 4.7 | Quadra-Drive | Inferno Red Pearl | Dark Slate Gray
ShinyWJ is offline
post #15 of 16 Old 04-24-2016, 05:50 PM
thecause17
thecause17's Avatar
It's a shame that we don't have an existing plug(unless you have an '01) like a lot of the later model year DC vehicles came with. My '07 Dakota had a plug. I installed a P3 in that, and it took me longer to mount the bracket than it did to wire it. All I had to do was plug it in.
I need to do this eventually, good write up.
'14 F-150 Ecoboost Super Crew 4x4
'97 ZJ 4.0 SOLD, '04 WJ SE 4.0 TOTALED, '03 KJ SOLD, '07 WK Hemi QD SOLD, '04 Columbia 4.7HO SOLD
thecause17 is offline
Trailer Brake Controller questions BigFire WJ Grand Cherokee Forum 13 09-12-2012 08:55 AM
WJ trailer brake controller RNMedic WJ Grand Cherokee Forum 4 06-08-2012 07:12 PM
Installing Brake Controller Subi69 WJ Grand Cherokee Forum 4 05-27-2012 03:14 PM
brake controller question hoyt5885 WJ Grand Cherokee Forum 0 06-08-2011 05:44 PM
Brake Controller gfriedm1 WJ Grand Cherokee Forum 7 03-19-2010 02:08 PM
