How does my 104K mile service check up look? Please check - JeepForum.com
post #1 of 25 Old 01-21-2009, 09:41 AM Thread Starter
MTSB
Have 104K on my '02 WJ V8 4WD. Want to keep it going for another 100K if possible. Time to change out all the fluids. Here is what I have on my list...
Engine oil + filter
F+R axle
Transfer case
Transmission Oil (Should I do both filters?)
Coolant flush
Plugs
Check belts
Now, what do you recommend for specific fluids? I'm in CA and the Jeep does not see harsh conditions, but does see towing a few times per year. Right now I'm running 10w30 M1 and thinking about going to 5w30.
Thanks.
MTSB is offline
post #2 of 25 Old 01-21-2009, 09:45 AM
ZJPunk98
Engine oil + filter
F+R axle
Transfer case
Coolant flush
Plugs
Check belts
Thanks.
stay with the heavier weight oil, go synthetic gear fluid and tc fluid, change the filters in the transmission.
I don't know ifyou have a cap and rotor, but i would suggest that as well.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline
post #3 of 25 Old 01-21-2009, 09:53 AM
kmd1776
no cap and rotor... or wires at that.
04 wj limited; 4.7L V8, 247> 242hd swap; Hayden auxillary tranny cooler; BFG All Terrain 245/70/17; Moog Up-Country Coil Springs; Monroe Reflex Monotube Shocks; JKS BPE's; Chrome Overland tow hooks; Dynomax Ultraflow catback
kmd1776 is offline
post #4 of 25 Old 01-21-2009, 09:57 AM
xJoshxx
2012 WK
Dont bother checking the belt just replace! get a Gator Poly V belt Good bite. never had it slip once.
DONT EVER EVER EVER use a fram oil filter haha. ok and u need a disturb+cap+rotor
xJoshxx is offline
post #5 of 25 Old 01-21-2009, 10:13 AM
gatorayde
He can't, he has a WJ which has coil packs.
gatorayde is offline
post #6 of 25 Old 01-21-2009, 10:21 AM
comptiger5000
If you have the NV247 (Quadra Trac II or Quadra Drive) Transfer Case, make sure you use the correct fluid.
comptiger5000 is offline
post #7 of 25 Old 01-21-2009, 10:52 AM Thread Starter
MTSB
I do have the Quadra Drive. Which fluid is recommended? The local dealer said the Mopar Transfer Case Lubricant - 3.4 pts. P/N 05016796AB is backordered.
MTSB is offline
post #8 of 25 Old 01-21-2009, 11:12 AM
gatorayde
nonononono, NEVER use anything other than Mopar fluid for the 247 TC. Man you are on a roll of mis-information today josh lol
post #9 of 25 Old 01-21-2009, 11:12 AM
WA_WJ
2003 WJ
For the 247 the amsoil works fine, thats what i just put in, might want to flush the power steering fluid and maybe new brake fluid cause i know mine was pretty nasty.
2003 Overland 31" KM 2's
WA_WJ is offline
post #10 of 25 Old 01-21-2009, 11:12 AM
xJoshxx
2012 WK
another reason why i like having my 242
and he has a v8 so he has coil on plug? damn im all maessed up todayz
going to stop using the interwebs
xJoshxx is offline
post #11 of 25 Old 01-21-2009, 11:14 AM
gatorayde
Quoted from wjjeeps:
NV247:
MoparŪ Transfer Case Lubricant
THIS IS THE ONLY LUBRICANT RECOMMENDED
post #12 of 25 Old 01-21-2009, 11:15 AM
99avant
That is what you need, and there is NO substitute.
|94 XJ|4.0|NP231|AW4|8.25 Trac Lock|Lotsa miles - SOLD
|99 WJ|4.7|242HD|Vari-lok|Upcountry+BB|DT8000|Dead as of 10/29/2009
If it aint broke, fix it till it is.
99avant is offline
post #13 of 25 Old 01-21-2009, 11:21 AM
WA_WJ
2003 WJ
I dont feel like searching right now, but there was just a pretty detailed thread that confirmed that amsoil had a fluid for the 247.
WA_WJ is offline
post #14 of 25 Old 01-21-2009, 11:21 AM
tennesseewj
No WJs have distributors, no matter what engine they have.
2004 4.0 Selec-Trac
BB->Black Diamonds->General Grabbers
Originally Posted by Sporer65 View Post
You need to learn, there are 3 things that all JF members must like beside Jeeps:
(1) Guns (2) Women (3) Bacon
Originally Posted by GraKee99 View Post
I was bored so I forded the river. No oxen were lost.
tennesseewj is offline
post #15 of 25 Old 01-21-2009, 11:23 AM
xJoshxx
2012 WK
i knows i was thinking of the 5.2 idk i alrdy said failed at interwebs for today get back to topic! lol
xJoshxx is offline
Check engine light and ways to check codes cody11ca ZJ Grand Cherokee Forum 12 01-11-2011 08:04 PM
100,000 mile check...what does my WJ need? chonger ZJ Grand Cherokee Forum 2 04-12-2009 08:34 PM
30K Mile Service Question (Dealer to do service) Natemare13 WK Grand Cherokee & XK Commander Forum 3 03-24-2009 11:52 AM
what should I check before going on a 800 mile trip? madmax ZJ Grand Cherokee Forum 6 06-30-2008 04:05 PM
30,000 mile check up ssg11bravo30 WJ Grand Cherokee Forum 2 11-11-2003 12:02 PM
